Snow Blade I picked up a piece of truck retread...now what?
   / I picked up a piece of truck retread...now what? #1
D33r3 6r33N
Logan County, OH
John Deere 2305, Scag 19hp 48" Tiger Cub
I found a sweet piece if semi truck retread on my way to work today. I figured I could mount it on the bottom of the cutting edge of my snow blade, the question is...How do I cut it? I was thinking sawzall because of the steel belting, but what do you guys think?
   / I picked up a piece of truck retread...now what? #2
Sawzall will cut tread,maybe less teeth blade so it won't gum up..one end of thread in vice and lightly pull the other end while cutting.
   / I picked up a piece of truck retread...now what? #3
Zip cut, you're going to have to keep the cut open as you move along gonna be a tad smokey tho. Don't think a sawzall will cut the wire, it'll just catch the teeth and vibrate.....Mike
   / I picked up a piece of truck retread...now what? #4
I did this 2 years ago and it works nicely for my purposes - I have grass, gravel and blacktop areas that I need to clear without ripping them up. I used a reciprocating saw (Milwaukee) with a hacksaw blade. It cut like buddah. You will need to get longer plow bolts to put the cutting edge back on. Measure the tread thickness and add that to the length of your present bolts. Luckily a local hardware store had some in stock. I used a brace & bit to cut the bolt holes, which worked surprisingly well.
Good luck & tell us how it goes ...
-Jim
   / I picked up a piece of truck retread...now what? #5
Jig saw will work but U need to lube to prevent binding.
WD-40 makes good lube as will liquid soap.
I have also used sharp box cutters with a helper pulling sideways.
Forget using a skill saw, it binds.
The recap would not have the wire as that is in the carcass, so you should be OK.
   / I picked up a piece of truck retread...now what? #6
I use the sawzall and vice method already mentioned. It takes some time but is the best I have found. I cut them down to use for the rubber edge on my plow wings for my truck mount plow.
Another good use for re-tread is for a dnow deflector across the top IF you have a truck plow. Tractors dont really go fast enough to benifit though.
   / I picked up a piece of truck retread...now what? #7
i find that the hacksaw blades work the best they cut wood a little slower but they go threw nails a thousand times better i always wanted to know how to work tires
   / I picked up a piece of truck retread...now what? #8
If it is, in fact, the recap, no wire to cut, as you say. However, most of what you see along the road that lots of people think is recap is actually the original tread and carcass; not a recap at all.
Error
Well I guess I was wrong in my OP does have the wire.
Another question does it matter which way I put mount it to the blade? Tread in or tread out?
LIGHT TOWER (A56857)
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
2018 John Deere 1653 (A56436)
2018 John Deere...
2018 RoGator 1100C (A56436)
2018 RoGator 1100C...
2019 TerraGator 7300 Spinner truck (A56436)
2019 TerraGator...
2014 Ford Fusion AWD Sedan (A56859)
2014 Ford Fusion...
