Plugging in your tractor.....GENIUS!!!
/ Plugging in your tractor.....GENIUS!!! #1
Ezlivn
Robbinston Maine
2001 JD 790
Ok so I can't take credit for this cause I read it here on TBN first but thought I'd share it anyways. This is brilliant!
I bought this at Ace Hardware for like $25 bucks. I'm sure it's sold elsewhere. I plug my engine heater into this and click it on from the house.:) No need to go out in the cold to plug in your baby before you go out to plow. The only badfall about this is that you can't really tell if it started by just clicking it.....(no on light).....sooooo I plugged a worklight along with the engine heater so now when I click from inside the house and see the worklight come on.....I know the engine heater is on also. GENIUS!!!:thumbsup:
I LOVE this place!!:p
/ Plugging in your tractor.....GENIUS!!! #2
The only problem is the device has a range and beyond that it will not operate the relay. My building is out of the range. I go out early and plug in because it gets me out of washing the floor , vacuuming ,and doing the dishes.
Craig Clayton
/ Plugging in your tractor.....GENIUS!!! #3
My barn is 3/4 of a mile from the house.............
Plus, barns do not like unattended electrical devices..........
/ Plugging in your tractor.....GENIUS!!! #4
That is a great concept, but be careful to check the wattage/amperage rating of timers, remote relays and such. A lot of that stuff is built for smaller loads than the average block heater creates. When I was farming I used a couple 1200 watt rated timers; they were about $40 bucks each at the time IIRC which was more than triple the cost of a light duty timer.
/ Plugging in your tractor.....GENIUS!!! #5
I posted this on the Diesel Gelling thread--maybe this thread is more appropriate!
All this talk about gelling of Diesel fuel makes me nervous being a novice tractor operator as well as a Northern Vermonter. What dictates when one should plug in their tractor before operation---What temperature? My tractor has a heating block I am just not sure when to use it. I am sure this has been covered in this forum at one point. So far this winter no issue with starting. I do not depend on my tractor in the winter. However, I do like to use it to beat back some of the big snow piles from encroaching on us. Any advice would be appreciated.
I plug mine in maybe 15-20 minutes before use. Just a nice warming to help with startup. Of course if it's warm out...I may not bother. I don't think it hurts anything to warm it up before any use. Just my 2 cents
/ Plugging in your tractor.....GENIUS!!! #7
I bought this at Ace Hardware for like $25 bucks. I'm sure it's sold elsewhere. I plug my engine heater into this and click it on from the house. No need to go out in the cold to plug in your baby before you go out to plow. The only badfall about this is that you can't really tell if it started by just clicking it.....(no on light).....sooooo I plugged a worklight along with the engine heater so now when I click from inside the house and see the worklight come on.....I know the engine heater is on also. GENIUS!!!
Okay; now install a remote stater kit to complete the job!:thumbsup:
/ Plugging in your tractor.....GENIUS!!! #8
I have a programable timer that comes on at noon sowhen i get home from work at 3 i can get right to work , it shuts off at 4 if i have to work over .
/ Plugging in your tractor.....GENIUS!!! #9
My L4240 just sat outside for a week in zero to twenty degrees,I did not plug in the block heater,just wanted to see how it started,absolutely no problem;glow plugs come on for twenty seconds or so and fired right up.
I don't think a block heater is going to help for jelled fuel,I add PowerService in the winter,plus winter blend fuel and never have had a problem in the winter.
/ Plugging in your tractor.....GENIUS!!! #10
I use a timer and since I feed at 4:00 pm in the afternoon, I set the timer for 2:00 pm and the tractor is warmed when i go out to feed. If I have a "senior moment" and forget, the timer remembers!
/ Plugging in your tractor.....GENIUS!!! #11
It kinda depends on the tractor. Mine has Thermostart but the problem I have is getting the engine to turn over fast enough in cold temperatures. I have the block heater on the timer and it warms up for 2hrs before I feed and the tractor starts on the first turn even at -10°F.
I would say use your block heater in temps below 20 F and if it isn't effective than use it below 30°F. Find what works for your machine.
Fuel gelling is not a real problem until like -30°F, but water freezing in the water separator, on the tank tap screen, or in the fuel filter is a more common problem. Keep the fuel clean and water free, change your fuel filter(s) before winter weather and drain the water separator before and after every use and you'll minimize the problem. Keep spare filters on hand also.
