Ashes to Ashes, Dust to Dust. . .
/ Ashes to Ashes, Dust to Dust. . . #1
jinman
Rest in Peace
Texas - Wise County - Sunset
NHTC45D, NH LB75B, Ford Jubilee
. . . or so it would seem.;)
I just bought a used New Holland LB75B TLB. My dealer was excellent and promised me that for his asking price, he would make the tractor work ready. He changed all the fluids and filters and replaced a front wheel final drive seal and rear axle seal plus he cleaned the tractor up spotless before delivery. All went well for the first week except an intermittent start failure and finally a leaking outlet manifold on the injector pump. The dealer dutifully came and picked up the tractor, repaired the leaking injector pump and replaced the main transmission shuttle switch on the steering column since he said that was the source of the starting problem.
After a week in the shop, the tractor was returned and I was thrilled to have it working so well, until my starting problem came back. Because I didn't want to be without my tractor for a week and I pride myself in my electrical troubleshooting abilties, I decided I would troubleshoot the problem myself. Since it's an intermittent problem, it became quite a challenge. When the starter would fail, the symptom was that I would turn the key to start and nothing would happen. Sometimes if I held the key at start for a couple of seconds, the starter would engage and work. Most times, by the time I got the cover off the relay access panel and my meter attached to read power, the starter would suddenly work and continue to work over and over. The embarrassing thing was it would fail almost anytime I went to show somebody my tractor. There's nothing like showing someone your new tractor and it won't start.:eek:
Well, last week, it failed completely. Even after about a dozen attempts at turning the key to start, there was no response from the starter. I was able to troubleshoot the whole circuit and found the problem was the Starting Relay, a 12 VDC, 70 Amp relay that energizes the starter solenoid. The relay is tucked away behind the starter, mounted on the firewall behind the engine with the main 80 amp fuse. Why NH chose this spot is beyond me.:rolleyes: It's dark, hard to access, and not a place you want to be sticking your hands when the engine is hot. Anyway, I pulled the relay and jumpered power to its coil while checking continuity to the main contacts. NOTHIN'! The relay coil had continuity, but the main contacts were not completing the start circuit. I immediately figured burned contacts were probably carbonized and not making contact. To make sure the tractor would start, I jumpered the starter with a hot wire and it worked perfectly. There is nothing wrong with the starter or solenoid.
I checked NH's price on the start relay and it was something like $52. I thought that seemed like a very expensive price, so I looked at Grainger and they had the relay for $8.95 plus shipping. Even with shipping, it's less than $20, so I purchased the relay and decided to jump start the tractor until it gets here.
Yesterday, I looked at the relay and it had a nick in one corner on the top that went all the way through the plastic. I looked closely and there was a hole that went all the way into the interior of the relay. I decided to cut off the top plastic cover and inspect the relay and contacts. The photos below show what I found (sorry they are cellphone quality). The darn relay was full of fine dust/sand. The quantity just blew me away. I think in the 40 years of working in electricity and electronics, this is the strangest thing I have ever seen. I found insects and animals in electric circuits, but I've never found a sealed relay with a tiny hole that was packed full of sand. I could not believe my eyes. There must have been close to a teaspoon full of sand in the relay.
After removing the sand, I put the relay back into the socket and it still would not work, but the contacts got hot. That told me there was contact resistance and I removed the relay and cleaned the contacts. I returned the relay to the circuit and it works perfectly. My tractor starts instantly. I'll leave it this way until the new relay arrives from Grainger.
I'm still completely baffled as to how this relay got full of sand, but I think the problem may have been the thorough pressure washing the tractor got at the dealer before delivery. I was there when they were washing the tractor and they had the engine side panels off and were cleaning all inside the engine compartment. What do you bet the pressure washing sent mud and sand down the firewall and into this relay? It's gotta be that. Very weird.:D How this relay ever worked when it was packed full of sand is beyond my comprehension.:confused:
/ Ashes to Ashes, Dust to Dust. . . #2
Holy smokes that is a lot of sand/ dust. Looks like it needs better water proofing besides a better location.. Good work Sherlock Jinman.. Being an electronic tech for the last 30 years I have had to scratch my head a few times at things I have found..
/ Ashes to Ashes, Dust to Dust. . . #3
Was that relay made with that hole as a vent? Or had something else made the hole?
Bird, it was not an intentional hole, but looked like the corner of the relay had been struck at some point and chipped off. I can't see how that would happen where it was located on the tractor, so my money is on it being chipped off and just installed that way at the factory. It was so small I almost overlooked it, less than 1/4" chip gone with a hole the size of a pencil lead in the middle. Maybe heating up inside and then cooling caused air/dust to be drawn in. I just don't know, but the pile of dust is impossible to deny. It was packed in there like a brick, almost like a dirt dauber had been busy making a nest except I've never seen a dirt dauber that small.
/ Ashes to Ashes, Dust to Dust. . . #5
WOW! I never seen that much sand in a tiny box. maybe it was mr sandman in its former life:laughing: ?
