3PT logsplitter
   / 3PT logsplitter #1
clemsonfor
Super Member
Greenwood Co., SC
Yanmar YM2000
What would yall consider a good buy on a 3py log splitter? It uses remote hydraulic hook ups not off the PTO. It is constructed with an I-beam and appears to have a new valve on it. Have not talked to the guy yet or seen it run, i have a pic but have to wait to get home to get it off my phone and onto the net.
   / 3PT logsplitter #2
I paid just under $600 for mine, a SpeeCo 4x24 from Tractor Supply. But it didn't come with hoses, so that pushed the ready-to-use price up slightly. But the only tractor I see listed in your sig line is a YM2000. They don't typically come with rear remotes. Have you added a pair yourself? Also - assuming the YM2000 - you might want to check the gpm rating of its hydraulic pump against the cylinder size of the splitter you're considering. Goes to splitter cycle time.
//greg//
   / 3PT logsplitter #3
Not sure what a good buy would be but I would deffinatally check your GPM specs.
A brief look and I couldn't find them but it is probabally about 5gpm. Assuming you have rear remotes and can run the splitter, If it is a 4x24 cylinder(most are) this would give you about 16 seconds jsut to extend the cylinder. A little less to retract. So you are looking at about a 30 second total cycle time. That is really slow. Most stand alone units on the market are in the 12-16 second range. So you are looking at about twice as slow as most splitters. If you can live with that, go for it if it is a good price.
   / 3PT logsplitter
Yea i dont have remotes, i also posted a thread about adding them to the yanmar. I have a metal line that has a rubber hose where with some fab i could hook up quick disconnects and run it off them. But yea i think 5gpm is close enough and that cycle time would not suit me, thanks, i think i may pass , unless i think i can buy and sell for a profit. They want $350 for it.
   / 3PT logsplitter #5
That is probabally not too bad of a price if it is in good shape.
Of if you are considering building one, that is a good start with a beam, cylinder and valve. All you would need is a tank, pump, and motor.
   / 3PT logsplitter
i even thought about that too. I could get a HF motor fairly cheaply, but then id need the pump n tank etc.
   / 3PT logsplitter #7
Tank should be easy to fab if you are handy, if not, a shop could probabally build you one for under $100. And a pump woud rund you about $150
   / 3PT logsplitter #8
Another option might be a PTO pump and tank. I built one a few years ago using 22 GPM PTO pump. It worked great. I liked the 3pt design but it ties up the tractor when used.
   / 3PT logsplitter #9
That is one nice splitter! I like the table!
   / 3PT logsplitter #10
I later added "wings" to the table with 3/8" rod. got tired of split pieces flopping off the table and having to pick them up off the ground. Thanks.
2018 East Texas 20ft Utility Trailer (A49461)
2018 East Texas...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A51039)
2018 John Deere...
2018 John Deere 460E Articulated Dump Truck (A51039)
2018 John Deere...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A51222)
2012 SULLIVAN...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
