Oil & Fuel hydrolic fluid
   / hydrolic fluid #11
wow.. when did they change this?
I'm surprised they did not change the oil name to prevent confusion.
I remember when the multi g came out I saw a m2c134d spec on it.
still ambra?
soundguy
   / hydrolic fluid #12
is the multi g no longer a M2c134d spec oil?
soundguy
still ambra?
soundguy
M2C134 is a Ford Specification.
Ford no longer owns New Holland, CNH/Fiat owns New Holland.
Why would NH use a Ford specification?
Multi-G 134 is now NH Spec 410B.
Thanks Jinman...
If you want an oil to be compatible with your New Holland tractor look
for NH 410B. The old Ford spec might or might not work, they may
change that spec and it may not in the future, it may not now. Ford
no longer worries if it meets the needs of tractor users as they do not sell
tractors any more. New Holland owns the 410B specification and they
do care if it works in their tractors.
   / hydrolic fluid #13
NH has been using the m2c134d spec for a long time..
soundguy
   / hydrolic fluid #14
Fellows, here's a photo that goes a long way to explain this whole confusing issue. It's a bucket of Ambra Multi G 134, and below that label you can clearly see in lighter print "NH410B.". I think NH must post the spec as the type of oil because my LB75B TLB Owner's Manual says NH Spec 410B oil with no mention of Multi-G 134 anywhere whatsoever, but I've never seen a label that prominently displayed Spec 410B. I think the new Multi-G 134 reflects the multi-grade 10W30 nature of the oil and its use for much more than just hydraulic or HST oil. It's also a fine multi-season lubricant and can actually leak into the engine without doing any damage as several people have had happen here. It may not be the best engine oil, but it won't hurt a thing for a short time.
imageview.aspx
   / hydrolic fluid #15
sounds like this was an update of the '134' spec, as even the name mentions `134'
cnh must have finally got tired of using an old spec / named oil.
soundguy
   / hydrolic fluid #16
hey now here's a question.
I remember there was a cold weather hydro oil. they still got that.. or does the new ambra multi cover that? if so.. nice deal... i'm so outta the loop on the new stuff.. :) give me an 00 or 01 series row crop and I'm at home.. :)
soundguy
   / hydrolic fluid #17
This has been the source of confusion with NH since Fiat showed up. Traditionally, North American (NA) Ford used M2xxxx oils, that was their spec numbers, be it a tractor, auto or truck. European Fords used other numbering. Ambra is Fiat's oil. That's why they use Ambra 134. They combined the Fiat/Ford names.
When the Fiat based machines showed up ( TN, TL, LB, LW), the owners manuals were calling for 410B oil, the brake oil had different numbers, the only ones that could be figured out was the engine oils. Now that Case/IH is in the mix, and more cross branding, there's more confusion. NH has a chart showing the NH/Ford, Fiat, Case/IH, Sae and Mil specs, along with current part numbers.
Long story short, NH410B is multi G 134 which is M2C 134D.
The cold weather substitute for 134 is F200.
   / hydrolic fluid #18
I think it is interesting to note on the pail of Multi-G 134 above that it says "Transmission Oil" instead of hydraulic oil. It seems the better grade of oils by all manufacturers specify that they are acceptable for transmissions as well as hydraulic systems.
Just for fun, I scanned the lubrication spec sheet for my NH LB75.B TLB. There are plenty of specs to "chase" on this page. :D
   / hydrolic fluid #19
soundguy
Wasn't the 4610 perfect? :^)
   / hydrolic fluid #20
the 10 series is still kinda new for me too.. it's 80's stuff :)
soundguy
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
2019 Caterpillar 249D Compact Track Loader Skid Steer (A55973)
2019 Caterpillar...
Tool King 12-Ton Hydraulic Pipe Bender (A59076)
Tool King 12-Ton...
JOHN DEERE 2155 TRACTOR (A52708)
JOHN DEERE 2155...
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
2017 John Deere 35G Mini Excavator (A55973)
2017 John Deere...
