Farmall 756
/ Farmall 756 #1
jsberhow
I'm looking at a ih756 gas, it seems to have what would appeear to be oil blow by. Is this something that is common? Should it be a deal breaking with the tractor, as all seems to be very good with it other that this concern?
/ Farmall 756 #2
You left so much open! what hitch? Two remotes? Wide Front? Condition other then engine? Tires? TA?
A lot of these tractors never got many hours maybe about 3500! To think that they thought gas was expensive then!!!!
Many have been converted to Cummins 5.9 to finish there lives in style and power!
/ Farmall 756
wide front, shows 4700hrs and tach is currently working, good tred on the tires, 2 remotes, tin is in good condition repainted a couple of years ago is good not great, new ignition parts installed, TA good. It fired up without issue in 15 degree weather and it was not warm to the touch prior to this, 3 point works well. Again, all in all it is a pretty solid unit, with the only concern being previously mentioned.
/ Farmall 756 #4
My concern would be the 5-6 gallons of gas per hour it will take to feed it at full power.
/ Farmall 756 #5
To have some blow by is not bad although it is a good bargining chip for a purchaser!
It certainly doesn't have many hours on it for it's vintage. Probably because of the fuel it would burn under heavy use. They did start well when cold and depending on use there still might be more years on the engine. The breather just having a bit of haze coming out of it when cold means it might be a full stream under heavy use, is there any signs of oil in the tube?
/ Farmall 756
First of all thank you for the responses.
Art, I do not know the answer to that question. I will have to check it out.
As for the fuel consumption, it is a concern but I think that it is common with all tractors of any size and HP.
柊ccording to the Nebraska Test Data the 706 (756 not tested) has max hp of 73.82, using 5.7 gal per hr at max hp.
柊 JD 3020 gas would have 70.59 max hp and fuel usage rate of 6.6 gal per hr.
漂our Oliver 660 would claim 67.23 max hp with a 4.8 gal per hr usage.
It is certainly known that the diesel would perform better in this category, but I like the simplicity of the gas engine and the reliability in cold weather starting.
/ Farmall 756 #7
the blow by really isnt to much of an issue.an the IH 756 is a good mid range tractor.being a gas burner you should be able to get it for under $5000.
/ Farmall 756 #8
That's also why these older, larger gas tractors are often well-preserved. Nobody could afford to wear them out even with 50 cent gas. Most 756 Diesels you will find have 2-3 times the hours on them.
At 4500 hours, if it hasn't had an overhaul, it is closer to needing one than the rest of these guys realize and excessive blowby can be an indicator. It is, after all, your dime.
/ Farmall 756 #9
I'm jealous, let me know how it goes, and post some pictures.
/ Farmall 756
No pics as of yet because still trying to decide. This leads me to my next question. What are the differences in the 706 and 756, other than the engine size?
/ Farmall 756
what is actually different about the shift mechanics
/ Farmall 756 #13
06 series shifter has the ranges as a straight line shift with a lockout latch for reverse. 56/66 shifter has a modified H pattern for the ranges. Much improved.
/ Farmall 756
Thank you for the feed back RickB, it is greatly appreciated.
/ Farmall 756 #15
The H pattern was much improved as long as you kept a long handled screw driver to unlock the shifter out of 2 gears when it stuck. It would seem to happen a couple of times a year, usally in the spring when everybody was getting used to driving it again. I thought my 1466 was the best starting cold diesel I ever owned. IH built a darn good engine. The T/A wasn't heavy enough and the layout of throttle, shifters and hydraulics could of been better. When you were plowing you need three arms to drop the plow, hit the throttle and shift the T/A. I did love that engine though!:thumbsup:
/ Farmall 756 #16
Never heard of anyone retrofitting an '06 shifter to a '56 or '66 tractor. Many are and still do swap out the '06 straightline for the later style.
Any of them will wear out and cause grief.
1770 (A58375)
1770 (A58375)
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
2011 Isuzu NRR Dovetail Flatbed Truck (A61573)
2011 Isuzu NRR...
2016 Ford Transit 350 Cargo Van (A61573)
2016 Ford Transit...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
