actual repair cost by hour usage of skid crawler undercarriage
/ actual repair cost by hour usage of skid crawler undercarriage #21
Hey Bob Rocks, how did the OTT search turn out? Did you get them, if so how do you like them? I'm plainning on getting the steal ones, not so much for winter{chains work fine} but come spring I'll need them.
I'm still looking for the rubber OTT's like Solideal. Next to impossible to find used (folks really like them). All kinds of used steel link type are abundant around here on Craigslist. I think that the rubber OTT's give better tire puncture protection ("staking") for non foam-filled or solid tires.
/ actual repair cost by hour usage of skid crawler undercarriage #22
:thumbsup:
/ actual repair cost by hour usage of skid crawler undercarriage #24
When you get some real world experience other that tootling around on a 35hp toy bulldozer I will take you seriously.Um, okay, whatever. Doesn't matter to me if you believe me or not. Back in the early '60's I was running D-7 & D-8 cable blades. You remember those don't you? FWIW, my toy "hobby" dozer is 30 hp. Get ur facts straight. :laughing:
It's okay now, lets just give it a rest...
12345
/ actual repair cost by hour usage of skid crawler undercarriage #25
I need to pull the trigger on tracks for 2006 RC100 with 1307 forestry hours.
Labor is a WAG (wild a** guess)
Options are:
Complete replacement undercarriage from Terex
Undercarriage $18332
Tax $1604
Labor WAG $2000
Total $21936 .... $16.78/hour
Complete parts replacement
2 Tracks $4832
4 14" wheels $3414
10 bogie whls $6901
Tax $1325
Labor WAG $4000
Total $20472 .... $15.66/hour
Partial parts
2 Tracks $4832
4 14" wheels $3414
Tax $ 721
Labor WAG $3000
Total $11967 .... $9.15/hour
Tracks only
2 Tracks $4832
Tax $ 422
Labor WAG $2000
Total $ 7254 .... $5.55/hour
Any experience with labor estimates and rebuild knowledge would be appreciated. I'm inclined to have the dealer pull the tracks, inspect wheels, then make a decision on replacement vs. full-partial-none rebuild. Aftermarket tracks would not make a big difference in the total cost.
/ actual repair cost by hour usage of skid crawler undercarriage #26
I don't have any experience with the ASV or Cats but I have lots with the Bobcats. If it takes more than 2 hours of labor per side to R&R tracks somebody is milking the clock. I'm 5'-4" 140 lbs and I can do 18" T300 tracks by myself in that amount of time. A forklift speeds the process a bit, but I can still manage with just a couple of good sized prybars. Why is everyone talking about replacing idlers and "boogie" wheels? The Bobcats almost never have a problem with these wearing out or the bearings failing.
Brian
/ actual repair cost by hour usage of skid crawler undercarriage #27
This is a good conversation and also educational! With the new Kubota skids being out and sell in Case, New Holland and Gehl we have been talking with a different customer base then normal.
We have found out that some companies do have more problems with idlers and drives then others. We have also found so depends on the conditions, we have also found people going back to wheeled units.
/ actual repair cost by hour usage of skid crawler undercarriage #28
anybody that needs asv tracks i can get them for 4500 a pair from terex i got 2000 hours out of the ones on both of my pt100s
/ actual repair cost by hour usage of skid crawler undercarriage #29
$8.91 per hour track cost.
Just got machine back today. 1307 forestry hours on 2006 RC100
(2) Tracks $5076
(5) Bogie whls & tubes $2400
(8) 14" wheels $786
Labor $2380
Tax $1012
Total: $11654
/ actual repair cost by hour usage of skid crawler undercarriage #30
(2) Tracks $5076
(5) Bogie & tubes $2400
(8) 14 wheels $786
Labor $2380
Tax $1012
Total: $11654
Out of curiosity and my own self-interest, is $8.91 per hour an acceptable cost per hour in a brush cutting application? If not, what is, and if so, what amount would be too high for your personal liking? I hear numbers thrown around readily, but yours are the closest, unvarnished I have seen on the forum. I'll readily admit that I'm and ASV fan (I own a RC50), but I don't have any experience with the brush cutting side of the business other than about 4 or 5 guys I know that do it as a money making endeavor.
/ actual repair cost by hour usage of skid crawler undercarriage #31
my pt 100s got 2000 hours out of tracks and around 1200 out of sprockets and havent put any bogies on yet the pt bogies are way better than the rc ones and i only paid 3900 for my tracks
/ actual repair cost by hour usage of skid crawler undercarriage #32
Digdeep,
I'm in the market for an ASV RC50 or RC60...is your RC50 pre 2005 or 2006+? I'm leaning towards pre-2005 to take advantage of the lower weight (I want to run turf tracks)...do you have any advice on how to check out a used machine to determine undercarraige condition?
