BX Front Axle Leak
/ BX Front Axle Leak #1
AceDeuce
Gold Member
Northern Virginia
Kubota BX1500 w/ R1's and LA181 FEL
Hey folks... anyone else had this problem? I have a pesky leak at the front axle pivot pin. Replaced the o-rings and keepers where the pin penetrates the axle housing but couldn't figure out how to get the old bushings out. The leak is better now but not totally fixed. I mic'd the pin while I had it out and found it to be within a few thousands of stock diameter over the wear areas so I don't think it needs to be replaced. The only other place for wear are the bushings. They appear to be pressed in but there is a landing inside the axle housing that prevents them from being pushed out or through. Do they have to be drilled out? I seriously hope not. Can they be pulled out somehow? What about slightly fatter o-rings? Any ideas would be a big help! Thanks.
/ BX Front Axle Leak #2
I have read about a few others leaking. Sorry can't help you on the bushing removal but I am going to attach an exploded view of the axle assembly.
Dumb question but did you double check the torque on the pivot bolt?
Roy
  • BX front axle.pdf
I did miss that reply, thanks. I guess the bushings will come out, although be it kicking and screaming.
/ BX Front Axle Leak #5
Just noticed one of mine is leaking as well.
Is this something that, if one side is leaking, I should go ahead and do both sides? If I remember correctly, I have somewhere around 400 hours on my 1830.
/ BX Front Axle Leak #6
oops - Wrong leak. Mine is on the left, front hub assembly, not the center pivot pin.
/ BX Front Axle Leak #7
This is what I posted a while back. The thread is here http://www.tractorbynet.com/forums/kubota-owning-operating/177471-bx-1500-front-axle-leak.html
I just finished the repair job. I replaced all the parts that bw12 did. I don't know how you did the repair with out taking the axle completely out. If just replacing the o-rings & back up rings, then removing the center bolt & dropping the axle down 6 inches or so would be easy. But to replace the bushings is a different story. I really don't think that the bushings or the bolt needed replaced, but I had the parts bought, so I went ahead and replaced them. The bushings, for others that have never done this, are pressed in against a lip, so that there is no edge to drive them out. I used a small chisel & cut a groove thru the bushing then kind of peeled them out. I couldn't have done this if I didn't take the axle out. That is really no big job. Just remove the power steering cylinder & the tie rod ends.
/ BX Front Axle Leak #8
The 1500 has been leaking there as well since about 400hrs. I snugged up the pivot pin to spec and that helped a little. I just let it leak and pour in old UTF change fluid occasionally. Its been low a lot but we keep the situation in mind and use 4wd only briefly when needed. And in the case of planned prolonged use we make a point to refill beforehand. The drive still operates perfectly at 1500hrs. A need to replace parts every 400 hrs is not acceptable.:mad:
larry
/ BX Front Axle Leak #9
Would using 90W gear lube slow the leak down VS UDT? I believe the manual states either lube is acceptable?
Roy
/ BX Front Axle Leak #10
Yeah, but gear oil still leaks out and I have gallons of used UDT.
larry
Chandler Equipment 20' Litter Spreader (A60462)
Chandler Equipment...
HYSTER S50FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S50FT...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A60736)
2000 ITASCA...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
