>> AGCO 15W-40 OIL ??
   / >> AGCO 15W-40 OIL ?? #11
Warren is the Company that makes the TSC Travelers and the Walmart Supertech stuff. I had a long conversation with one of the techs couple weeks ago. He was a really nice guy. He told me that the difference between agco Hydro oil and Travelers is the Agco puts a fragrance in it. (i'm sure it cost more too). He also said they have about 40% of the market in non big name oils. The biggest difference between them and the big names is they don't pay racers and charge the sponsorship cost onto you and I.
   / >> AGCO 15W-40 OIL ?? #12
Have you ever seen a VOA from these above oil's packaged by WPP for the house brands of WM or TSC?? it's nothing to be proud of believe me,,or not...
way better oil's out there...
   / >> AGCO 15W-40 OIL ?? #14
So in other words, its all the same, different company propaganda.
   / >> AGCO 15W-40 OIL ?? #15
What's the VOA mean?
Virgin oil analisis...a small oil sample you send into a lab
it shows the compound make up of an oil,additives,acid neutralizing property's,viscosity at given temps,etc,etc..
   / >> AGCO 15W-40 OIL ?? #16
The 5w-40 oil will be picked up by the oil pump quicker on startup than the 15w-40 oil. BOTH oils will be more viscous on startup than in operation.
Getting oil to the upper valve train on startup is one of the main reasons why synthetic oil almost eliminates the wear up there but also gives more fuel economy and hp.
I use a 0w30 in all my engines now: 2 diesels, 4 gas.
Ralph
On engines with horizontal mounted oil filters, that same thin at cold temp 0w, or 5w oil will can leak back through the anti drain back seal of the filter.This can offset some of the perceived advantage of the quicker flow at startup. I know 15w can also do the same but at a slower rate once the engine cools down.
   / >> AGCO 15W-40 OIL ?? #17
I thought for sure one of the site's oil experts would challange me on my last post. Where's the spunk?
   / >> AGCO 15W-40 OIL ?? #18
Gee... I guess no is aware of filter drainback on horizontal applications.:confused:
2009 GMC C8500 Altec DM47 47ft Insulated Digger Derrick Truck (A55852)
2009 GMC C8500...
(41) T-POSTS W/ (20) ROLLS OF BARBED WIRE (A54757)
(41) T-POSTS W/...
401 (A52706)
401 (A52706)
CHAMPION C80C MOTOR GRADER (A52707)
CHAMPION C80C...
Native American Wooden Statue (A55853)
Native American...
