Water Line problems. Ideas?
/ Water Line problems. Ideas? #1
rutwad
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
My friend has approx 1/2 mile of water line from the main to his house. 2" Sch 40 pipe was used. The soil here is absolutely terrible! Prairie mud/gumbo. Yet when it's dry, it draws up leaving cracks everywhere. He has had multiple leaks with his water line and I am not sure if it has to do primarily with the soil it is in. Surely there is a good way to lay water lines even in this nasty stuff.
What about 2" slip-joint PVC?
What about 500' rolls of poly%^#$%^ tubing?
Anybody ever had to deal with this? Looking for ideas.
/ Water Line problems. Ideas? #2
At our plant we had installed by a contractor the longest underwater pipe at 1.5 miles within our 11 foot intake pipe. We have bundles of 3" and 4" pipes. Schedule 120 poly welded. There has been breaks.
In your case I would install it in a 4" big O drain pipe to allow for the seasonal wet dry cycles that could be pulling the pipes apart. Also if you trench it in at 3' maybe the soil will be a bit more stable.
Craig Clayton
/ Water Line problems. Ideas? #3
You don't say if the sch 40 is plastic or stee or where or how it is failing. I installed a little over a 1 1/2 miles of 4" bell and socket plastic water line a few years back. I am sure it was heavier than sch 40. I rented a Ditch Witch R100 trencher and buried it 4' deep. Nothing like sticking a semi load of pipe in the ground where it will never be seen again. Very simple to install. You lubricate the bell end with the special lube and a tolit mop brush, slip the ends together then lower it in to the trench. If you must make a 90 degree turn you have to block the ends so it won't blow apart and block the very end so it won't blow apart.
You need to keep the trench bottom as flat as you can to avoid dips where the pipe gets pushed down and strains the rest of the run. Our soil has no rocks so I didn't have to deal with that and my area is flat as a table top so did not have to cross any ditches or creeks.
Dan
Is's Sch 40 PVC glue joint pipe. The terrain is undulating with probably a 75' max difference total.
Burying at 4' scares me b/c you may have a leak for a very long time b4 you know it, then there comes the problem of locating and fixing it.
I guess the bell and socket is the same as the slip-joint I was referring to. Gasket in the bell gets a little grease, then push/bump the other end in. And yes it too will blow out of the ground if not covered! Do you think the joints may slip enough to compensate for any movement from the soil?
I think a pressure regulator may help too. After 1/2 mile of pipe, he has 100 psi including leaks!!!
/ Water Line problems. Ideas? #5
Soil movement is the cause of most pipe failure, and it's inablity to move with soil. Drying and cracking is one movement, but getting wet and freezing is when most of your damage will happen. That's a very quick movement in the soil, and also, a very powerful movement.
Most water utilities use gasketed water pipe. You just grease the ends and push them together. This allows the pipe to move in small amounts with the soil around it.
Poly pipe is famous for failing. It was an idea that was tried and failed. Lots of guys use it for their well systems, and home use, but it's one of those things that you just never know when it's going to go bad on you. From what I understand, the Water Utilities have quite usining it a decade ago, and are now running crews full time to deal with the never ending repairs on what they did use.
In CA, where I'm from, we had to surround the water lines with sand. The pipe had to lay on a bed of sand, and then sand was put in over top of it. The pipe had to have sand all the way around it for so many inches. I forget the number, and it varied with location, size of the pipe and if it was a puplic water line or private.
When the earth moves, the sand allows the pipe to remain in place. It also protects it from rocks that might be in the ground, that may wear on the pipe over time. I've never seen rock damage, or met anybody in person who has, but it's a concern that you might have.
As for the advice to enclose it in another larger pipe. I would not do that. Water preasure changes all the time. There are surges that will flex a pipe that will allow it to move if it's not solid in the ground. If the pipe can move around inside another pipe, it will never stop moving. Even worse, when it does break, how will you know where to look for the break?
Good luck,
Eddie
The owner seems to think that 1" black roll pipe is the answer. So would it be possible to dig up the 2" PVC water line approx every 450' and not even worry if it rips out a joint or two of pipe. Then with mouse, string, rope, followed by sock (think Chinese finger cuffs), feed the 500' through the 2" pipe. Then use the excavated areas for coupling the 500' rolls together and coving back with dirt. This would also allow a leak to present itself since the coupling area would not be sleeved in the 2" PVC.
CRAZY IDEA, BUT WHO KNOWS..........
Eddie, I missed your reply while I was typing my last one. But based on several peoples advice, it sounds like the slip-joint pipe is the way to go.
