Synthetic Engine Oil
/ Synthetic Engine Oil #1
Kubota 2350
Michigan, In The Thumb
2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
The JD manual doesn't say anything about using synthetic oil in the engine.
I been using JD 15w-40 and would like to switch to Shell Rotella 5w-40 synthetic for easer start ups when it's cold out, plus I think synthetic oil is much better for an engine.
I use synthetic oil in just about everything I have that has an engine.
Tractor is a 4310 E Hydro, with just over 600 hours on the clock.
What do you guy's think?
/ Synthetic Engine Oil #2
I use the Rotella 5w-40 in my tractor. Made for much easier starting last winter. :thumbsup:
/ Synthetic Engine Oil #3
Yep, do it. I would not hesitate:thumbsup: for a second about that decision.
/ Synthetic Engine Oil #4
We have moved totally to Rotella T6 5W-40 synthetic because we have found none better for all of our gas/diesel engines. One oil for everything is NICE.:thumbsup:
Tonight it is to be 9F and I hope I do not have to be starting anything but it is good to know any non starting issue will not be due to thick oil.
/ Synthetic Engine Oil #5
Using Mobil 1 in everything since the merger. Worked for Exxon in lube industry for 31 years. Knew Mobil 1 was the best from our research work on oils. After the merger, I could use Mobil 1 without feeling like a traitor. Gives you more hp and requires less fuel.
Forgot. using Castrol 5w30 put in by the dealer in our 2010 TDI until the warranty is off. Then I'll switch to Mobil 1 5w30 ESP that meets the VW spec.
Think that Rotella stuff is hydrotreated, not synthetic. Shell was big on hydrotreating.
Ralph
Do you use it all year around?
And do you think I'll have any problems switching over with 600 hours on the engine?
/ Synthetic Engine Oil #7
along the same lines...how many hours on the tractor before switching over? I just bought a new JD last week and want to make sure everything is seated well before doing this. I just havent any idea when on a diesel
/ Synthetic Engine Oil #8
John most of our stuff is quite old and never saw synthetic anything before we owned it and so far no synthetic use issues. The diesels are 60 HP engines (JD- year 1983 and MF year 1976) and the two larger gas engines are in a 1989 F-700 truck (429) with 145K miles showing and 1992 Chevy 454 showing just over 100K miles that I changed to synthetic 10K miles ago.
Oil will get dark quickly the first time you use synthetic I noticed.
/ Synthetic Engine Oil #9
I would run the breakin oil the recommended time and then change over. I have never had a problem changing over at anytime whether the engine had 50hrs or 5000hr.
/ Synthetic Engine Oil #10
I switched from Dino oil to Delvac1 last month in the Kubota, I expect it will lead to a very good performing engine.Plus the rapid oiling on start-up, and easier cranking. I have used Mobil 1 for years in our engines.Jy
/ Synthetic Engine Oil #11
When synthetic oils were first introduced, there was some fear of changing to them. Concerns that it might leak through seals and such were noted.
That was then and this is now. One can change to synthetics safely at virtually any time, if one chooses to do so. More and more engine builders from trucks, autos and other vehicles even come with synthetic from the factory. I suspect the future will see increasing use of synthetic oils of all types. I really like synthetic gear lube, for example.
Word is that synthetic hydro fluids are the next big thing. We shall see.
/ Synthetic Engine Oil #12
I run Mobil Delvac 1 (5w40) in most everything from my Duramax trucks to 3720 and 445 Deere, Honda Rincon, Polaris Ranger, Honda generators, etc.
Saves having a whole bunch of oils on hand.
/ Synthetic Engine Oil #13
The engines on premium compact tractors have a design life far beyond that of the tractor itself. We'd kinda like to make a big deal out of which engine oil we use... but it's not a big deal. As long as we use a premium quality engine oil rated for diesel engines, we're fine. Moisture from condensation is probably the biggest risk, because these tractors don't rack up a lot of hours, and sometimes sit outside for extended periods. Once moisture gets in the oil, it modifies some of the additives in the oil, reducing their performance. and even if the moisture gets boiled out, the damage is done. i'd rather use Castrol plain GTX oil in my tractor, and change it yearly...... than to run Delo 400 and change it in 4 years when I hit the hourly interval. Use a good quality diesel rated oil and be happy. If using synthetic oil makes you more happy, by all means use it. Either way, when the tractor is wore out you can use the engine on a genset or log splitter!
For all the fluids in the tractor, it's not the best idea to run them more than maybe 2 years unless your tractor is stored in a dry shop with a dehumidifier!
