Box Blade Choice
/ Box Blade Choice #1
kfin
Central, MO
YM2310D
We are just about to finish our house and it comes with a 1/4 mile gravel driveway that needs to be maintained. I will also use it to keep a 1/3 mile dirt road at the farm operable a time or two a year. That will about be the extent of it useage.
I have a Yanmar 2310D to use. Probably going to get a 5' model. King Kutter is available locally, also looking at the United 560HD. What do you guys think? Some other brand.....one better than the other?
Thanks,
Keith
/ Box Blade Choice #2
That is one thing I bought my compact for was to maintain my 3/4 mile DR. I just bought a BB that was the same width as my rear wheels. Make it easier not to catch it on anything your getting close to. I have seen the KK at tractor supply and is made as well if not better then mine. Which I don't use much now that I have all the problem areas worked out.
carey
/ Box Blade Choice #3
I have the United 560 on my Kubota L3400 and have been very pleased with it. I like the fact that the 3 pt. pins are supported on both ends... seems to be stronger. I did find that I had to add weight to it to perform optimally, but that was easy to do since I had a couple of extra forks that strapped nicely on top of the boxblade... added about 200 lbs.
/ Box Blade Choice #4
I have a tc-30 New Holland with a 5ft. box blade.I wish it was about 6"wider so it would clear my tires bu a few inches so when I make a"cut" It would cut straight with ought riding up on the not cut ground. That would keep the tractor level.Dont get me wrong it will work for you, but a few inches to clear will be of benefit.
Army Grunt
Where about in N/east Ga.?
/ Box Blade Choice #5
I prefer close to the same mine is still a few inches bigger. If I had problems with the BB being to small easy fix for me I just reverse my rear tires back.:cool:
Army grunt. I'm in Walton Co. about 20 miles from Athens.
Carey
/ Box Blade Choice #6
Keep in mind that weight is your friend when grading. So I would be looking for the heaviest one that I could find that is the width that you want.
My Mahindra 3215 is about 60" wide, but I went with a 66" wide roll over box blade and am very happy with it. :thumbsup:
/ Box Blade Choice #7
I have a Gannon 54" rollover that I'm in love with. Not sure they even make the 54" any more.
/ Box Blade Choice #8
I also have a United 560hd it is very heavy duty.
/ Box Blade Choice #9
My rollover is a Gannon also.:thumbsup: Sadly :( when Woods shut down the Gannon factory in California last year, they also discontinued the manufacturing of their rollover box blades. We also have a 36" Gannon rollover for our Sears garden tractor. There are other companies that still make them, just not Gannon-Woods. :(
/ Box Blade Choice #10
Tractor Suppply Co. has a 5' box blade for a very good price. Does anyone have one? Can you tell me what the weight is? I am very interested in a box blade for a counterweight; the Bush Hog is too bulky!
/ Box Blade Choice #12
its a king kutter or county line. My guess is the 5 fter is in the 300-350 range. I have a cheap Atlas brand i bought used for $200 is has ripper shanks and all. It will stop my tractor if sunk to deep in grass or hits a root adn wont bend, of course im not running 9-10 mph using it either. The only down side of this is that it does not have a replaceable cutting edge, i gues i could either bolt or weld a new one up if needed. But i only use it to maybe bust up a field everynow and then to reworked my gravel at the house and tried to fill a mudhole in on my woods road (did not work but i was in to much of a hurry to fool with it). Mine weighs around 200 and is classified as lightweight, but like i said it will stop my tracotor and not bend, but i do need to add weight to it to get it to cut or stay in the ground well.
/ Box Blade Choice #13
there is a 5 ft'r at the local salvage/scrap yard here in Braselton Ga, can be purchased for the cost of weight, I think is 39 cents pound,
although looks to be a heavy built one with the cutting blade on the backside as well as the inside,I think i remeber seeing 4 scarifiers, not sure of the make.... if I were guessing the weight I'd guess over 350-400 lbs... estimate costing 140-175
/ Box Blade Choice #14
dang deep, you need to grab that thing. I got one but at that price i might think of selling mine and trading up.
/ Box Blade Choice #16
if he still has it tomorrow I'll go take a picture of it and send it over to you just to see if you would be interested? if so I could proly talk him into holding it a day or so for you, I really have no use for another box, plus as i said it looks heavy built and remember my tractor barely pushing 20 Hp. I would say take 25+ Hp for this thing, but if your interested;)
I'm still looking for the tillers :thumbsup:
/ Box Blade Choice #17
I did not know who manufactured mine it just has a serial number with no name. Curiousity was getting to me so I did some checking on it. I bought it from Spalding and sure enough it looks Identical to the Lowery from KY. that Fredricks sells. I was pretty sure thats who it came from. Picked it up with the YM2000. It's been over 3yrs and the only thing I've had to do to it was put a weld back on a Scarifier Tip. I knocked Loose when I got it caught on a root. I would say he gave me a good deal on it for 300.00 new.
carey
/ Box Blade Choice #18
Stormpetrel,
Here's one from Tractor Supply, I plan on leaving it on for the winter.....
/ Box Blade Choice #19
Stormpetrel,
That is a nice looking rig for the money!! There's still a deep hole in my wallet where all the money I spent on my grapple used to be.......I don't know how soon it will be before I can afford it. Then again, there's a new TSC opening close to me, and they're having a 10% off sale this Saturday. Hmmmm.:eek:
/ Box Blade Choice #20
This one IIRC was $539. , 60" wide.....
Unused 2024 Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024 Land...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
2012 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2012 INTERNATIONAL...
2018 Nissan Frontier Ext. Cab Pickup Truck (A66736)
2018 Nissan...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2012 GORILLA BUILT MANIFOLD TRAILER (A67714)
2012 GORILLA BUILT...
