8n 1952 weak spark
/ 8n 1952 weak spark #1
joeragg
John Deere 5045D, Ford 8N 1952
Help?I have a 1952 n8 ?till the 6 volts system
She does not want to start
Depending on here demeanor
I think it is a spark trouble?seems the spark is weak
If I put her on charge and then try to fire here up she in more cooperative and will start sometimes.
After she is up going she just purrs
How do I figure this out?..layman—´ terms please.
Oh I have changed the switch
/ 8n 1952 weak spark #2
Change that Puppy over to 12 volts, You will need an alternator that has an internal regulator. 12 volt battery , and a resisitor for the coil.I did mine 20 years ago, and my starter still works great. If you want a real hot fast firing tractor, then spring for a pertronox distributor kit and coil, My tractor starts in 3 revolutions now.Yesterdays' tractors and many others sell the parts listed here. I adapted my alternator from a gm wreck. You will not regret junking the 6 volt...Jy.
/ 8n 1952 weak spark #3
You can cover up a bunch of sins with a 12V conversion, or replace the 60 year old wiring, failing key switch, corroded battery cables and it will probably get along just fine as a 6V machine.
/ 8n 1952 weak spark #4
Yes, it all depends on how long you want to work on it each time .. I really ignored the iron carburator that rusts up, or if you leave gas too long, clabbors solid inside.My distributor was worn out, and needed points about every other few hours.We both did not mention the condensor, which helps the spark. Plus check the wiring directly to the distiributor, and the tiny rubber insulator that protects the wiring there.But< I still stick by my cure, to prevent hours of Tinkering each time you need it...Plus I turn the gas off and run it out each time..Jy.
/ 8n 1952 weak spark #5
There's nothing wrong with a 12V conversion. But it won't cure carb problems, and if the primary ignition circuit wiring is junk, it still will be after the typical 12V conversion because few will actually rip out the old harness and toss it. And a main harness for any 1939-1965 Ford gasser is cheaper than an auto parts store Delco alternator.
/ 8n 1952 weak spark #6
Even with a 12V system, my old Ford Jubilee would often have condensation problems allowing the spark to jump to ground long before it made it's way up the wires to the plugs. If you have electricity nearby, a hair dryer inside the distributor could work wonders. Also, make sure the coil and distributor cap are very clean/dry inside and outside. Pull the plug wires and clean off the plug insulators too. Clean and dry really makes a difference on old 6V and even 12V systems.
When I was experiencing problems with my system, I would always check that I had power to the coil when the key was turned on. A voltmeter or test lamp can show that quickly. Next, I'd pull the wire from the coil off the distributor cap and remove the distributor cap. Then, while holding the coil wire end very close to ground, I'd open and close the points manually to create a spark from the end of the coil wire (if you aren't careful, you'll get a jolt too). Of course, the engine/rotor has to be turned so the points are closed to start with, but that's easy to do by tugging on the fan belt or using the starter motor. You can watch the points to see that they open and close as they ride on the distributor cam face. While they are open, you should be able to measure the 6 volts from the coil. If you don't get a spark jumping from the coil wire when you open the points, then they need attention/cleaning/adjusting. By doing this test, you can check out everything except the rotor and high voltage distributor cap functions. Normally the rotor and cap will work fine if dry and carefully seated in the proper position.
Since you say that your 8N runs great once it starts, I'd be that if you get everything clean and dry, you won't even have to do the "experiments" above.
OK.... thank to everyone.....!!!!!
Hopefully ......with the advice
I can get her attention again and get her up and running ??
off to the garage I go
Many thanks to all
Joe
/ 8n 1952 weak spark #8
Great write up, i did not know if he had a multimeter, or tester.In answer to the points, my distributor really needed bushings or rebuilding. The pertronox is available in 6 volt or 12 volt, just cannot believe the spark that unit generates...with out any bushings or wear plates.. My generator had failed, and yes the igniton switch was gone. I use an 20 amp toggle switch, if they want it ,then take it, no key.But look out for the dog.. I really hate to part with mine , had it since 1981. Might spring for the new alloy carburator, but it was about $150.00. Now have Kubota, just to help the Ford.....JY.
/ 8n 1952 weak spark #9
sorry... i'm with rick.
FIX what's wrong with it.. then maintain it like it's suposed to be and it will be fine.
I have plenty of tractors on 6v.. I change their oil and do -AT MOST- yearly maintenance on them.. like cleaning bat terminals, checking wireing.. and sometimes cleaning and gapping points. there are many times this becomes a once per two or three year interval.
can't remember the last set of points I changed that simply wore out after i installed them...I've got plenty of sets that are going on a decade of use..
LEARN to maintain a machine.. it's easier than retrofitting it.
soundguy
/ 8n 1952 weak spark #10
another thing to do is pull the spark plugs and check their condition.. look for fouling.
if they are more than a couple years old.. or fouled.. splurge for a new set.
spark plug wires should be metalic core.. not resistor wires.
i like a hot plug like an al437.. though the oem range like an h10 should be fine in an otherwise good system.
once you get electrical out of the way, if it still hard starts.. we can look at fuel and compression..
soundguy
/ 8n 1952 weak spark #11
Your starting problems are not the fault of a 6 volt system. Converting to 12 volt seems to be everyone's cure all. You have something else going on that is giving you the problem.
/ 8n 1952 weak spark #12
Things do wear out; the bushings for the distributor cam shaft may be worn affecting the dwell angle. The cam lobs may be worn as well as the spark coil. Have you inspected the inside of the distributor for carbon tracking?
Some electrical systems that use a START and a RUN two position switch, having a one or two Ohm resistor in the START circuit and no resister in the RUN circuit to limit the maximum current. This resistor may have gone bad.
/ 8n 1952 weak spark #13
yep.. NO resistor in start, and resistor in run.
52 8n ford won't have that though... at least not oem.
soundguy
/ 8n 1952 weak spark #14
If you want to confirm that the problem is indeed a weak spark, remove a spark plug and connect it to the lead and ground shell. Crank the engine and observe the spark. If it's not a loud, fat, blue spark, then it can be considered a weak spark. If it is yellow, it is for sure a weak spark.
Hope this helps.
/ 8n 1952 weak spark #15
If I recall from the days of points, I always replaced the condenser when I changed points. That way you are sure of a good condenser that will suck that spark up as the points open so they dont burn up the contacts. You may want to view the whole system when it is running while in a dark room, that will show you any escaping fire in the system also. I would replace the distributor cap if it is really old as they can develop minute cracks that moisture seaps in and you only have a problem with starting, Once it starts and runs a while the moisture dries out from the electrical current running the minute crack and it runs ok from then on. If it cranks up well when Hot that could be your problem or just a weak coil. I can remember replacing the coil once because of weak fire and still had a problem. Pulled my hair out looking for something else till I finally took the coil back and they tested it. The new one was bad also. Not much on those old 8n's to be the culprit-wires, plugs, distributor cap, points, condenser, coil and rotor . If the battery is hot, it should have good fire if all the above are verified good.
2004 Chevrolet 1500 Silverado Truck (A63116)
2004 Chevrolet...
New Holland TC21 (A62177)
New Holland TC21...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
JAYCO BUMPER PULL TRAVEL TRAILER (A63569)
JAYCO BUMPER PULL...
2011 WESTERN STAR  4900 SB (A63569)
2011 WESTERN STAR...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
