KIOTI DK35 CLUTCH PROBLEMS
/ KIOTI DK35 CLUTCH PROBLEMS #1
klinger48
I have a 2004 dk35 and the clutch pedal is not engaging the clutch. As I was operating the tractor I felt a snap in the pedal and the pedal no longer engages or disengages the clutch. The actual clutch is fairly new and it was not slipping before this occurred. I checked the linkage and it all appears to be operating up into the clutch housing. Does anyone know what the problem may be?
This tractor has been great but the nearest dealer is far away so I have decided to start doing the repairs in house.
/ KIOTI DK35 CLUTCH PROBLEMS #2
Sounds like something in linkage broke or a pin came out. Have you found anything yet?
Loren
Yes, a dealer responded via email and ran down what the problems could be. For now I am going to start pulling the tractor apart and when I know exactly what went wrong I will post it. Thanks
The dealer mentioned that I may want to go ahead and replace the clutch assembly while the tractor is apart. does anyone know if maybe I can have the clutch plates rebuilt?
Are there after market parts available for Kioti tractors.. I can find any.
/ KIOTI DK35 CLUTCH PROBLEMS #7
Yeah, they are correct. The cost / effort to split a machine is greater than the cost of the clutch parts.
I would guess that the pressure plate fingers broke. You mentioned that the clutch was fairly new, is it a replacement ? Being a 2004 that machine shouldn't need a new clutch. I would expect 4-6000 hours out of a clutch, unless it's on a loader tractor. Then cut it in half or less. If it's a replacement by a prior owner, they may have just put in a new or rebuilt disc and left in the old PP. Common method of shady characters.
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
2022 EZ-GO ELITE...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
2015 Ford C-Max Hatchback (A61574)
2015 Ford C-Max...
Danuser 3pt Auger (A64119)
Danuser 3pt Auger...
