Four way flasher fuse
/ Four way flasher fuse #1
rsm123
bx22
My bx 22 keeps blowing the four way and turn signal fuse. How do I fix it?
/ Four way flasher fuse #2
Take out all of the bulbs and the fuse. Put a ohm meter on the fuse side that the lights are hooked to. It should read an open. If it reads a short then you have either a bare wire touching metal or a shorted light socket.
If you get a reading on the meter with the bulbs out then you may have a corroded light socket.
If it reads open, put the bulbs back in one at a time until it blows the fuse. That is the place to start looking for the problem.
Make sure the fuse you are using is the correct size fuse.
/ Four way flasher fuse #3
The above is very good information.
Does the fuse blow right away.
Does the fuse blow as soon as the flasher is put on.
Does the fuse blow shortly after the flasher starts.
A shorted lamp will blow the fuse right away.
Craig Clayton
/ Four way flasher fuse #4
Craig and Gary are right on with their advice. Depending on how you turn the signals on such as in a steering column where the wires enter is a likely place. As is a defective switch that might be cracked.
Thanks everyone for the great information!!:
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
2006 JOHN DEERE 160C LC EXCAVATOR (A64279)
2006 JOHN DEERE...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
2022 EZ-GO ELITE...