/ Synthetic Engine Oil #14
The oldest engine I switched to synthetic was my 1960ish Gravely. I always used a little bit of oil, but by the 3rd change on Mobil 1, it was using hardly any. Switched our 1983 240D at around 190k miles to synthetic. Its last changes were on Mobil 1 0w30. It gave about 1.4 mpg higher vs. 5w40. The old Benz would use about a quart of synthetic oil between 6-7k yearly changes. It had always used about a quart of dino oil between 3k changes. Dino oil is more volatile on the front end than synthetic. Therefore, synthetic oil use will likely be lower.
Any 0w or 5wxx oil is going to be more viscous at startup, even in the summer time, than it is at operating temperature. So, why would you have any problem with using a 0w30 or 5w40 in the summer? The 0w30 is gonna be 30w at operating temperature, and the 5w40 will be 40w at operating temperature. They'll BOTH be heavier at startup temperatures in the summer time.
Ralph
/ Synthetic Engine Oil #15
Delo 400 was petroleum based last I knew. That was several years ago though. I run the synthetics in my work stuff because I can go longer and it protects better if neglected.
If I were in a warm climate and cold starts were not an issue and I was using my machinery hard I would use a 20w50 petro. I run Cenpeco in my HP Duramax as it pushes the limits and can sit for extended periods. Extended sitting with synthetics can create dry starts as it tends to settle back to the pan more readily.
/ Synthetic Engine Oil #16
Is there any problem with mixing synthetic and non-synthetic oils?
/ Synthetic Engine Oil #17
It's been done for years and years. Of course, you can buy semi synthetic, but whether you do it yourself or buy semi, the benefits are somewhere in-between, of course.
I used to add a quart of syn to my wife's car at each oil change. 150K miles and running perfectly, with zero oil usage 11 hard years later. FWIW.
/ Synthetic Engine Oil #18
I've used synthetics for years and just to be clear synthetic is modified dino oil. I think a lot of people aren't aware of that.
I use synthetic (M-1) in my Subie but the Subie has hydraulic chain lifters and the synthetic runs out of them when I idle at a light and the engine gets noisy. Doesn't damage it though but it did take m awhile to figure out what was going on.
I ran synthetic Amsoil in my tranny and engine on my 2320. The tranny oil smelled and the rate of expansion must have been greater than the Deere oil because I would have to break the oil lines once and awhile to get the quick connects off.
On my 3320 I am sticking with Deere oils. I heard they are semi-synthetic. I remember reading that synthetic has smaller molecules than dino, I think the jury is still out whether that is good or bad.
So far my 3320 has started well in the subzero temps it's seen and my dealer just gave me 5-w30 for my next change coming up soon. Remember the 'w' = winter in oils guys.
I think synthetic is good for a lot of apps but i think you can't go wrong with Deere oils and Deere might be stodgy old company but I'll be they pick their oils supplier very carefully.... Good enough for me!
Rob
/ Synthetic Engine Oil #19
I used JD 15w-40 during the break-in period (about the 1st 100 hrs.) then switched to Mobil One 5w-40 Turbo Diesel Truck. Start ups in cold weather were greatly improved. I just changed the oil for the winter and filled it with JD 0w-40 synthetic. Again, noted improvement in cold weather (currently daytime highs about 25*F) over the 5w-40. I used the 5w-40 year round and plan on using the JD 0w-40 year round as well. The JD 0w-40 is a great oil.
Hop on over to the forums on www.bobistheoilguy.com and you'll learn more about oil and lubes (among other topics) than you ever cared to.
/ Synthetic Engine Oil #20
I used the proscribed break-in oil for the first 50 hrs or so and changed to synthetic Mobil 1 - 5w40 Turbo Diesel.
Have used it for the past 4 years. Great oil! Cold starts and warmup are a monumental difference from the conventional oils that I've used in the past!
Just this past year or so - I switch over to John Deere 0w40 synthetic. It has been just as good a performing lubricant as the Mobil 1 - IMO.
Planning to convert every engine on my place to the JD synthetic.
AKfish
2R CULTIVATOR, 3PT (A64280)
2R CULTIVATOR, 3PT...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
(INOP) TAKEUCHI TL10V2 SKID STEER (A64280)
(INOP) TAKEUCHI...
GE ENERGYSTAR WASHER & DRYER STACK (A64281)
GE ENERGYSTAR...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
JOHN DEERE 8400R TRACTOR (A64280)
JOHN DEERE 8400R...
