59 blower cutting edge - cheap replacement?
/ 59 blower cutting edge - cheap replacement? #1
defed
Gold Member
WNY, USA
was ordering the parts for my 359 to 59 blower gearbox conversion and was going to add a new cutting edge to the list...until i saw it is $100! that seems a bit extreme.
is there a 'cheap' alternative? worse case i can probably rehab the one i have and get some more years out of it.
thanks.
/ 59 blower cutting edge - cheap replacement? #2
Simply go to your local metal supplier and buy 5/16" or 3/8" x 3" flat stock and bolt it in place of the old one.
That is all the origional blade is!
OK, you need to drill the holes, use the old blade as a template.
/ 59 blower cutting edge - cheap replacement? #3
Is it really that easy? Isn't it hardened steel in the blades? Does it matter if it is hot rolled or cold rolled?
i figured it also had a beveled edge (or 2 if reversible) and square holes for the carriage bolts.
/ 59 blower cutting edge - cheap replacement? #5
That is all I got, "beveled edge" you can buy it buy the foot. I did not pay for mine as I mentioned it to a neighbor that I blew out his driveway last winter and he picked it up for me. I did price them out about two years ago and "think it only would have been about thirty bucks for a five footer.
/ 59 blower cutting edge - cheap replacement? #6
You should be able to turn it around and wear the other edge back to the bolt holes. At least I did on my 46", I am assuming it is the same on the 59".
i haven't looked at it closely enough yet to know if it has already been reversed. i had just noticed that the original edge is rolled up a bit, probably from hitting rocks. since it's rolled up, i'm thinking there is still enough to give it a resurfacing w/ the grinder.
it's not high on the priority list, as i have to fix the gear box and modify the mounting a bit before i can even use it. was just going to order one while i got my other parts until i found out how much it was. was figuring about $30!
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
PREVIEW DATES AND TIMES (A65579)
PREVIEW DATES AND...
1143 (A63745)
1143 (A63745)
Yale 5K Forklift (A63688)
Yale 5K Forklift...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
