King Kutter Rep.
   / King Kutter Rep. #41
Welcome King Kutter Rep,
I don't if this has been asked yet, but I own a KKII tiller that I purchased from TSC. I see that TSC now sells a tiller that looks like a King Kutter, but has a different name on it. Is this made by your company, or someone else that make a close copy of a KKII tiller?
go to the first page of this one or the link thats here, it covers that.
   / King Kutter Rep. #42
King Kutter Rep...
I've got a new JD 2305, which per the manual has an 18hp PTO and 681 lbs lift at 24" off the 3-point hitch. I'd like to go with the TG-48, but it's 'recommended' for 20+hp PTO.. any experience using this at 18hp?
I was also looking at your XB tiller, but it doesn't seem to be offset so I'd be running over my tillin.. and I can't find but one review on it. Is this a new product?
Thanks
John
   / King Kutter Rep. #43
King Kutter Rep...
Thanks
John
I'm pretty sure the 2305 is what I would refer to as a sub-compact tractor, which is exactly the type of tractor we designed the TG-48-XB Gear Drive Rotary Tiller to go on.
The TG-48 is only offset, in that it is supposed to cover at least one wheel track on those larger compact tractors. However your sub-compact doesn't need that. The TG-48-XB is ideal for you.
   / King Kutter Rep. #44
Thanks KKRep.. how long have these XB's been out?
Also, is there a difference in the TG-48-XB-0 model? I found that at one online store with a somewhat lower price then the others (not sure what shipping was). Probably is, just want to make sure it's the same thing as the TG-48-XB.
Also going to call around to some possible KK dealers around my area (45177) to see if I can find one locally.. the ones mentioned on you website are a little far..
   / King Kutter Rep. #45
I believe they've been out for about three years.
The "O" at the end of the model number is the letter "O" not the number zero. It just means that it is painted Orange.
Let me see about a dealer for you.
   / King Kutter Rep. #46
King Kutter Rep...
Thanks
John
John, I can deliver a 48 inch Hawkline by Behlen in there to you for $1590 Total, To a business or picked up at a terminal nearby. 600 lbs, Gear Drive, 6 tines per rotor and slip clutch PTO. Ken Sweet
   / King Kutter Rep. #47
KKR
I'm in the market for a HD tiller 60" working width. How does the KKII TG-60 match up with the Woods GHT-60.
   / King Kutter Rep. #48
KKR
King Kutter TG-60
Model Designation TG-60
PTO Speed Req'd 540
Tractor HP Req'd 25 - 45 HP
Dimensions
Overall Length 25.5"
Overall Width 65.25"
Weight 630 lbs
Performance
Working Width 60"
Max. Tilling Depth 8"
Rotor Shaft Speed (RPM) 216
Gearbox Protection Slip Clutch
Construction
Rotor Drive Type Gear
Num. of Flanges 7
Num. of Blades per Flange 6
Hitch Cat I
Input Drive Line Category ASAE Cat. 3
Blade Type C shaped
Blade Spacing 7.875"
Woods GHT-60
Model Designation GHT-60
PTO Speed Req'd 540
Tractor HP Req'd 30 - 50 HP
Weight 628 lbs
Working Width 60"
Max. Tilling Depth 7.25"
Rotor Shaft Speed 211
Num. of Flanges 7
Num. of Blades per flange 4 (6 optional)
Hitch Cat I
Blade Type C shaped
Those are the specs. One thing you need to do is to check the price. For the money, in my opinion, the King Kutter is a much better value. Also on the Woods, the number of tines per flange is optional between 4 or 6. The King Kutter comes standard with 6 tines. 6 tines, in my opinion, are better than 4. So, no matter what you buy, try and make sure it has 6 tines per flange. Also a gear drive and PTO with slip clutch are ideal.
   / King Kutter Rep. #49
King Kutter TG-60
PTO Speed Req'd 540
Dimensions
Weight 569 lbs
Performance
Working Width 60"
Construction
Num. of Flanges 7
Hitch Cat I
Blade Type C shaped
Woods GHT-60
PTO Speed Req'd 540
Weight 628 lbs
Working Width 60"
Num. of Flanges 7
Hitch Cat I
Blade Type C shaped
Those are the specs. The Woods outweighs the King Kutter some. One thing you need to do is to check the price. For the money, in my opinion, the King Kutter is a much better value. Also on the Woods, the number of tines per flange is optional between 4 or 6. The King Kutter comes standard with 6 tines. 6 tines, in my opinion, are better than 4. So, no matter what you buy, try and make sure it has 6 tines per flange. Also a gear drive and PTO with slip clutch are ideal.
The gear drive over the chain and slip clutch I've learned are a must have. I got a qoute of 3400.00 for the Woods and around 1700.00 for the KKII. Thats half, how can that be or was somebody putting the screws to me on the Woods.
   / King Kutter Rep. #50
FYI I edited the weight of the King Kutter. I had the wrong weight. So they weigh basically the same.
I can't speculate on price. Sorry. I will say that there is a reason why we sell so many more tillers than anyone else in the United States. VALUE. It's not just that ours cost less. It's because they are such a good value.
If you look at the specs, IMO, the King Kutter is hard to beat.
Forklift (A56857)
Forklift (A56857)
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A59231)
2009 Mariah SC23...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
15200 (A56857)
15200 (A56857)
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
2018 JLG 742 TELESCOPIC FORKLIFT (A60429)
2018 JLG 742...
