CAB Top Repair Suggestions?
/ CAB Top Repair Suggestions? #21
Oops - not a job for Acraglas! Nuru, I think the bumper repair advice may be the way to go. Maybe some JD green Line-X or Rhino-liner truck bedliner may be a solution with more protection qualities in case you decide to do it again.
Ouch is right, you did this deliberately ?
You need your cab privileges taken away for a while. :laughing:
Gee, that bad huh:laughing:, well i guess I better go ahead and fix it.
om21braz, thanks, i will also have to look at the Rhino lining got yhr top - sounds like as very good idea.
OK, I finally started; here are my first pics - Day 1 Sand and Primer
Any comments, questions, suggestions?
I was wondering if I should just rough up the entire top, primer it, and paint the entire top?
/ CAB Top Repair Suggestions? #25
I'd paint the whole top so it's even and matches....
But it's the top of a tractor. Does it really matter?
I have been thinking about that and sofar, painting the entire top seems lie a good idea. So I probably will go for it.
/ CAB Top Repair Suggestions? #27
Dang Nuru, can't even tell where the scars were.
Ditto the idea of repainting the whole thing.
Day 2 (Today), 1 week since I did the primer coat. Well since it is a top and I had some other tasks to get done. I went ahead and took a chance on spraying (aerosol can) a single coat of official JD Green over the single coat of the primer. Since it is a top and I can do it again pretty fast. I went for it. Here are the results - see pics attached. This is without painting the entire top, it looks like I got luck on the matching as it does look pretty good. I will take a look tomorrow and then decide on what steps are next
I was wondering, should I use a Top coat of clear?, Or another coat of the JD Green first and a coat of clear? - seems like the initial coat is working, but maybe another coat of JD Green is warranted?
Thanks Willl, but I got a bit anxious and went ahead and went at it with the aerosol can of JD Green from JD.
/ CAB Top Repair Suggestions? #30
Looks pretty good to me. Bet you are glad you didn't put a lot of $$'s into a new roof. Good job.
Yeah, I think it looks ok, the $500 bucks would have also have taken a longer time to get it done, and risking damaging the seals too.
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
2013 Honda Pilot AWD SUV (A61574)
2013 Honda Pilot...
2001 33 Ft. Chris Craft Boat with a T/A 36 Ft. Boat trailer (A61574)
2001 33 Ft. Chris...
UNUSED IREV HIGH-END 2 WHEEL ELECTRIC VEHICLE (A64281)
UNUSED IREV...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
