Kioti KL130 Quick Connects question
/ Kioti KL130 Quick Connects question #1
nvip9r
Member
Mass
Kioti CK30
Looking for a little help. I am looking to put a snow plow onto my tractor and am wondering on what the KL130 hydraulic quick connect fittings are called that are setup near the loader. My plan is to disconnect the tilt/dump cylinders and hook up the new lines to the angle cylinders on the plow. I see they have a 3/8PT on them but when I went to buy one it didn't fit the same. Is it different due to a Korean brand? Any help would be great. thanks
I was thinking of ordering a setup on line with the quick connect and hydraulic line.
I see the Surplus store carrys a ton of stuff, and am wondering if it would be one of these? I think it is called the S45-3 type? But unsure if that is what I already bought at my local TSC, which wasn't the right size. Thanks for looking.
/ Kioti KL130 Quick Connects question #3
You won't find them at Surplus Center. The plugs are 3/8" ISO 7241-A plugs. You can order them from your dealer or some on-line sites. They cross reference to the following:
Parker 6600
Snap Tite 61
Aeroquip 5600
The Safeway 25 and 45 series do not fit these quick connects.
Hope this helps.
Thanks Michigan...was actually thinking of emailing you just cause you are always so helpful...I will check out my local place...if not online I will check too.
/ Kioti KL130 Quick Connects question #5
If you have trouble finding them, let us know.
Thanks should of just emailed you...next time I will...but figured try and keep the local guy in business...but he was $$$
thanks again
/ Kioti KL130 Quick Connects question #7
I am in need of O-rings (I think) for the quick connections on my CK30 with KL130 FEL hydraulic lines. I recently started having some small leaks around the connection block and checked the fittings tight. I cannot find the O-Ring size for the female connectors and was hoping you all might know. The connectors and hoses all look good and the tractor has ~350 hours on it.
thanks Jay
Parker 6600
Snap Tite 61
Aeroquip 5600
Hope this helps.
