Slime vs other sealants
/ Slime vs other sealants #1
usmc5595
Is slime as good as other liquid sealants that you can buy at tractor tire shops?
I am buy a new tire and I am going to have 3 gallons put into the tire. The shop uses a blue (slime like sealant) that costs $38 a gallon:mad:
I can buy slime for $30.00 a gallon and do it my self. This is for the rear tractor tires 13.6-28. The previous tire had the same blue sealant in it and had trouble sealing a 16 penny nail hole in the tire.
Just wondering if slime is as good as the rest. I have heard that it will get dry and rust out over time is this true?
The tire guy stated that the add a gallon evey year to prevent dry out of the "blue sealant".
/ Slime vs other sealants #2
I use super seal formula 100. Its $32 a gal and has worked pretty good for me. I use it in my 4wheeler tires also and do alot of hunting in west Tx where there is only catus and thorns and have not had a flat in the past 4 years
/ Slime vs other sealants #3
Just check into whatever brand you use, some are corrosive! Don't know what brand had been used in my JD 420 garden tractor front tire, but it had eaten a hole in the rim. ~~ grnspot110
/ Slime vs other sealants #4
My experience is that the sealants, a fibrous liquid mixture that seals by forming a filter cake over a hole, work great at first, but wear out over time as the fibers slowly break up. After a few hundred miles the tires on low speed equipment start going flat again if you leave them parked with the hole up. Adding more sealant "fixes" it for awhile.
larry
/ Slime vs other sealants #5
Thats not good Were u able to fix it or did you have to buy a new rim?
slime pro otr says that it will plug a 3/8" hole and the reg slime only a 1/4" hole
/ Slime vs other sealants #7
Why use slime at all in a tractor tire? It is not hard to put in a tube. I even broke down the front tire on my 4310 with r-4's. Yes, it is more work than pumping gook into a tire, but lasts longer.
/ Slime vs other sealants #8
Slime worked fine for a couple years on the front tires of my 4010. Last year, I had to remove them and put tubes in because they kept losing air. Now, they stay "up" all the time.
Ralph
Come visit South Texas and you'll understand why we use sealant. Everything here has thorns.
/ Slime vs other sealants #10
I needed tubes for the V61 tires anyway, so I cleaned & epoxied the bad spots & repainted. ~~ grnspot110
/ Slime vs other sealants #11
Thats a sweet looking tractor. I think I'd have to trailer it around town to show it off!:D
2016 Hyundia 53' Dry Van Trailer (A62613)
2016 Hyundia 53'...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
2016 Great Dane 50ft. T/A Refrigerated Van Reefer Trailer (A61573)
2016 Great Dane...
2023 Stearling Trailer (A60352)
2023 Stearling...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
iDrive TDS-2010H...