/ Ashes to Ashes, Dust to Dust. . . #6
I can't recall seeing any relays with vent holes, so I'll bet the new one won't have a hole it and will fix the problem. But even with the hole in the old one, I'd agree it's hard to imagine that much sand/dust getting in there.
/ Ashes to Ashes, Dust to Dust. . . #7
How old/how many hours does it have? Fine dust will work its way into anything. If it has been like that the whole life of the TLB it is plausible... it probably spent its whole life in a dusty environment.
/ Ashes to Ashes, Dust to Dust. . . #8
The cowl is probably installed after the engine at the factory. If it is a tight fit it might have been damaged during assembly and collecting crud since day one.
/ Ashes to Ashes, Dust to Dust. . . #9
I read the title and electrical problems and was thinking this was going to end in a fire. Glad you found the problem.
Well, the relay was getting awfully hot before I cleaned the contacts. I touched the actuator lever and it almost burned my finger. After cleaning the contacts, there was enough conductive surface that it didn't even get warm. . . .and I plead guilty to using a title that I thought would get folks attention.:D
Charlz: The TLB is a 2005 model with 3600 hours. It was owned by a fellow who installed septic systems, so it has seen its share of dry dusty places, I am sure.
/ Ashes to Ashes, Dust to Dust. . . #11
I'm betting that it was damaged from the beginning, and after all those hours of air from the fan and from just being used, the dust found it's way into that tiny hole and as luck would have it, you got to deal with the end result. At least you were able to troubleshoot it!
/ Ashes to Ashes, Dust to Dust. . . #12
jinman,
Good job! Warms my heart to know, someone out there is willing to take the time to trouble shoot a problem the high paid mechanics won't.
Sitting down and thinking is sometimes the best way to spend time.
Dave
/ Ashes to Ashes, Dust to Dust. . . #13
Good going, jinman. :thumbsup: Intermittent electrical problems are the hardest things to trouble shoot and having the relay actually go into total failure mode turned out to be a blessing in disguise.
/ Ashes to Ashes, Dust to Dust. . . #14
Good job Jim. Intermitent problems are a nightmare to figure out. Now why don't you tell us what the project is that you bought the new toy I mean tractor for.
Bill
Bill
Thanks Bill, Mace, and Dave. I have always been a hardhead when it comes to troubleshooting. I think persistence may be my crowning quality.:D
Bill, in the projects forum, I have a thread called "The gully to pond project." I'm turning a few gullies on my property into ponds. It's about the only thing this part of my property will ever do well. I bought the TLB because of it's flexibility for digging, moving, and finishing. Of course, I'll do the fine work with my TC45D. It's a long-term retirement project that should keep me out of trouble and out of my wife's hair.;)
/ Ashes to Ashes, Dust to Dust. . . #16
It makes me wonder if the tractor has been sandblasted and re-painted at some point. Auctions such as Ritchie Brothers sand blast, paint and decal most of the equipment that runs across their sale ramps. We have a big RB auction facility a few miles from here. Of course only speculation on my part, and probably not a bad thing..... But I would like to know if I was buying a repainted unit. #justsayin
Good luck, and great job with diagnosing your problem.
Dean
/ Ashes to Ashes, Dust to Dust. . . #17
This reminds me of what we would find in fuse boxes of cars that had been underwater. I worked at an auto salvage yard over a summer in high school, and they got a truck load of cars that had been underwater because of a flood, and there was fine dirt in every orifice of everything. It was in the intakes the air filter, the fuse boxes, the cup holders. Was this tractor ever under water?
There's no indication of that in other electrical panels at or below the same level as this relay. However, pressure washing at the dealership was done over two days and I got the impression that the engine covers were left off during the time the loader arms, undercarriage, and all other parts were being cleaned. I think sand and dirt goes in and washes down the firewall. Since the relay was upright, all that stuff washed over the top of it. Even the relay socket was a bit corroded, but not really full of sand because the relay was an "umbrella" for it. The main fuse has a hooded cover, so it was free of sediment too. Only this relay seems to be affected.
Also, this is a 2005 model tractor and all the paint is original. It's obvious it has never been repainted nor sand blasted, but I don't know for sure that the pressure washer didn't have grit injection for cleaning. I have a friend with a washer that uses grit for cleaning concrete parking lots and removing paint, but I doubt the tractor dealer would use one of those. If so, I'd expect them to have constant problems with sand in alternators, starters, and many other places you don't want sand around a diesel engine. The sand does look like fine sandblasting sand though.
Hot diggity dog! My new relay arrived by UPS from Grainger yesterday. My starting problems are over. Woohoo!:D:D:D
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2013 John Deere 2623VT Vertical Tillage Tool (A63116)
2013 John Deere...
2016 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2016 MACK CXU613...
2009 CPS Manac SGH36 Hopper Bottom (A64047)
2009 CPS Manac...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
