Buying Advice Google Earth Pro
/ Google Earth Pro #1
Rod in Forfar
Forfar, Ontario, Canada
1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
Don't download the 7 day trial of Google Earth Pro until you have some heavy lifting to do, because when the seventh day ends and your screen goes blank, you'll feel like Aladdin when they took away his magic carpet. It costs $400. to get it back for a year.
So why am I mentioning this on a tractor site? In the last week I mapped every field on the farm, calculated the acreage of each, and wrote a legal description from point to point using bearings and Lat and Long points, correct to 1'. I also generated a 25.5 Meg Photoshop map to illustrate the property for years to come, and all in a couple hours. When I got down to work with it, having those GPS points on tap was like having access to that other great mythical tool, the sky hook.
Work that would have taken a survey crew quite a while and cost a lot of money was completed for free in an evening in the kitchen. I dictated the property description to my wife as I ran the boundary lines and noted the heading and length of each.
So if you want to do some mapping of the back 40, you might want to try Earth Pro on a 7-day trial.
/ Google Earth Pro #2
Where did you get the description, from the deed? I plotted mine on a CADD program and sometime ago they began requiring a zero closure error, so there was a second description. In the origional they used the stone border walls for most of it, and when I plotted the second with their tweeking for zero closure error it showed my property about 15 feet short of the wall along the longest border, saying I had something like a third of an acre less land. Seemed to me that the hundreds of tons of stone must be right, but it's a legal battle just waiting to happen.
/ Google Earth Pro #4
My remote property location in the mtns has never had a decent Google Earth image, lower resolution than more populated areas nearby. Maybe the "Pro" version is better?
A few weeks ago I used Google Earth to generate a map with 2 points marked with lat/lon for purposes of importing it into another program to make a field map for radio direction finding equipment. I found Google Earth's lat/lon displays to be off quite a bit in the field..again maybe the "Pro" version is better but I sure wouldn't rely on the free version for any accuracy. BTW Delorme Topo USA was dead on.
/ Google Earth Pro #5
If you want real good GPS accuracy and decent aerial photos, try USA Photomaps. It's a FREE program that a retired pilot created and it uses aerial photos from Microsoft's Terra Server. It's easy to use and incredibly accurate.
The link is at this site: JDMCOX Software (He also has TONS of other FREE and very useful tools)
Here's the direct link to download the .exe file: http://jdmcox.com/USAPhotoMaps.exe
Sample screen shot: http://jdmcox.com/Sample.jpg
/ Google Earth Pro #6
The JDMCOX map data is old (1996 ish) and not very close zoom. My 160 acre at max zoom is a full screen. Is there any newer data and tighter zoom?
/ Google Earth Pro #7
Can you tell me a bit more about Delorme Topo USA? I have read a little about it but I am not familiar with it.
/ Google Earth Pro
My son set me straight on the software. Turns out the free version of Google Earth will do the same things I value in the commercial version. So I get to keep my magic carpet/sky hook. Cool.
/ Google Earth Pro #10
It depends on the area, check the Microsoft site (MSR Maps) to see if anything better shows up there. That's where the program gets the imagery.
/ Google Earth Pro #11
Got to looking at our place on Google Earth the other day and found it had been updated, 28 Oct 10. I actually saw my tractor towing our water tank up to the pumphouse to refill. Also saw our little goat herd. Couldn't see myself since there is a canopy on the tractor.:laughing:
Kind of cool seeing that.:thumbsup:
2012 Ford E-350 4x4 Terra-Hawk Mobile Surveillance Van (A61573)
2012 Ford E-350...
2017 TROXELL 130 BBL VACUUM TRAILER (A63569)
2017 TROXELL 130...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2013 CATERPILLAR 305E CR EXCAVATOR (A64279)
2013 CATERPILLAR...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
2022 EZ-GO ELITE...
