MF 1643
/ MF 1643 #2
More than a few folks have the tractor on here. I bet they would be glad to answer any questions you might have. I will be glad to help in any way i can.:thumbsup:
/ MF 1643 #3
I've had mine since July '10. What would you like to know?
/ MF 1643 #4
I just got mine 5 day's ago. still waiting for warmer weather to get it out and play with it. it's sitting in the shop with 1 hour on it.
/ MF 1643 #5
I just got a 1648, same tractor, just a couple of extra ponies, what would you like to know?
/ MF 1643
Basically just trying to determine how folks that have had one would buy one again and if anyone has had any problems with one.
Does the engine have balance shafts in it? How would you rate the smoothness of the 4cyl. engine? Thanks for the replies.
/ MF 1643 #8
I have had no problems at all with mine. I have the HST transmission, which is excellent. Only things I would change is adding factory rear remotes and a block heater. I'm going to have my dealer install both in the near future.
I'm not sure if the Iseki has a balance shaft or not, but I can tell you that it is extremely smooth. The engine is well isolated from the chasis and the operators platform is isolated from the chasis, so there is very little vibration that is felt by the operator. In fact, its almost TOO comfortable to drive...my wife likes it so much that I rarely get to use it!!!!!!
Overall fit and finish is exceptional. The paint matches anything the auto industry is putting out. I added extra lights to the fender and ROPS on mine. The factory headlights are incredibly bright, but unfortunately, if you add a FEL, the loader tends to block them much of the time.
I looked at JD, CaseIH, and NH before buying my MF. I am a big Deere fan and really wanted a Deere (and fully expected to buy one). The only reason I even looked at any other brands was to make my wife happy by shoppig around. When I saw the MF, I changed my mind instantly. Everyone has their favorite color and are sometimes blinded by that, but I think if you look at the tractors honestly, the Massey is a much better tractor than what any of the other manufacturers are currently offering.
Sorry for the long post. Bottom line, I love my 1643 and would recommend it to anyone.
/ MF 1643 #10
Does yours start well in cold weather?
I store mine in an unheated garage. The coldest its been in the garage is about 20F. The tractor always starts up first crank after I hit the glow plugs for 30-60 seconds. It smokes and rattles a bit, but it runs! I usually let it warm up for 15 minutes or so before I put it to use. I don't think the block heater is necessary, but it hurts my feelings to hear it start up cold!
/ MF 1643 #11
I recently looked at one and instantly fell in love. Only problem I found is that I couldn't justify the size. Still want one someday. Massey definitely got it right on the 1600 series.
/ MF 1643 #12
I have a 1547/Challenger 285B same tractor, different color. I purchased a factory block heater for around $ 75 bucks. Installs in one of the freeze plug holes. First try it leaked. Second try a bit of prem-a-tex #2 around the o ring and the leak was gone.
Plug it in for an hour and it starts in and instant. No clatter out of a cold diesel motor. She likes to warm up before start. All diesels do.
I added the two factory remotes. Maybe a two hour job. Get ready for some cash to go out of the wallet. Everything fit as it should.
My labor, free, personal satisfaction,free. Can't put a price on that.
Thats how I'd do it.
/ MF 1643 #13
I also have a 1643 CL. Like Wayne in the previous post. Hit the glow for about 15 seconds and it will start. It will blow some smoke and rattle but it will start. I feel sorry for it till it warms up....:thumbsup:
I also have a MF245.. If I didn't have a block heater it would be unusable in the winter. I have a magnetic heater and a block heater that I've used in the past. The magnet heater has a thermostat and can be left on for long periods. I used it primarily over the last few years. I would leave it on when the tempatures would get down below freezing. When the 1643 moved in the 245 lost its parking place at the barn and now resides at the hay barn. I do not power there but in a bind I will carry a portable generator up there and plug in the block heater. After a few min. it will start. but it takes forever for the fluids to warm up. When I had the magnet heater on it, it warmed the whole machine. Just jump on and go. Don't forget to take the heater off the oil pan or it will un hook it's self and tear up the plug.. Please don't ask me how I know that..:ashamed: I may try it on the 1643 but so far I haven't felt the need.
tpoole12
/ MF 1643 #14
Ask your wife YOU CAN ALWAYS JUSTIFIE THE SIZE.....:laughing::laughing:
I have a block heater on mine (live in Quebec)and even if it sleeps in my garage I will plug it before firing up ( an hour or so) and it fires immediatly very small black smoke and runs very smooth.
Just before buying my 1643 I went to a Kubota and tried a L4400 , it was vibrating and did not run smooth, it's what decided me to go to a Massey dealer......thank God .....this 1643 is a dream.
The only thing Massey could have put on those would have been another control arm in the back of the tractor to control the 3 pt lift arms. There would be no need to go back to the control on the fender to raise or lower the 3pt making it easy for us to attach some equipment. Have a nice day. Roger
/ MF 1643 #15
I really feel sorry for the tractors of other colors, massey just got the 1600's
right out of the box. gee, metal not plastic feels so much better
david
2015 Mack CXU613 Tri-Axle Day Cab Truck Tractor (A64194)
2015 Mack CXU613...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
1995 Ford LT9000 Tri-Axle Dump Truck (A64556)
1995 Ford LT9000...
HARDEE DITCH BANK MOWER (A64278)
HARDEE DITCH BANK...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
