hydraulic line pressure
/ hydraulic line pressure #1
lakespirit
Idaho Panhandle
2004 KAMA TS254C
It seems my Koyker 140 loader doesn't have enough pressure to raise the bucket. Is there an adjustment to increse pressure?
/ hydraulic line pressure #2
if it is as cold as you said wouldnt that be the problem?
did you let it warm up plenty?
I run ATF in my system, expensive, but does not gel, or even thicken well below zero. I was running earlier in the day and the loader was operating OK. Do you have any other thoughts?
/ hydraulic line pressure #4
If you have QD's (quick disconnects) unhook and rehook. One may be slightly offseated.
/ hydraulic line pressure #6
ATF is not recommended in Chinese tractors, it can decompose seals and gaskets. You may have clogged the hydraulic filter. It's in that horizontal cylinder looking thing on the left side of the hydraulic sump
//greg//
OK, so which Hyd fluid should I use? AW32, or something even less viscous for my weather?
Any way to increase presuure?
/ hydraulic line pressure #8
Well, apparently you didn't read http://www.mehf.com/FLasia01muladvantages.pdf because you would have picked up on using the multi-vis hydraulic oil. It outperforms the monograde oils, particularly in cold climates. Your weather is not exceptional by comparison. When you chose a hydraulic oil, make sure it is labled AW Hydraulic Oil and not AW Machine Oil, R&O Oil, etc. Give it a chance to warm up before you use it.
You state that you want to increase pressure. What is your current pressure that you wish to exceed? Do you know that by increasing pressure you can take your FEL beyond design limits and break something - including yourself?
Well, I did read it, but didn't see any recommendation for a multi-vis AW hyd oil. I have never seen multi-vis hyd oil. In days past 15w/40 oil was used in most all applications in the gold mines of NV where it's cold.
/ hydraulic line pressure #11
Well, start by draining the ATF and opening the filter housing. There will be a screen-wrapped cylinder inside. Remove the screen to reveal the cylinder. It's magnetic, so clean it well with diesel fuel and a toothbrush. The screen will not likely be reusable, you should have some replacement material on hand. I use 80x80 brass mesh on mine, and have plenty extra if you can't find it locally.
Multi-vis hydraulic fluid is ok, just not readily available in all areas yet. Certainly not around here anyway, and your area sounds even more remote. But yes, AW32 is plenty thin for your use, it's got a viscosity equivalency to 10W engine oil.
//greg//
2020 PETERBILT 567 (A60736)
2020 PETERBILT 567...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
2020 CATERPILLAR 262D3 SKID STEER (A62129)
2020 CATERPILLAR...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A60352)
2017 Gravely...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