If you get down to -30F regularly, and jelling (the filter look like it has wax on it) beomes a problem, mix one part of #1 diesel with 2 parts of #2 diesel or make sure that your fuel is a winter blend with a high pour point. There are also anti-gel additives.
/ Plugging in your tractor.....GENIUS!!! #12
I see no reason to plug the tractor in. I have a john deere 3120 2008year and it starts right up in the winter. I primarily use it to cut grass and do cores in the summer so it sits alot on the winter. I havent used it in three mounths and walked over to it and it started right up after activating the glow plugs. I daily drive a ford diesel and have never plugged that in either. I just let them both run for a few minutes before I use them to let them warm up. It was 19 degrees this morning anf my truck fires right up.
/ Plugging in your tractor.....GENIUS!!! #13
If you get down to -30F regularly, and jelling (the filter look like it has wax on it) beomes a problem, mix one part of #1 diesel with 2 parts of #2 diesel or make sure that your fuel is a winter blend with a high pour point. There are also anti-gel additives. ( From what I know about fuel is #1 is diesel fuel and #2 is furnace oil)Why would this work for gelling?If it doesn't make sense ask the question
/ Plugging in your tractor.....GENIUS!!! #14
/ Plugging in your tractor.....GENIUS!!! #15
I also use an appliance rated timer with the block heater to warm up the tractor if I know I will need it at a later date/time. Otherwise I use the walk out to the shed and plug it in routine :confused2:.
I like to leave it plugged in for an hour or so prior to winter use. Like others have stated it starts without the block heater but it starts and runs much smoother with it and warms up faster which I think is better for the diesel engine. I also have a battery tender on the battery to keep it fully charged year round.
The block heater is on the larger Kubota, GL3240. The BX does not have one installed but I generally do not run it much at all in the winter months and it is in a attached garage that stays warmer than the outside air.
/ Plugging in your tractor.....GENIUS!!! #16
I don't have a block heater on the tractor but it rarely gets below 30º here so it's not a problem.
I do however place a small heater in the car on an appliance timer for those frosty mornings. It comes on about an hour before I leave for work so the windows never need cleaning. Also makes the interior nice and toasty while the engine warms up.
/ Plugging in your tractor.....GENIUS!!! #17
Craig Clayton
I wrote about automating my barn here http://www.tractorbynet.com/forums/rural-living/187856-barn-wiring-home-automation.html. X-10 will work those long distances and has properly rated devices. I think the OP's idea is a great one.
Craig, I can certainly understand your reasoning. I just don't like the cold, so I want to get started right away.
Dead Horse, I lived with an unattended house (this was our weekend farm until last summer) for 25 years. Like all things, there is a risk with unattended electrical devices, but those can be mitigated by using the proper equipment and follow safety procedures. Still, I wouldn't try this if I wasn't comfortable with it.
/ Plugging in your tractor.....GENIUS!!! #18
When we had to re-do our electrical service several years ago I buried conduit from the house to the barn. Now I have a switch in the house that controls an outlet in the barn that my block heater is pluged into. So when I decide I need to blow snow in the morning, I flip the switch, have a cup of coffee, SS&S. When I go out the engine is warm and I have heat. I'll use the heater when the tempature is below 30 degrees. The easier it starts the easier it is on the engine.
/ Plugging in your tractor.....GENIUS!!! #19
I use X10 20amp 3pin appliance modules and our office computer to control the heaters in 3 of our tractors. Automatically turns heaters on and off in our equipment shed from house. Warm engine it starts like summer time and quicker heat.
/ Plugging in your tractor.....GENIUS!!! #20
if your tractor is fairly new i.e. less than 10 yrs old , it will start on glow plugs down to - 30 with a good battery.
it will only warm up faster when plugged in.
BARRY HILL 20 GALLON ALLY WAY SPRAYER, 3PT (A63291)
BARRY HILL 20...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
378908 (A61166)
378908 (A61166)
LILLISTON 8R ROLLING CULTIVATOR (A63291)
LILLISTON 8R...
2013 Ford F-350 Knapheide Service Truck (A61573)
2013 Ford F-350...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