Tx!
Mark
You got to jack the machine up to inspect the axle roller brgs and boogies for play or dry.
For front and rear idler inspection you got to remove the tracks.
Track lug and wheel wear can be seen from the outside.
Be very wary if the owner has no detailed maintenance record.
Don't just take his word for it.Don't ask how i know this ;)
/ actual repair cost by hour usage of skid crawler undercarriage #33
Man, ASV and Cat's are pricey to repair. I am running my Takeuchi TL 130 with 2,300 or so hours on it. I have put three sets of sprockets on it, i am about to put my second set of aftermarket tracks on it, solideal "B" pattern and i wrecked a front roller while working a really steep slope. My cost so far is a pretty close estimate per hour. I am running real close to $2.43 per hour for under carriage repairs so far. I am an owner/operator so i am kind of careful, but you should also know that I sold my D-4C dozer about 3 months after buying my TL 130. I use the 130 for every thing from cleaning up after sewer and water installs, backfilling basements, to grading driveways, parking lots and sidwalks. In the winter it has a 6' snowblower on it. I love that machine. Cats and ASV's are nice but ridiculously expensive when it comes to track/under carriage repairs.
/ actual repair cost by hour usage of skid crawler undercarriage #34
Higher track repair costs are typical to forestry usage. Turning on cutoff brush digs into the track. Debris get lodged into the undercarriage. Material in the track is impossible to see from operators view. As in picture below, debris can be quite damaging. Combined with continuous full throttle usage and major heat generation, forestry is really tough on any machine. After denting the oil pan with a branch, I welded some mesh over the access holes under the engine and pump.
/ actual repair cost by hour usage of skid crawler undercarriage #35
I know that type of work is going to be tough on a machine, but having rocks, gravel, mud and concrete getting in the tracks and UC is pretty damaging if not more so. $10.00 per hour for UC maintenance is crazy.
I am surprised that your oil pan was that exposed, aren't there skid plates under it? Mine has 1/4" skid plates under it from front to back.
I do enjoy seeing a well set up Cat or ASV doing forestry work... love to seethe wood fly when they get into a tree or heavy brush. :thumbsup:
/ actual repair cost by hour usage of skid crawler undercarriage #36
I feel your pain on the track issues, but I'm curious about the mesh you welded over the access holes. What do they access, and what do you do when you have to go in there?
/ actual repair cost by hour usage of skid crawler undercarriage #37
I don't know why there are two 4" holes in the skid plates. They originally had rubber plugs, but they got mulched a long time ago. The holes are not convenient access to anything. I figured drainage. The expanded metal stopped the debris problem. In addition to denting oil pan, another stick pushed the wire connector off the oil sensor. The skid plates are heavy, I use a floor jack to drop & lift when cleaning out machine.
I also added some after market hose protectors to the undercarriage. They work well in stopping branches from damaging hose assemblies.
/ actual repair cost by hour usage of skid crawler undercarriage #38
The holes in the belly pan are so you can access the oil drain plug on the engine without dropping the pans.
On mine I got a 1/4" x 3" plate and drilled a 1/2" hole in it. Then I got a 1 1/2" x 3" plate, drilled a hole in it, then welded a nut on it. Slide the skinny piece in, then run a bolt through it to squeeze it together. Then you can take it off later if you want.
On the TL130 $2.23 per hr x 2300= 5129. That includes 2 sets of rollers and 2 sets of tracks? Sounds pretty good! Do you think the TL150 would be the same? Maybe I should get one of those!
/ actual repair cost by hour usage of skid crawler undercarriage #39
Hey I called about the ASV part number lited by Buck and they said it was $18,000+ retail but they would hook me up for $16,500 plus shipping, plus sales tax!!!!! So that would be $18 an hour just for undercarraige! WOW!!! Digdeep please tell us a part number and where to call for the $8,500 set!
/ actual repair cost by hour usage of skid crawler undercarriage #40
Tracks for the TL150 will run a few more bucks because of the size of them... but i know some guys who run TL140's and are only a grand or so ahead of me in track expense and we run about the same hours per set of tracks. The Takeuchi's are great machines and our dealer is amazing. I had mine in for new sprockets last year and they gave me a new TL140 to try out for the day while they put my sprockets on.
2019 TAKEUCHI TL10V2 SKID STEER (A60429)
2019 TAKEUCHI...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
(APPROX.64) 2X6X8 NO.2 PRIME LUMBER (A60432)
(APPROX.64) 2X6X8...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
TANK MANIFOLD (A58216)
80" BOX BLADE (A60430)
