Hose diameter/QC diameter question
/ Hose diameter/QC diameter question #1
nickel plate
CA
2002 New Holland TC40S
I'm in the planning stages of the hydraulics for a FEL grapple thumb which has one operating cylinder with two 3/8" ports. Should I then use 3/8" hydraulic hose? If I use 3/8" hose, do 3/8" QCs allow an equal amount of fluid through them, same as the 3/8" hose or if less, should I step up the QCs to 1/2"? There will also be several 90 degree ELS piped in.
/ Hose diameter/QC diameter question #2
Although the step up is recommended, I doubt that very many people do it. There isn't that big of a loss anyway.
If you had a continuous flow , like to a hyd motor, it might be a good idea.
/ Hose diameter/QC diameter question #3
For a grapple/thumb, anything bigger than 1/4 hose is a waste of money, and the 3/8" is harder to route as well. The small cylinders used on them require very little flow. 1/4" QD's will suffice also, but you can use 3/8" also if you want. The amount of 90's is irrelevant since the flow is only intermittent.
/ Hose diameter/QC diameter question #4
You should be able to get the maximum allowable flow rates from your coupler supplier. As long as the couplers you are considering allow enough flow for your application, upsizing shouldn't be necessary. If you're planning to use ISO 5675 Agricultural Hydraulic Couplers (aka "Pioneer" Couplers), here are some examples of flow rates from DiscountHydraulicHose.com.
1/4" Coupler = 3.2 gpm
3/8" Coupler = 7 gpm
1/2" Coupler = 12 gpm
3/4" Coupler = 20 gpm
1" Coupler = 40 gpm
If swapping attachments, or compatibility with other equipment is an issue, the 1/2" couplers are by far the most common size. We sell more of those than all other sizes combined.
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
NEW IDEA 2R CORN PICKER (A64278)
NEW IDEA 2R CORN...
2022 EZ-GO ELITE...
2012 T/A Frac Blender Trailer (A64194)
2012 T/A Frac...
Bigfoot (A64557)
Bigfoot (A64557)
2016 Chevrolet Tahoe SUV (A64194)
2016 Chevrolet...
