Leaking steering Jinma 204
/ Leaking steering Jinma 204 #1
Catch95
Australia
Jinma 204
I've started losing hydraulic fluid from the left side axle / hub. I've attached a pic showing where it is coming out. Excuse the messy tractor but its been very wet here!
I've been topping up the fluid for the power steering but am losing the battle. Any help on what needs to be done would be much appreciated. Is this a repair I can do myself? And what parts am I likely to need?
Many thanks
Mark
/ Leaking steering Jinma 204 #2
There should not be any hydraulic fluid in that area. The front axle should be lubed with gear oil, same as the tranny. The only hydraulic fluid up front is in the power steering system and that has no fluid connection to the steering axis. If it is hydraulic fluid you're seeing there, it must be running there from the power steering hoses or cylinder - check it out closer. If it is actually gear oil, then you'll need to tear down that front kingpin assembly and replace the seals.
Rich
/ Leaking steering Jinma 204 #3
Locate items 28 through 31 on the diagram;
  • felt washer 184.31.108
  • oil seal FB50x72x7
  • oil seal FB50x72x12
  • bushing 184.31.150
Could be any one, I'd replace all four.
//greg//
Thanks for the replies.
Greg - is that the same as Rich is saying - that it would be transmission gear oil that is leaking?
How big a job is it to replace those seals?
Thanks
Mark
/ Leaking steering Jinma 204 #5
Not transmission fluid either. And if you actually ARE using tranny fluid in that tractor, don't. Use gear oil. At least that's what should be in your front differential and drive hubs; typically 80W90 gear oil. Same stuff as should be in the shuttle/creeper box, the transmission box, and the rear differential.
And based upon what I've read so far, I believe it's a job that you should have done by a mechanic. Four manuals usually come with these tractors;
1. operations & maintenance, engine
2. parts engine
3. operations & maintenance, tractor
4. parts, tractor
The mechanic will benefit greatly from #4 when doing this job. Do you still have yours?
//greg//
/ Leaking steering Jinma 204 #6
Okay Rich Waugh, and the others are correct that IS NOT hydraulic oil it should be gear oil as stated. It is not a hard fix, just messy go to Ranch hands site he has a picture by picture fix for this. I had to replace the felt seal{same as what your showing in your picture} on mine so while I was at it I replaced all of the seals per Greg G diagram. The fix itself is basic and IMO simple, it does take some time because of the mess.
/ Leaking steering Jinma 204 #7
Catch95,
I'm still a bit confused here: you say the front axle assembly is where the fluid is showing up, but at the same time you say that you keep having to replace hydraulic fluid in the power steering. I think you really need to thoroughly clean the whole front end assembly and then start it up and see if you can actually determine the real origin of the leak. If the leak is form the front axle, it will be (should be) gear oil, and would require disassembling the front axle assembly to replace all the seals shown. A tedious job but not terribly difficult if you can read the diagrams and have experience with general mechanic work. If not, hire it done.
If the power steering is the source of the leak, then things may be simpler to fix. Could be a loose fitting, a leaking hose, or a seal bypassing in the steering cylinder. Or your loss of steering fluid (hydraulic fluid) could be a separate and unrelated problem - the axle could be leaking and the steering fluid loss could be from a bad pump seal or the other issues I mentioned. How is your engine oil level? If it is going up while your steering fluid is going down that would likely indicate a leaking pump seal passing fluid into the engine sump. One more thing to check.
90% of all mechanical work is diligent diagnosis - the rest is mostly just changing parts. The place you have to start though, is the diagnosis.
Rich
/ Leaking steering Jinma 204 #8
Um, not all JM204s even had power steering. And even then, take another look at the opening photo. Isn't the hydraulic pump is on the other side of the tractor?
//greg//
/ Leaking steering Jinma 204 #9
Yes, the pump is on the other side, but the hoses for the steering cylinder are clearly shown in this view. Thus, a leaking hose, fitting or cylinder seal could be responsible for the fluid observed and the fluid loss the OP mentioned.
I stand by my suggestion to thoroughly clean the whole front end and then try to determine to *source* of the leak. Doesn't matter where the pump is, or even if has one or not - locating the source of the leak is important to diagnosing the problem.
Many thanks for your thoughts. I had a look at the Ranchhand site which was great. Will clean it up and have another look.
Certainly not losing engine oil, but I haven't checked the transmission oil level. Will do that next week when I'm back up at the farm. I definitely think it is coming out around the area with the felt seal that Greg mentioned.
Problem I have here is getting parts - not a good supply in Australia yet so I tend to still get from the US. Pain to start working on something and then wait a ten days for the parts.
Will let you know how I go
Cheers
Mark
/ Leaking steering Jinma 204 #11
the 204 uses a light weight motor oil in the transmission and in the front axle, the dip stick is on the left side, the seal and felt washers are not that hard to replace, just be careful because of the weight. oil will not feed from the transmission to the front axle. some tractors may have hyd oil in place of the motor oil
/ Leaking steering Jinma 204 #12
Relative to Chinese tractors, this advice/info flies in the face of conventional wisdom. How/where'd you come up with it ?
//greg//
/ Leaking steering Jinma 204 #13
Don't know if'n I'd ever want to use hydraulic oil as a working drive axle lubricant - manual transmission either...
/ Leaking steering Jinma 204 #16
i do repair work on the chinese tractors and find hyd oil in the drive train, but i do not like it or advise it
I think I know what you're talking about now; UTF (or Universal Tractor Fluid). You're correct, that's the wrong stuff. UTF is for common sump tractors, those that use one fluid for both gears and hydraulics. Individual sump tractors (like Jinmas) take gear oil in the gear boxes, hydraulic fluid in the hydraulic sump.
//greg//
/ Leaking steering Jinma 204 #17
I thought my seller (NORTRAC) said to use 30W oil in the tranny and all that stuff. Is that right or wrong?
/ Leaking steering Jinma 204 #18
That is what the manual states. The issue is in China oils are hard to come by. Running 30W will work but is not the best choice for our climate plus we have a wide variety of quality oils available to us here.
Use 15W40 in the engine. 80W90 gear oil in the tranny and front axle. Use AW32 in the hydros.
Chris
/ Leaking steering Jinma 204 #19
I had to replace my left axle two years ago. I did not put all the seals in correct and it leaks a little. I just keep on trucken, and have had no problems. But I will probably take it apart one of these days.
/ Leaking steering Jinma 204 #20
yes it is a good idea to clean then take the boot off or pull it back to see if the leek is there (steering cylinder ) and for the motor oil going up if it ever happens it will be your injector pump seal gone :thumbsup: ps the best grease cleaner i found if oven cleaner ---but you spray it on and hose it off with in 2- 3 min strong shi t my eat your gaskets if you leave it on to long :cool:
