Buying Advice CT235
/ CT235 #1
Nightwind15
2009 BobCat CT235
Just got my CT235 with 32 hours on it. I really like it so far.
/ CT235 #2
They're great tractors. Just got our CT230 a few weeks ago to replace our 10 yr old tractor and it's been great. 10 hours and counting.
/ CT235 #3
I have 180 hours on my CT230. It is plugged in this morning. Some snow removal and firewood pallet chores to do today.
/ CT235 #4
You are going to love your machine. I have a CT 235 and love it!
Canada Ct 230, where did you get your pallet forks? And, if you don't mind, how much were they.
Tks Fred
/ CT235 #5
I bought them at my dealer. They are Bobcat forks and were part of their rental fleet. I paid $550. They are indestrucible with my machine.
/ CT235 #6
I have over 170hrs. and 80hrs. of it was doing with the chipper. Soooo, what other implements you got with that? I can see in your future that you will have lots...:D
/ CT235
I am still trying to decide what size implements to buy for my CT235. Do I go with 5' box, tiller and rough cut mower or go with 6' stuff. My Kubota 3240 was physically larger but put out three less horse power and I used 6' equipment with it. Just do not want to overload this tractor. The physical size of it is smaller but it does not weigh much less than my Kubota did. All help in deciding would be appreciated.
/ CT235 #8
Do you still have the 6' implements? If so, use them and see how it goes.
My feeling is that with this size tractor you are better off with a 60-66" box blade. An 84" rear blade or landscape rake. 5' bush hog, 6' finish mower. With a tiller, it sort of depends on your ground. I have a 58" tiller and sort of wish that I had a 72", but my ground is mostly top soil and is easy to till. That's not to say that your tractor won't handle 6' implements, just that I feel that you should be able to work an implement up hill and 6' implements can make that very difficult. I have a Mahindra 3215HST ballasted to about 5000lbs. I prefer to have implements that I have listed for this size tractor. ;)
/ CT235
Sound advice, thank you!
Anyone else?
/ CT235 #10
Nightwind15, did you get all the goodies with your tractor? Both remotes, suspension seat, bob tach, sun shade etc.
Just wondering
/ CT235 #11
Nightwind 15; I have a CT 235 (80 hours and counting). I have a 5 foot box blade and use this quite a bit, in particular for snow removal. I have a snow blade but like the box blade because it takes the snow out to the street and I therefore get no gravel build up on the lawn from windrows.
The other day the temp was above zero, the snow was wet and heavy. I had to go into a horse paddock to remove some snow as it was getting a bit deep for one of my ponies. I used the box blade ( extended top link to keep the front blade slightly off the ground). The tractor in mid-range was pulling the load and going through about a foot of snow and did so without problem. It was definately working and I thought this might be the limit. I'm thinking that a 6 foot blade would have bogged me down.
My tires are NOT loaded (also, I have Ag tires). I'm real happy with the power and ability with the 5 foot box blade. I am not an expert but I would suggest that a 5 foot blade may be your best choice. Additionally and for obvious reasons will be easier to get into tight spaces.
Ofcourse, things take longer with the smaller blade but I think it better suits this tractors power/weight ratio.
Fred
/ CT235 #12
There are several people that seem to have good luck with the 6 foot box blades on this size of tractor. My feeling is that a tractor should be able to scrape and pull a full load as in the picture up hill. If not, then your blade is too big in my opinion. These pics are not up hill, but my tractors will do this up a pretty good grade. Red tractor has a 66" rollover BB and the blue tractor has an 81" rollover BB. Both are Gannon's.
/ CT235 #13
I am still trying to decide what size implements to buy for my CT235. Do I go with 5' box, tiller and rough cut mower or go with 6' stuff. All help in deciding would be appreciated.
Just look at my sig... that is what I collected so far and all are easily handled by CT235 :thumbsup:
/ CT235 #14
I pull a 6' box with a CK25 gear. It does just fine. But, I think the 5' box would be better all around, especially with HST. But, I think you do have the HP to pull a 6' bush hog with a 235. I also pull a 7' scraper blade, and my little tractor has no problem with the scraper. In fact, it bent it very easily when it got hung on a root. Tiller: 5', finish mower: 7' rake: 7'
/ CT235 #15
You need a heavier duty blade. Unless you were moving at a high rate of speed, the blade should have held and spun your tractor around.
At least this one RB3584 or this one is REEEEEEALLY NICE RBT3584 :cool:
/ CT235 #16
One word of caution about using heavy duty blades made for both cat. 1&2 hitches on smaller CUTs: their higher moldboard and hitch heights make them hard to adjust for level pull while still maintaining adequate lifting height and a decent angle of attack for the cutting edge. (without a hydraulic top link)
My Woods HBL96 that I use on a larger tractor wasn't a good match behind my CT335. I ended up finding a deal on a Brush Hog 5007, it is a much nicer fit and I am happy with its performance.
/ CT235 #17
Milkman636, you may be right, without a hydraulic top link a person might have a problem with a smaller CUT. But I feel that with the blades that I recommended for his CT235, he would be fine. Of course he would be happier with "TnT" if he does not have them. :D
I know that I would love :drool: to have an RBT3584 for my Mahindra 3215 which is about the same size as his CT235. But then again I have "TnT" on mine.
Just my opinion ;)
/ CT235 #18
I have a Woods RB84. I was told it would be hard to tear it up. I was going very slow, 1st gear, low range. But, I was going down hill. Blade caught just for a second on a 3" root. Root gave way quicly and I kept on going. When I raised the blade I noticed it was bent. The bracket/plate where the blade is attaches to the pivot is what bent. Blade itself is find. But, I don't think it should have bent so easily. My original point still holds: The CT235 will easily handle a 7' scraper blade. You'd just have to be a bit more careful with the heavier duty blades (like the RB3584).
/ CT235 #19
Another instance where the dealer was wrong. I did almost the exact same thing with my 7520 and my MidWest RB4096 blade. I was naive and trusted the dealer as far as what I needed. :ashamed: After all, they are dealers and deal with this stuff all the time. Well with what I know now, I would rate that blade at maybe 50hp and 6000lb tractor. Oh, and the manufacturer said that I had abused the blade and that they would not warranty it. :mad: It was not a cheap blade, a little over $1,000, but it is not built for a 9,000lb 75hp machine.
Anyway, enough about dealers. :(
2021 CASE TV450B SKID STEER (A64279)
2021 CASE TV450B...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
2020 CATERPILLAR 289D3 SKID STEER (A64279)
2020 CATERPILLAR...
2015 A and A Melters A-110 Towable Hot Rubber Melter (A61572)
2015 A and A...
