2320 with Loader and Quick Hitch
/ 2320 with Loader and Quick Hitch #1
rocketjeremy
John Deere 2320
I think this may have been discussed before but maybe there has been some progress made and some solutions found. I have a new 2320 that I've been using with a 200cx loader all fall and early winter. The other day when they were calling for snow I started to get the machine ready for plowing. I took the adapter off the front for the MMM and wanted to put the bracket on for the quick hitch. However, there doesn't seem to be a way to put that piece on and still have the loader with the kick stand on. My hope was to be able to put that plate on and the drive shaft (most challenging part of the job) and leave it on with the bucket and only drop the bucket only when I put the blade or blower on.
I wouldn't plan on doing much with the bucket because I would be worried about damaging the drive shaft anyhow. Just hauling ashes, things between my garage and shop, and using it to lift heavy objects out of my truck, etc. Has anybody ever gotten it to work or come across some kind of adapter that makes it happen? Thanks!
/ 2320 with Loader and Quick Hitch #2
Can't have any of the quick hitch attachments on the
tractor and have the FEL on at the same time. All quick
hitch attachments need to be off of the tractor in order
to have the FEL on the tractor.
/ 2320 with Loader and Quick Hitch #3
Sorry Jeremy, but Greg's got it right. You can not have the QH and the loader on at the same time.
Welcome to TBN:D
/ 2320 with Loader and Quick Hitch #4
"Quick Hitch", you guys talking about the 'black' portion of this setup ?
That sucks from a design standpoint that you can't even have the adapter plate on. I figured the quick hitch itself (the black piece in your pic Willl) because I'd have all those extra hydraulic pieces anyhow. Sucks that they did it for the MMM and not the quick hitch attachments. I guess I gotta figure out a way to be able to do it all. I have my eye on a carry all from TSC to be able to do the hauling stuff around. I have some trees I want to cut up and need to be able to use it to haul. Any other ideas? Thank you for the welcome!! :thumbsup:
/ 2320 with Loader and Quick Hitch #6
Yes, and also the "box" that it mounts to.
/ 2320 with Loader and Quick Hitch #8
Doggone, that front end quick hitch pictured is the same thing that came with my 54 inch plow. And I didn't know that I had a quick hitch there. What else can it be used with? Willl, what's that green dohicky in your picture?
Oh getting back on topic. There's a post somewhere about a guy that tried to leave the adapter bracket on when he reinstalled the fel. It bent the fel stand and that's an expensive replacement. The hydraulic unit is about 70 pounds.
/ 2320 with Loader and Quick Hitch #9
Kenny,
Can you give me a rough guess what the entire quick hitch assembly weighs?
About 70-75 lbs like Ragkar wrote...+/- 10 lbs. The "box" weighs around 20 or so.
It is however SUPER easy to install/remove. Changeover from QH to loader could be done in under 10 minutes after you do it a few times.
Why do you ask?
/ 2320 with Loader and Quick Hitch #10
IDK, I stole the pic from somebody here. I belive it has something to do with a snow plow.
I could possibly do a re-research and find the thread. ?
/ 2320 with Loader and Quick Hitch #11
I leave the adapter and drive shaft in place, only removing the hydraulic lift/tilt unit, and have no problem with the loader going on and off. It did take a minor adjustment on the kickstand bar, but this has not impaired any function.
/ 2320 with Loader and Quick Hitch #13
Well, welcome to TBN:D
You gonna share this little "adjustment" with us?:confused2: Pics would be nice;)
/ 2320 with Loader and Quick Hitch #14
Will take a few pics later this week in the daylight, but basically it is not a mod to the kickstand, just bent it slightly.
Pics would be great!! Was that "thoughtfully bent" as in I planned to do that to make it work or opps I didn't realize you couldn't have both on but it worked out anyhow kind of bent? :laughing:
/ 2320 with Loader and Quick Hitch #16
Rocket, your analysis of my methods is right on target. But it still works
Well, loader AND quick hitch or not we finally got enough snow here to get out and have some fun!! We got about 2 inches here which is enough to want to clear off my driveway as it's pretty steep. Was so easy to just grab the blade with the quick hitch and off I went!! What a difference compared to my old JD 216 garden tractor with with chains and a blade. Instead of having to throw all speed and momentum at the snow along with a strong arm lifting the blade (even with the helper spring) I had a real treat.
I could angle the blade, raise and lower, work in low range, not that high RPMs and work in 2 wheel drive. What a pleasure to be able to work delicately and deliberately instead of having to just ram to get the snow where I want before the traction runs out.
Now if it would just snow deep enough to give the blower a try!!!! :D
/ 2320 with Loader and Quick Hitch #18
gtosvx, that's got to be the longest week ever!:D
Do you have pictures? I just bought my quick hitch today and i'm trying to figure things out!
thanks
/ 2320 with Loader and Quick Hitch #19
Sorry for the no pics,
I actually took them, but then my daughter took my camera.
I will take some new ones and post
/ 2320 with Loader and Quick Hitch #20
No problem. I got mine up and running now. I also took pictures but lost them. I can not get more pictures because I lent out my tractor to my uncle for temporary farm use.
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
1997 Ford Expedition 4X4 SUV (A66738)
1997 Ford...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2015 CATERPILLAR D6T LGP HIGH TRACK CRAWLER DOZER (A65056)
2015 CATERPILLAR...
PT 5' Disc Offset Harrow (A64912)
PT 5' Disc Offset...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
