Better built implements
/ Better built implements #23
Does this count? - my home made land scape rake, powder coated, hydraulic controlled, rotates 360* with swivel offset. Completely home made from my CAD design, CNC plasma cutting of parts, new powder coat process.... yada, yada, yada.
Link to the entire build: CLICK HERE
Larry
/ Better built implements #24
Heck ya!!! :thumbsup: Forgot about that one!
/ Better built implements #26
You made the front of a tractor to put behind your loader?? Wow - that's one of the coolest things I've ever seen!! OK - I'll bite...
Here is an "attachment" I made to hold my mailbox (about 10 years ago):
Still looks mean after all this time.
JayC
That would be an instant ball bat target around here....freaking teenagers...
/ Better built implements #28
You show me what you think are pretty cool home made attachments you built and I bet I'll beat ya all with what I just put together.
Were all here still waiting for you to trump our builds. It better be good!
I vote for the Godzilla Dragon, it's just too cool.
Larry
/ Better built implements #29
Well, I claim the prize for best value for pounds lifted for $$ spent versus pounds of implement to facilitate lifting.
$$ = 0.0, I scavenged some used axles/hubs from scrap laying around
implement weight = less than 20 lbs for the axles... maybe a little more if you count the non dedicated chains.
lift weight = 2800 lbs of concrete culvert turned into a corner post. This culvert cannot be otherwise lifted because FEL bucket or forks add so much weight that relief valve pops first. I have numerous of these culvert corner posts and use the implement several times a year as I place them for new fence corners or replace old wood ones.
Best corner I've ever found...never rot, pull out of the ground, rust, tip. Axle shafts fit into holes manufactured in the culvert explicitly for lifting.
/ Better built implements #30
A couple of mine.
Some nice stuff, but you got to do better before I show case something you'll all want to build
/ Better built implements #33
I am thinking you just want to see our stuff so you can get some ideas on what to build.
Show us what you got, and maybe I will pull out the show case.
On what to build next....maybe J__J
/ Better built implements #35
Maybe you could show examples of other implements you have created to show you are not just fishing and the group will be more inclined to show you the better stuff.
Quick set of front counter weights I put together. I use them when I'm brush hogging. Can be put on or off in 5 minutes.
/ Better built implements #40
That's the biggest fence post I ever seen.
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2019 JCB 457 (A60462)
UNUSED RAYTREE RMSG29 - 29" HYD STUMP GRINDER (A62131)
UNUSED RAYTREE...
Freightliner Columbia (A63118)
Freightliner...
JLG Scissor Lift (A64047)
JLG Scissor Lift...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
