Low visosity hydrolic fluid
/ Low visosity hydrolic fluid #1
Netmo
I am not sure if I am in the right place to ask my question. Since it the topic is hydralics, I am sure I can find some one with the right knowledge to help me with my problem.
I am looking for a hydralic fluid with low viscosity, I mean low anout 5 or less. This is for a new application. I am trying to create a pulsatile flow using a pump for a new application. It is low pressure application. Maximum pressure will be 5 PSI. Lowest is 1 PSI. I searched everywhere and I couldn't find any site for selecting a fluid low visosity. Any body has any sugesstions. many thanks if some one can help me.
/ Low visosity hydrolic fluid #3
What about using a 0W-20 engine oil?
larry
/ Low visosity hydrolic fluid #5
Transmission fluid can be purchased in many viscosity that are very low, something to think about.
/ Low visosity hydrolic fluid #6
Is there not a water soluable product that can be mixed with water???
Cutting fluids use such products that will lubricate and mix with water.
/ Low visosity hydrolic fluid #7
I think the viscosity there is so low that sealing within the pump element would become a real issue, allowing a lot of bypass. Some pumps could handle it, but probably not a gearpump at hi pressure.
larry
/ Low visosity hydrolic fluid #8
larry
At 5 PSI???? You could use a centrifugal pump, instead of positive displacement. I may be missing something here.
/ Low visosity hydrolic fluid #9
Netmo,
The best oil with low visc to my knowledge is Aircraft Hydraulic Oil
Mobil AERO HFA is what I use.........Texaco Hyd Oil #15 is another........
MIL-H-5606 is the Military spec for their use in low visc hyd oil.......
Other manufacturers have similar stuff just use the "5606" designation to convert to another brand.....
/ Low visosity hydrolic fluid #10
Also Kubota SuperUDT.......plenty available at your local dealer......
That stuff is very thin......
/ Low visosity hydrolic fluid #11
:eek: I missed the 5 PSI. Hard to imagine that as a hydraulic application.
larry
/ Low visosity hydrolic fluid #12
larry
I think we are missing what the whole concept is about. I was wondering also if this was a typo.
/ Low visosity hydrolic fluid #13
He only has one post. He may be playing with you guys.
/ Low visosity hydrolic fluid #15
on our bucket trucks up here in Canada we use Exxon Univis J13, it's an aircraft hydraulic oil for cold weather. Some of the trucks that come from the southern states will use a 22 grade oil, put this at -25 and it flows like tar, we change all our trucks to J13 for year round service, it's a little thin for extended hot weather use but thats normally not a problem for us. Jim
/ Low visosity hydrolic fluid #16
In our bucket trucks the standard oil we use is a 22, we can a dyed blue (arctic) oil with a 15 weight to it for use in winter weather or pilot operated valves. I haven't seen anyone using lower, and I don't think I'd recommend it, you'll start to lose the properties of oil in general when you approach the viscosity of water.
/ Low visosity hydrolic fluid #17
Hi Rocwin... we work on your trucks (RH aerial) as well as others, posiplus, versilift, wajax, telsa, Utem, duralift, etc. for the last 20 years the only oil we spec is J13, the odd one will come in with ATF but that's mostly digger derricks.
We have very few problems with J13 unless some mixes in ATF, then in cold weather you will get tank foaming ( the base stocks are different and will not mix when cold) you may want to check the specs on the oil, you will be surprised at it's properties. Jim
/ Low visosity hydrolic fluid #18
Meyers snow plows are a problem in cold weather.
Most users I know use automatic transmission fluid (ATF).*
Works great!
*ATF is hydraulic flud, just thinner than our tractor 'universal' type.
/ Low visosity hydrolic fluid #19
FYI, the viscosity of engine oil when it reaches operating temperatures is very close to the viscosity of water.
/ Low visosity hydrolic fluid #20
Thanks Glastron23. I just took a look at the spec sheet for the J13 oil and ours performs a bit better. The J13 has a VI of 300 (resistance to viscosity change with temperature) while our MV15 is 356 and the viscosities are very comparable otherwise. Our normal oil MV22 does well with 253 VI for our temperatures, but like I mentioned there are issues with very small lines on some equipment. When the UTEM booms come here from Texas they'll put a 32 oil in them, we make sure to order those empty so we can put our own in, during winter they become unusable.
Engine oil and hydraulic oil serve two different purposes, hydraulic oil is used to transmit power while engine oil is used as a solvent and lubricant which is actually pretty close to water (without the rust.)
Massey Ferguson 383 Tractor (A64047)
Massey Ferguson...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
2022 EZ-GO ELITE...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
Deutz D3006 Tractor (A62613)
Deutz D3006...
