Cylinder travel limiter
/ Cylinder travel limiter
My cylinder bent from too much travel and inattention on my part..
Anyway, I picked up the new cylinder today (3 inch piston, 10 inch stroke), more snow is coming so there's no time to waste :eek:
I may see if I can get a piece of chromed 1 1/4 round stock to replace the old rod, I know it's available. If I can get the rod for a good price, repair the cylinder and re-use it for something else, I may recoup part of my cost.
Got the steel cut for the new anchor bracket, and the old bracket cut off the frame. The new one should be quite a bit stronger than the old.
All told the "error" in planning will cost me about a hundred Semolians, this is what I get for trusting someone else's engineering. I do have to replace one hydraulic hose too, the old one is too short now with the shorter cylinder and change in bracket placement.
From what I can tell, the new cylinder should be CFD as far as size goes, and the new bracket will be a better looking job too. Other than the cost of the second cylinder, it's been an interesting exercise and a learning experience.
I should have some pics up by the weekend, I'll weld up the bracket on Friday weather permitting.
If this doesn't work, Craig's in big trouble..:laughing:
Sean
/ Cylinder travel limiter #22
Chilly807
I have posted all the pics of the rear blade that I put on and showed every stage of the layout. When you find the point where you get equal angles right and left you might like just a touch more in the direction that you grade to. I am right handed. The cylinder at 3"x 10" sounds good. Just remember not to change the blade angle under full tip load as then the pressure will be back to the hydraulic system. Another way to look at the cylinder loading is you can pull the quick couplers off of the tractor and the blade will not change the angle because the oil is locked in.
I was told by a Case mechanic that on the 6 way blades if under maximum angle push they operated the spool it could bugle a cylinder. As long as the spools were in neutral it was ok.
If was not so far I could come over and fix it. The other thing to think about is what direction do you want the blade tip to move in when you pull or push the spool lever.
When I pull my lever back the right blade tip moves back.
I was thinking of changing all my quick couplers around so a pull back causes a positive flow to always make the cylinder move the same direction.
Craig Clayton
Craig Clayton
Mine does the same, i.e. the blade angles to the right when you pull the lever back.
My hoses and couplers are colour coded so it's easy to get them right the first time.
Another way to do it is to put a male and female QC on the remote bracket on the tractor, it's impossible to mix them up. I have the two females on the tractor, they were the most expensive of the two parts, as well as being the most susceptible to rust and dirt if left outside for storage.
Sean
Got 'er together and painted up, trials went well this morning.
The old cylinder, complete with banana feature.
The new kid on the block.
New brackets and spacers.
Welded in place and painted.
Full right angle, cylinder at max extension.
Full left angle, cylinder fully retracted.
Rear view.
Moving the anchor point as Craig suggested was the solution, easier than dismantling the cylinder and installing a stop collar.
Sean
/ Cylinder travel limiter #25
Looks good, but do you get enough angle with it set up that way? Looks like 25* or less to me. As long as it works ok, then great. :thumbsup:
/ Cylinder travel limiter #26
Nice Job Chilly......Enjoy that beast.....looks great..!!
/ Cylinder travel limiter #27
I really like the PSE sticker on your tool box (though I shoot Matthews)..:thumbsup:
It's probably close to 35 degrees, I think the last set of holes in the original pin plates is 45*, and the next-to-last set lines up at the limits of travel. Snow flows along it quite well at that angle.
Sean
That IS funny.. I shot PSE for a lot of years, finally got tired of them and tried a Mathews. Haven't shot anything else since. I had an Ultramax (still have a set of 70 lb limbs for that I need to move) and a Conquest. Both bows got stolen at the 2000 Canadian 3D Nationals. I replaced them with a pair of MQ-1's, sold one of those and still have the other. Best-shooting bow I've ever had.
Sean
/ Cylinder travel limiter #31
I love my Mathews bows. I have both a Mathews Switchback XT and Mathews Drenaline :thumbsup:
/ Cylinder travel limiter #32
Sean
Chilly,
You and I speak the same language....I love 3D shooting..(not to hijack your thread)...... a couple of what I do when NOT on the tractor or NOT fixing hydraulics...........:laughing:
http://www.tractorbynet.com/forums/rural-living/184607-hunting-season-maine-2.html#post2154012
/ Cylinder travel limiter #33
To Chilly807
I sat on pins and needles all day waiting the for TRACTOR police to come and take me away for leading you astray. The BEAST looks good. What I have found when plowing snow is the angle of the blade to the forward travel of the tractor. When you get the blade loaded the back of the tractor likes to move slightly sideways, a slight reduction in angle will straighten out the tractor. This brings in the next rule which was stated many times DO NOT change the angle under MAX tip load. You now have the power to bend your rear tube. If you leave your cylinder locked under max load you have it triangled in and that is the strongest that you can make it. Think about adding a stiff support to the other side, running from the left lower pin bracket to the head pin at the back. We all make that mistake when going along and we are having too much fun and we jam the lever forward under max load. If you look at the old beast of the blade I am using the people before me bent it and added 1/2 "x 2" flat bar because the Factory supports were bending. I think it was used on a much larger tractor because it had a tough live before me.
Slow moving ( SIREN ) the TRACTOR police just went by my house.
Don't breaker the new toy because the warranty just expired.
Craig Clayton
The top of my blade had a few "waves" in it when I got it, the previous owner had welded the cylinder pivot to the blade itself, not the collar. I added a brace to the collar and no problems with bending it since.
Sean
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2014 FREIGHTLINER CASCADIA CA113DC T/A 6X4 DAY CAB TRUCK TRACTOR (A67148)
2014 FREIGHTLINER...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2016 PETERBILT 337 CAB AND CHASSIS (A65643)
2016 PETERBILT 337...
2022 SANY SY35U EXCAVATOR (A63276)
2022 SANY SY35U...
1989 STE 307 SS 4 Comp Non Insulated T/A Chemical Tanker Trailer (A64194)
1989 STE 307 SS 4...
