power beyond to run power angle plow
   / power beyond to run power angle plow #1
sal64
ny orange county
jd 2320 jd 990 jd950
hello all i have a jd990 with power beyond can i run it through a log spliter remote to power my power angle plow? if so can anyone recomend the remote i should use.tuvm
   / power beyond to run power angle plow #2
I don't know about all the options available, but where's that plow gonna be mounted, front frame or 3pt hitch? and I assume you have no loader, to use those valves?
JB.
JB.
i have the plow now mounted on front i take off the loader tilt hoses and plug in the plow angle hoses . i no i could buy an electric diverter valve but rather use my power beyond and run hoses to a remote then to the angle.
   / power beyond to run power angle plow #4
Yes, you can do this easily. I would not use a logsplitter valve though because of the detent. Here is a decent cheap one: Surplus Center - 1 SPOOL 8 GPM PRINCE MB11B5C1 DA VALVE
Just buy short hoses and the proper QD's and "plug" it into the PB lines just like you would a backhoe or logsplitter.
   / power beyond to run power angle plow #5
I guess I don't get why he can't use the loader valve for 4 way plow, lift and angle.
Anyway, with that 1 spool valve plugged into my PB would that prevent 3 pt from working just like when back hoe is connected?
Was thinking if that would work for TNT, (already have 2 remotes from 3scv), wouldn't be logical if 3pt was disabled though Does fluid flow through some how?
Sorry for hijack Sal
JB
   / power beyond to run power angle plow #6
You are 100% correct, I thought he was putting the blade on his FEL but I just re-read his post...
Sal, Why do you think you need another valve to angle the plow?
If you have the newer PB kit, you have two returns. One feeds the 3PH and is used when the BH is not mounted, the other goes directly to the tank bypassing the 3PH that you use when the BH is mounted. If you use the return that feeds the 3PH-then no problem.
:confused::confused::confused: You don't have "two remotes" from the 3rd SCV, only one. I don't understand the second part of the question.
   / power beyond to run power angle plow #7
Not sure which one I have but I thought my 3ph is disabled when my BH is connected, if I have the old style could it be modded to work the "new " way.
I guess the proper term is one SET of remotes? was thinking about that even as I typed it.
JB
the plow is on my fel i take the bucket of put the plow on when i put my backhoe on i have a dump quicktacth i let the power beyond hang then my 3ph dosnt work .if i divert the powerbeyond line through a remote then to power angle my 3pt should work? tu
   / power beyond to run power angle plow #9
Ok, then you can add a valve like I mentioned earlier.
   / power beyond to run power angle plow #10
JB
Simple question: Does you 3PH work when you remove the BH? (of course the answer is yes!) Those are the lines you use-the ones you plug together to keep the fluid fluid flowing.
LEE G550 MOTOR GRADER (A51242)
LEE G550 MOTOR...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
UNUSED FUTURE FT-E48 ELECTRIC BICYCLE (A51244)
UNUSED FUTURE...
UNUSED FUTURE MINI EXCAVATOR HYD THUMB (A51244)
UNUSED FUTURE MINI...
UNUSED AGT XZ20R EXCAVATOR (A51243)
UNUSED AGT XZ20R...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
