Ever had this happen?
/ Ever had this happen? #1
s78wingrider
Gold Member
Hardy Co. WV
Mahindra 3215 gear
I hooked the air hose to my older Stanley Bostich coil framing nailer and it instantly fired, just missing the largest window I have in my building! :confused2: I unhook it between uses because it leaks some and didn't think of it going off again, but about put hole in metal roof! After that, was more careful where it was pointing! Could cold have something to do with it? I have a finish nailer I have to keep in house cause it won't fire when its cold :confused: Aaron
/ Ever had this happen? #2
Probably some crud blocking the trigger.
Cold suggests maybe moisture trapped in there.
I like to spray mine with WD-40 to sort of wash it clean from time to time. Works for me.
Thanks PILOON! sounds like a good idea :thumbsup: Aaron
/ Ever had this happen? #4
do you put air tool oil in it ( does it need it? )
soundguy
/ Ever had this happen? #5
WD40 has a lot of Stoddard Solvent in it. If it's not compatible with the seals you might have a mess. I'd check the manual for what to use for lube.
Does the nailer have a contact shoe? It shouldn't fire if it does.
/ Ever had this happen? #7
I've had this happen a few times on my Bostich framing nailer. Now, I lower the line pressure before hooking it up then increase the pressure to where I need it. Hasn't happened since.
/ Ever had this happen? #8
I betcha the vast majority of users have never considered this to be a possibility and have never seen it happen. All it would take is to be unlucky the first time it did though, and a person could be in for a ton of grief, both physically, mentally and economically. A soft tissue injury might be a blessing instead of getting it in an eyeball, an artery or your "junk".:shocked:
/ Ever had this happen? #9
I treat air nailers like real guns. I've seen nails blow right threw stuff being nailed or get deflected and it's scary. I'd have someone familiar with those at least look at it. Even call the manufacturer and ask. I've found them to be great helps when I have questions.
/ Ever had this happen? #10
I was just using my nailer yesterday.....hooked/unhooked several times moving from room to room. Never gave it much thought as to where it was pointing during the process.......I think I will now.
/ Ever had this happen? #11
:thumbsup:
Air nailers and powder actuated nailers should always be treated like firearms when it comes to safety.
One of the most important safety considerations is maintenance. Blow dust and debris off your nailer before and after use. Keep it lubricated with proper tool oil. If it's not operating properly, determine why and fix it.
harpoonalt is right about treating as real gun :thumbsup: I've used nail guns for I don't know how many years and never saw, had, or heard of this happening, thought I had been careful till now :ashamed: (still going to school!) Aaron
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
John Deere 2155 (A62177)
John Deere 2155...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
2021 BOBCAT T62 R-SERIES SKID STEER (A64279)
2021 BOBCAT T62...
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
2021 UTILITY VS2DX 53X102 T/A DRY VAN TRAILER (A59912)
2021 UTILITY VS2DX...
