BX Quick disconnect problem on snowblower
/ BX Quick disconnect problem on snowblower #21
What a dumb *****! All the way right on the stick. I had no idea that was even there. Thanks to all. It works and I feel stupid. You guys are great.
Thanks again
Jim
Don't feel dumb. I had my B3030 several months before I discovered the float position on the loader valve.
/ BX Quick disconnect problem on snowblower #22
Thanks again
Jim
:thumbsup:
/ BX Quick disconnect problem on snowblower #23
Thanks for this thread.................the exact same thing happened to me yesterday when I put my blower on my BX2350:laughing:
/ BX Quick disconnect problem on snowblower #24
Spoke to soon..................went out and tried that..........I still found the shoot rotator will only go 1 way. If I reverse the lines it will go the other direction. If I use the 2 outer connections that is used to lift & lower the snowblower it will turn in both directions. Yet if I hook up the loader it works like it should..........Pretty weird
/ BX Quick disconnect problem on snowblower #25
/ BX Quick disconnect problem on snowblower #26
First time posting here. This topic has me wondering about my current project. I wasn't going to buy the factory snow plow so I have been adapting a ATV plow to run off of the loader valve. I am using single acting cylinders for the angle motion and was under the belief that I would be OK as long as I pushed the loaded valve past the detent. If someone can clarify it would be appreciated. I hope as soon as the paint dries on my plow mount I will be hooking up the hoses to try it this week. I have learned a bunch from this forum the last 6 months. Thanks
/ BX Quick disconnect problem on snowblower #27
Welcome to TBN:D
If you have a newer 'bota, you should be fine. Some of the older ones came with the "3-way" valve, but all the new ones have the 4-way.
/ BX Quick disconnect problem on snowblower #28
What tractor? Read my reply to Scott...
/ BX Quick disconnect problem on snowblower #29
Thanks Kennyd. I have a BX2360 purchased in the spring of this year. after I get my hoses hooked up I will report back.
/ BX Quick disconnect problem on snowblower #31
Hi Kenny...........I have a BX2350
I did push the lever to the far right
Are you sure you pushed it far enough? It works for everybody else. You can try to lube up the joystick linkages.
JOHN DEERE 544K (A67714)
JOHN DEERE 544K...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
2014 FORD F-150 (A67714)
2014 FORD F-150...
2023 Polaris Ranger 4x4 Gas Utility Cart (A66734)
2023 Polaris...
2019 FOREST RIVER WILDWOOD (A67714)
2019 FOREST RIVER...
CULVERTS / PIPE STAND (A68842)
CULVERTS / PIPE...