/ Water Line problems. Ideas? #8
I would use poly and if he could size it right he may be able to just shove it thru the old pipe and have very little digging but that's just a guess I try to figure out easy ways to do things.
edit;Oh I just found your post where he had already thought of that well there are 2 votes!
/ Water Line problems. Ideas? #9
If you have poor soil conditions which move a lot you need to replace that soil with sand which was suggested in a earlier post. Some place even require some gravel to allow water to drain from around the pipes. You local building departement should be able to tell you what works, but that may bring other questions from them that you do not want. Permitting, inspections, etc.
/ Water Line problems. Ideas? #10
There are several kinds of " poly " some is junk others are very good. I have repaired the bad and installed the good. I have poly pipe that has been in the ground for 25 years and never a problem. The pressure you describe is an issue. The pipe, no matter what you use, must be rated for that kind of pressure. PEX is one of the better poly. The cities in my area have used and still use, a blue poly for water services. They love it.
/ Water Line problems. Ideas? #11
Yes if you bed the pipe that will help, maybe pea gravel or sand. Around here we bury everything 4.5' deep, but we worry about it frezzing.
/ Water Line problems. Ideas? #12
Good luck,
Eddie
Once again, Eddie has some good advice above. The company I work for is a general engineering contractor specializing in the install of wet utilities in California. Rubber gasketed is preferred when there is concern of pipe movement. Actually, that is essentially all we see used 4" and larger in size. At 4" and up it usually changes from Sch 40 or 80 to a C900 spec which is rubber gasketed bell and spigot. That is what I used on a fire line at my house. The typical standard with this pipe is sand bedding (4" below bottom of pipe) and shading (to 12" above pipe). As was also mentioned, you need to either install thrust blocks at bends, end of line, and valves to restrict movement due to water hammering. They also make mechanical restraints for the joints, but the thrust blocks usually is cheaper to install. When we do need to install long smaller diameter pvc glued joint pipe, it seems to prevent leaks by installing in an 18"-24" wide trench and "snaking" the pipe back and forth to allow some slack for the pipe. We have also had luck with troublesome sch 40 fittings by replacing with sch 80 and using sand paper to scuff the outside of pipe/inside of fitting prior to gluing.
Matt
HOLY SMOKES!!!! That much sand could get expensive!!
/ Water Line problems. Ideas? #14
If you bed it with sand call your local ready mix plant and have them bring it in a concrete truck, they can unload it and drive at the same time and save you a boatload of time in spreading it in the trench.
/ Water Line problems. Ideas? #15
Go Sand.
I am on the black land prarrie with the same type of clay soil--technically it has a "high plasticity rating" and with the same situation--approx .75 miles from the meter to the house of schedule 40 pvc pipe.
When the p[revious owner did the pip in 1999 or 2000...he bedded the pipe in ~ 8-12 inches of sand all round (top, bottom, sides).
In that time we have had exactly 1 leak on the main line and it was from a joint that looked like it was improperly done.
On the other water lines (3/4 inch sch 40) that branch off of the main line, if they are not bedded in sand, they eventually leak (I have one now for the line to the barn that is getting fixed tomorrow :mad:), if they are bedded in sand, I have not had a problem.
/ Water Line problems. Ideas? #16
I used 1.25" polyethelene pipe to run 650' of underground water line at my last house. I ordered it in a continuous roll so there were no underground joints. It was black and rated for 180psi. It came sealed and pressurized. After laying it in the trench and backfilling it is very reassuring to hear the pressure come rushing out as I cut into it. It was fast to install and worked great.
I did some work for a chuch that used regular schedule 40 pvc for a 500' run. They would have a problem every 2-3 years with a leak in that water line.
/ Water Line problems. Ideas? #17
There was a product called Golden Jet way back when I worked on submersible pumps. It was rated at 200 PSI. We hung 3hp pumps 400' deep on it. It really took a beating. I don't ever remember a failure. It was always a relief to see that pump come out of the hole when you pulled the pipe over a big wheel out of the hole. A big splash would mean big bucks down the hole.
1996 CATERPILLAR D6E CRAWLER DOZER (A62129)
1996 CATERPILLAR...
New/Unused Two Wheeled Electric Bike (A61166)
New/Unused Two...
Traffic Safety Cones (A61567)
Traffic Safety...
2025 LandHonor ABC-13-125A 42in Articulating Brush Cutter Skid Steer Attachment (A60352)
2025 LandHonor...
2019 John Deere R-4038 (A61306)
2019 John Deere...
2014 F-150 STX (A56438)
2014 F-150 STX...
