Snowblower use question
/ Snowblower use question #1
jrogers
Anchorage, AK
Kubota 2630HSD
Hello,
We just got our first real snow, and I have some questions on my snowblower. It is a 63" two stange front mount on a B2630.
We are building a house, so it is currently a new gravel driveway. In preperation for this, I changed the skids to put the blower in it's highest position. Do you think it is reasonable to use the blower this year, or an I just going to be breaking things? The first bit of plowing I hit something and sheared a auger bolt and broke the chain. To finish the job, I just pushed the snow with the blower and was careful not to go up against anything hard (don't want to damage the auger). This seemed to work fine. Do you think it is OK to do this on the section where there are bigger rocks and blow the rest, or should I just switch back to the FEL for the winter. The driveway is pretty big. I would really like to use the blower if I can do it without wrecking it. I wish I would have take an hour to clear all the loose rocks before it snowed, but too late now. Another option would be to buy a snow blade for it, I am going to see what this costs. The driveway is around 600', with a large parking area.
Suggestions?
/ Snowblower use question #2
Hello,
Suggestions?
If you don't have a lot of freeze/thaw cycle, I would suggest you blow with the blower up a few inches above the driveway, and then when that snow freezes and packs down, you would be able to lower the blower to the snow pack.
The other option that you could do is put a rear blade on the back and push the snow with that, and keep the blower in the front. I use a rear blade for my 600' stone driveway and although it isn't great, it does the job just fine.
/ Snowblower use question #3
After the first one or two (hopefully) small snowfalls, we'll intentionally drive over the entire driveway - ditch to ditch - without clearing any of the snow. The idea is to lock down the gravel with this layer of hardened snow/ice then clear the subsequent snow from this bottom layer.
/ Snowblower use question #4
I snow blow on a gravel driveway with a similar blower, but there are no rocks bigger than 3/4 inch so it doesnt seem to bother it. I have broken auger shear bolts on tennis ball sized rocks that I "found" in the road around my mailbox, but they are few and far between.
If you driveway is covered with larger rocks, you might want to pack the first couple inches of snow down until you get a good base to snow blow off of.
/ Snowblower use question #5
back blades work very well for removing snow as long as its not too deep.
/ Snowblower use question #6
I allways let some snow pack in and make sure the ground is froze. Everyone around here that has blowers have gravel drives, no real issues that I know of. If the ground isn't froze and you get a fair snow accumulation you could allways just use a back blade for the 1st couple of plowings until you have a smoother base.
/ Snowblower use question #7
I think you answered your own question when you said you broke the chain and a shear bolt. I would use the FEL or a back blade for the first year until you get the issues of larger rocks from driveway. Then of course the blower would be the way to go.
DevilDog
/ Snowblower use question #8
When you remove the large rocks from driveway you snow blower will work just like this. A breeze to blow when there are no rocks or items to break blower.:thumbsup:
DevilDog
/ Snowblower use question #9
Suggestions?
You obviously didn't prep your driveway. There shouldn't have been a rock there to break your blower. You can't just let things "fall as they may" - you can get away with a lot more trash using a plow, but with a blower, you have to make sure that large rocks, tree branches, the Sunday Globe, etc. are cleared off of your drive, and the areas immediately next to it BEFORE it snows.
In any case, once you get the cleared area established, with a good cut and a frozen driveway surface, you won't have any more problems. Clean up before the snow flys next year.
JayC
/ Snowblower use question #10
If you don't mind spending the money you can always buy (or rent) a landscape rake and go over your driveway with it. I'm assuming that the ground isn't frozen yet so even with the snow it should still remove the larger rocks for you.
/ Snowblower use question #11
This is one of those cases where I would not use float on the blower. If the stones are not frozen to the base yet, I would just use the lift to bring it up off the ground even if the skid shoes are no longer touching. Stones beat the heck out of the chute too and can dent the angle deflector. It is not considered "normal" to break shear pins and my local dealer is amazed at how many he sells each season. I'm surprised to hear the chain broke as well as the pin, as that kinda defeats the purpose of the pin...
/ Snowblower use question #12
I used the blower on gravel for years (it's paved now). I would go through at least a dozen shear bolts per season, but never broke anything else. It got better after the first year or two as the gravel packed. I always used float on the blower and kept the skids at the highest setting. After the first season, I made my own shear bolts. Home Depot stock and cut the grooves on a lathe. Much, much cheaper.
paul
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2001 FREIGHTLINER FLD120 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2001 FREIGHTLINER...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
2007 30ft. Regal 30 Express Cruiser Boat with 2010 Vantage T/A 33 Ft. Trailer (A64557)
2007 30ft. Regal...
2023 Chevrolet Express 2500 Cargo Van (A61573)
2023 Chevrolet...
2017 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A64556)
2017 Ford F-550...
