Can I put on a longer cord?
   / Can I put on a longer cord? #1
handirifle
Central Coast of CA
Massey Ferguson 1010
I have a Campbell Huasfeld (sp?) Mig welder, 85 amp, not a heavy duty beast, but it's what I have. My new shop has two seperate, dedicated 20 amp circuits for the welder, in different locations in the shop, but I still find the need for further reach. My delima is that at times the 8' welding cables are too short, and if working on something of size, that can't be moved, the 6' power chord will not allow the unit to be where I need it.
As far as I can tell (haven't pulled the panel off to look) the power chord is 14ga wire. Can I put on a longer power chord and still get full power from the machine? Haven't looked to see, first what ga the power cord is (pretty sure 14 though), and second, if a 12ga will fit through the cabinet.
How long could I go with existing ga wire before it gets detrimental to power?
   / Can I put on a longer cord? #2
If you have the 20 amp Receptacle (one T shaped slot) I would look for a 20 amp extension cord 12 guage minimum 10 gauge better
NEMA 5-20R
tom
   / Can I put on a longer cord? #3
I agree, why not just use a 10ga extension cord and be done.
   / Can I put on a longer cord? #4
I have a 135 amp mig welder that i used to weld up angle iron for a building frame. I ran that off of a 100 ft 10 gauge extension cord and it worked just fine.
   / Can I put on a longer cord? #5
I replaced the 6' 12/2 cord on my Miller 210 with 25' of 10/2 SO cord and a new plug the day after I got it home.
   / Can I put on a longer cord? #6
OK, but just don't leave a 100' cord rolled up when you only need a few feet of cord... Using a portion of a cord with a load wrapped around ferrous/magnetic type metal may create a problem too...
   / Can I put on a longer cord? #7
That will work Great for home use, but in commercial use OSHA Frowns on it.. I know of a welder sent in for warranty repair where the owner replaced the OEM cord to a longer one. Welder was repaired under warranty, but the cord was replace to the OEM cord length as a billed item...
   / Can I put on a longer cord? #8
When you buy the Cabtire ( extension cord ) the green bonding wire is not counted in the conductor count. For example 10/2 Aromered Cable ( BX ) for wiring a welding machine has a bare bonding conductor ( Ground ) to the receptacle. When you plug in the cord and it has 10/3 hard usage cabtire, so always include the green.
The reason they can it cabtire is because the first rubber covered cords used the same rubber as horse drawn carriage tires.
If the new cable is larger use an approved cord grip connector not a romex or bx connector.
Craig Clayton
   / Can I put on a longer cord? #9
i'd opt for the extension cord method myself. not knowing how big your shop is, i'd wonder whether maybe a 20' cord would allow you to reach anywhere from one of the two receptacles. i'd go as short as possible. the other good thing with an extension cord is that since it's running on 120v you'll be able to use the cord for all kinds of things. i'd expect a short 12/3 cord would work fine.
   / Can I put on a longer cord? #10
It's interesting how much an extension cord will drop the circuit voltage under load. I have an electric powered woodsplitter that I wanted to run at the end of a 100 foot cord. 14/3 cord showed 110 v with no load, then dropped to 75 volts measured at the splitter with it stalled in rock maple. Also the motor didn't sound happy starting.
I switched to 12/3, voltage dropped to slightly over 100 volts under full load, no more groan on startup either. 10/3 would have been better yet, but much more expensive and heavier to boot.
Sean
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
24 Foot Wells Cargo Enclosed Trailer (A50324)
24 Foot Wells...
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
TRUCKING INFO (A50774)
