Tires rear wheel width
/ rear wheel width #1
JimP
southern New England
Kubota L5460HSTC; Volvo ECR88 excavator; Dresser TD9H dozer; Bandit RM990 chipper (sold)
So the new (to me) tractor is in the garage and I can't tell if the rear wheels (R4) are in the widest position. The centers are dished out, the rim lugs are external to the center and the valve stems are facing in. Can I get more clearance if I move the wheels so the valve stems face out?
/ rear wheel width #2
Put a straight board across the tire and measure to the lugs on each side. Put the shorter distance in towards the tractor.:thumbsup:
/ rear wheel width #3
Or... post a photo of the tire here, and we'll let you know. What model tractor is this?
/ rear wheel width #4
Agreed as there are several different configurations.
/ rear wheel width
Thanks for the replies. I measured across the rim and this is the mid position. Valve stem out is the wide position. I spent 3 hours very carefully swapping tires to widen the rear wheel track and make clearance for chains. Tractor is a 5240 cab and so far I am loving the cab!!!
/ rear wheel width #6
I had mine widened prior to delivery as I didn't want to wrestle with filled tires. I sure know what you mean as we have cabs on our L5030 and M8540; love it.
/ rear wheel width
TripleR - I also asked that the tires be set in the widest position since I run on hilly property and would be using chains. Tractor was delivered in the mid position. Oh well, time well spent with my son.
I've only had the cab for a couple days but working in windy, 30 degree weather in a tee shirt puts a smile on my face, I'm almost looking forward to plowing snow this year. I'll pay for it in the spring when I'm widening and raising height in the woods. Jim
Grease Pneumatic Air Gun, 50' Hose  (A62679)
Grease Pneumatic...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
Case Quitch Hitch (A66408)
Case Quitch Hitch...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
