JD 4005 ?
/ JD 4005 ? #1
wbyman
Member
I am thinking about buying a new JD 4005 with fwd [replaced the JD 990] for 25 acres of food plots , just wanted some opinions on this tractor. I have a NH tc29 fwd now.
/ JD 4005 ? #2
Have you looked at or considered a 5055E? Should cost about 25% more than the 4005 but would be much better suited for 25 acres of tillage. I would hesitate moving from a 2500 lb tractor to a 2900 lb tractor, these small incremental upgrades are very costly. Are you planning to reuse the smaller implements and is this the reason for the slight upgrade in tractor size?
/ JD 4005 ?
Yep, I will use the same equipment, the tractor I have now works OK just want something a little bigger and new. Lots of JD dealers in my area.
/ JD 4005 ? #4
Your TC is Hydro correct? You want go to a gear machine?
/ JD 4005 ?
Nope , 9x3. , perfect tranny for food plots and that is the only time it leaves the shed.
/ JD 4005 ? #6
Yep, 9x3...but that's still a gear tractor (as opposed to HST). Good machine and probably well suited to your tasks.
/ JD 4005 ? #7
I think that would be a very dependable, basic, tractor for your needs.
Reliable is another word that comes to mind.
Relatively affordable, too.
:thumbsup:
/ JD 4005 ? #8
Just dropped the hammer on a new 4005. Great value for the $$. Going to pick it up this weekend!
/ JD 4005 ? #9
Great, don't forget to post some pics.:thumbsup:
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2018 Ford F-150...
2017 Ram 3500 9ft Flatbed Truck (A61568)
2017 Ram 3500 9ft...
10ft Bush Hog Rotary Cutter (A61166)
10ft Bush Hog...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A62131)
UNUSED WOLVERINE...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
(APPROX.20) UNUSED RAYSKY GROUND PROTECTION MATS (A62131)
(APPROX.20) UNUSED...
