Grapple Shop Built Grapple
/ Shop Built Grapple #1
Lt220
Dalton, GA
John Deere 3032E with rear hydraulics
Anyone have any good pictures of their homemade Grapple attachment? I am wanting to build a quick attach bucket with a grapple for my JD 2320. Any pictures or suggestions will be great.
/ Shop Built Grapple #2
Try searching the term "grapple" in the Build it Yourself Forum, There have been quite a few builds posted there over the years.
/ Shop Built Grapple #3
I attached the grapple to my loader arms so I could use it with the bucket or for logs with forks
/ Shop Built Grapple #4
I thinking of making one. From what I've read the Gator is made from 3/8" steel with 1/4" wall tube. I haven't fount out what size cylinder they use but another brand uses a 2" bore and 8" stroke. I figure the stroke is kind of dependent on where you place the cylinder.
I haven't decided if I want to build an attachment that can mount to the bucket or if I'll go all out and make one that'll have tines that can be used for a root rake as well. If I do I'm thinking that I'll make it use the standard teeth that my Case backhoe uses. I do like the idea of being able to lift and carry logs, not sure of the bucket grapple would work well for that.
Once I get my plasma cutter I'll get more serious and start asking questions. The Gator has long straight lower tines that can be used to slide under brush or a log and then the grapple comes down on top of it. Other brands I've seen look more like a claw with both the upper and lower jaw curved. It looks like you would lift the loader up, open the jaw up, and then drop it down (think of one of those cranes used to pick up stuffed animals). I'm thinking the straight kind would be better for my needs but would love to here others opinions.
Then of course would be measurements, what size are the lower and upper pieces. Do they feel that are too long, too short, or just about right. Is 4' wide enough or is 5' a much better way to go. Should I put expanded metal on the back to keep brush from sticking into the radiator or is that not an issue.
I haven't done much searching yet to see what people have made because I really wanted to wait until next spring.
I believe that my grapple bucket will probably be the same width as the bucket on my loader.....49". This seems to be a good size for my needs. I have been doing some research for several months and have collected a good number of pictures of different types of grapple buckets and grapple attachments for existing loader buckets. I am leaning toward making the grapple bucket with laser cut tines for the bottom. I still haven't decided what length that I want the tines to be. I don't want to make the bucket so big and heavy that I automatically loose lifting capacity due to the weight of the bucket.
/ Shop Built Grapple #6
crazyal,
Did you say, "once I get my plasma cutter"? May I ask what you bought or are planning to buy?
/ Shop Built Grapple #7
I made mine by trail and error. I used 1/2" and 1" pvc pipe with a bolt in the pivot point to determine stroke length and placement of the pivot points. I think I came up with 8". My grapple teeth are not as wide as the bucket. I use it for everything from large rocks to brush.
I even pick up my rake, box scraper, snow blade,etc and move them on and off my indoor shelving. No chains or getting off the tractor needed.
I don't see any reason to make them as wide as the bucket.
If the grapple arms stick out to far it will interfer with bucket digging near close objects/or self destruct because of pushing them into unseen objects. They don't have to stick out to far.
If doing it again, I would look into a light weight 4 in 1 bucket. Would it be possible to have an aluminun 4 in 1 bucket?
/ Shop Built Grapple #8
I wanted my grapple to be removeable, but I use it so much, that I just leave it on. I like the fact I can drop my quick attch bucket, put my forks on, then lift my 10' wide work platform, pinch it down with the grapple arms and hold it in place.
I also used electric over hydraulic to operate the grapple, since it was cleaner with just a switch on the dash.
/ Shop Built Grapple #9
crazyal,
I figure I'll try an Everlast PP60. I figure since Mark has been here he has shown he knows welding (not just a salesman) so I figure I'll give them a shot. Mark is hoping that early next week they will get a shipment in. I just can't justify the cost of something like a powerplasma65 (I think I could get by with a 45 but even that's about twice the cost) or a Cutmaster 52 for something that will only be used occasionally.
So I figure I'll need a project that will test it out, what better than cutting up a bunch of 3/8" plate.
/ Shop Built Grapple #10
What Plasma cutter did you get ? I bought one from Mark at Everlast and both the customer service and the unit itself has been amazing ! I am trying to make a homemade pantograph to aid in cutting out small parts and holes. It will use a wood template that I can make easily and then just mount in the machine and trace it by hand to reproduce the part in steel because I am no good at freehand cutting and trying to get an accurate hole otherwise has been an excercise in futility:mur:
/ Shop Built Grapple #11
I'm going to get the PowerPlasma60. I know what you mean about free hand cutting, lol. Someday I think I may try to make a CNC plasma table for it, either a 4x4 or a 4x8. There are several companies that sell kits to do it. It's not cheap though but I like the idea of connecting a computer to a plasma cutter so it would be more of a hobby.
So far all I've ever used is a much older smaller unit that might be able to cut 1/4" thick steel. I figure I'll play around a little first then try to find a way, maybe like you said a plywood form to cut along, to cut all the parts for the grapple and have the ones that should be identical be close enough so you can't tell with the naked eye. But that's the fun of building it yourself.
/ Shop Built Grapple #12
Well this is what I made for now to get me by. The stock was some scrap aluminium that was given to me. I hope to someday add some drive screws and motors to make it CNC but the simplicity of use is growing on me. It is kind of scary how accurate it is.
/ Shop Built Grapple #13
Simple but effective.
/ Shop Built Grapple #14
That is REALLY cool!
You should dedicated a new thread to it with build details.:thumbsup:
/ Shop Built Grapple #16
Nice pantograph evo !!!
We have a CNC Plasma Table, and wouldn't be without it, but seeing your pantograph, and your results, is a great reminder of what American ingenuity is all about. We still have what it takes, we just need a fair chance to use it.
/ Shop Built Grapple #17
Thanks for the comments and I apologize to the OP for sidetracking his thread. I will take some more pics and post how I built it in the welding section soon.
New/Unused Wolverine 72in Quick Attach Brush Cutter (A61166)
New/Unused...
2014 FORD F-350 SERVICE VAN (A62130)
2014 FORD F-350...
2013 John Deere 1790 Planter (A63109)
2013 John Deere...
BUSH HOG 3715 BATWING ROTARY MOWER (A62130)
BUSH HOG 3715...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
