CHAINS?? PLEASE HELP ONCE MORE
/ CHAINS?? PLEASE HELP ONCE MORE #1
chrispratt11
John Deere 4310
Hello, everyone.
You all have been such a great help to a newbie tractor owner. This site is the best.
Ok, now I have the front plow mounted. The back tires have been loaded. Now all I need is the back chains that everyone has said I MUST have. Can people give me some recommendations for back tire chains for a JD 4310? Trying not to spend more then $300 all day. I live in NH and have a steep driveway.
Thanks again
oh, can anyone also make a recommendation on a additional light I could mount?
/ CHAINS?? PLEASE HELP ONCE MORE #4
If you're anywhere near Milford stop into B & B chain they're a part of Chapell tractor. Good people, pricing is decent and you'll get good info as well as being able to handle the merchandise which always helps me. I'm in So. Me and use double ring chains as they are self cleaning and I use them through spring mud season.
here's a pic of the bottom half of my driveway, I can't find the photo going up from here.
Here's what I decided on the tractor, I bought a canopy to keep dry and found it the ideal place for mounting lights. The angle is much better while using the FEL than ROP mounted lights. I have two trapezoidal beam lights on the front and two floods on the back. after several years of use I still wouldn't change a thing. I hope this helps.
/ CHAINS?? PLEASE HELP ONCE MORE #5
Not sure of your tire size but i got chains from tirechains.com that fit my 17.5L X 24 for just over $200 and they are in PA. Free shipping also. :thumbsup:
/ CHAINS?? PLEASE HELP ONCE MORE #6
When you order chains make sure that you order the correct one. There is difference between chains for R1 and R4 tires of the same dimension.
/ CHAINS?? PLEASE HELP ONCE MORE #7
For my 4300 with type R4s I got a set of rear chains from tirechains.com. Was happy with the quality of the chain and their service. Obviously you will need to know the type of tire you have and the dimensions so that the chains fit properly. Also it may be necessary to install spacers so that there is enough room for the chains. In my case I had the rear tires swapped and that provided an extra inch or so which was enough for the chains. Don't know if the same can be done or needs to be done on a 4310?
Tire Chains by TireChains.com
/ CHAINS?? PLEASE HELP ONCE MORE #8
If you have a steep driveway, and get a lot of ice, then chains become a necessity for snow removal, towing, and material hauling. Even AG tires don't get enough bite into ice that you get with chains.
And the same holds true if you're using the tractor as a log hauler pulling over rock and brush; especially if you're using brush as support over swampy areas.
Never heard of studded tractor tires. I guess that any instance that you needed them would end up pulling most of them out of the tires in a short period of time.
/ CHAINS?? PLEASE HELP ONCE MORE #9
Was that $200 a piece or for both?? I paid $100 for a pair of 26x12x12 tire chains from them. Surely the larger chains are much higher. Thanks.
/ CHAINS?? PLEASE HELP ONCE MORE #10
I also have used Tirechains.com and I would highly reccomend them as a source of information and chains. They have been very helpful to me, a tractor novice. I have purchased front and rear v-bar chains (dirt/gravel driveway and private road) from them and are happy with the quality. A neighbor of mine also purchased from them luckily he also purchased the tools required to cut and size the chains for a perfect fit. We had a record setting Snowvember here in the Northwest and I am happy I had the chains.
/ CHAINS?? PLEASE HELP ONCE MORE #11
That was for the pair. It was $211 to be exact. That was for the duo-grip chains
/ CHAINS?? PLEASE HELP ONCE MORE #12
I bought one of these online last spring for $45 shipped:
Super Duty Truck LED Work Lights | Truck N Tow.com
I bought it from these same guys and have no idea why the price is now 5X what I paid -- maybe they go up just prior to winter or something. It's a really nice bright light with a super low draw. I know it's tough because I had it mounted with a pop-nut on my canopy and I lost it while brush hogging. I ran over it with the right-rear tire and found it face down totally embedded in dry clay. Dug it out, cleaned it up, and remounted it (better this time.) It still works fine. I wouldn't pay $250 for one, but maybe someone on this forum can tell you where you can find them for a better price. In any case, I suggest you consider going with LEDs for your additional lights. They cost more up front but keep you from taxing your tractor's electrical system.
2004 Chevrolet Tahoe 4x4 (MPV), VIN # 1GNEK13Z24R318274 (A61165)
2004 Chevrolet...
2016 HEIL TRAILER (A63569)
2016 HEIL TRAILER...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
Electric Tricycle (A64194)
Electric Tricycle...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
