Kubota Tractor tool kit recommendations?
/ Kubota Tractor tool kit recommendations? #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
I have been using my adjustable wrench a lot on a B7800/--L3700 ? I would like to purchase a torque wrench and some large wrenches maybe a socket or two from northern tool. Do I need metric or standard also any specific sizes ? I have a grease gun.
/ Kubota Tractor tool kit recommendations? #2
Use the same formula I use. I tell my wife that it is necessary to spend approximately 10% of the purchase price on tools to correctly maintain the vehicle.
If you spend $10,000.00 on a vehicle then you should spend $1,000.00 on tools. Use of this formula should set you up pretty well. Each vehicle requires the additional expense. Do not fall for the "you already have enough tools" line.
Let me know when they arrive so I can move next door to you.
Oh as for the tools start with a GOOD 3/8 metric socket set covering 8MM to 20MM or so and a GOOD set of combination wrenches of the same range. I seldom use a torque wrench on the tractor except for engine work.
/ Kubota Tractor tool kit recommendations? #3
Since I have several tractors, I just bought a complete tool kit from Sears with sockets and end wrenches along with a torque wrench. Kubotas use metric bolts/nuts though in some of the larger sizes SAE will work.
I am sure Northern will have sets also and I buy some stuff from them too.
/ Kubota Tractor tool kit recommendations? #4
[a little OT]
I've got a really useful tool in the box. It's a big "crescent" wrench with a handle that tapers into a spike. Seems like there are always some holes to be aligned when wrestling with the tractor and accessories. I suppose adjustable wrenches are evil, but mighty handy.
Anybody know what that tool is called? I haven't found it or a pic on the web yet.
Z.
/ Kubota Tractor tool kit recommendations? #5
I am probably a bad person to suggest what you should have for tools. I have probably have over $900 worth of hand tool and $1200 of air tools in my house garage and well over $5000 in the shop garage in my shed. I also carry 200+piece Craftmans sets in both my work van and my personal truck, I also installed a onboard air system on my truck for min use of air tools but mainly for airing up tires.
I would suggest that you go to Sears and buy a 200 or so piece Craftsman set. It will have most of the things that you will need for repairs, plus its lifetime warrantied.
WOW!!!! where do you live?? :laughing: I will check out sears. I mentioned northern tool because they offer a Jumbo wrench set, I do not know what 20mm equates to. The torque wrench would be used for our Wallenstein Chipper, the manual recommends different torques? Is this necessary or would good judgement work? Thanks for the replies.
/ Kubota Tractor tool kit recommendations? #7
[a little OT]
Z.
I think this might be what you have, Crescent 10" Adjustable Construction Spud Wrench. Iron workers use wrenches with a similar end.
/ Kubota Tractor tool kit recommendations? #8
In my opinion, there is simply no substitute for a good torque wrench when working on machinery. I did it for years, but certainly don't advise it.
What size should I look for ?
/ Kubota Tractor tool kit recommendations? #10
You shouldn't need any "jumbo" wrenches for the tractors you have.
Everything is meteric, but I'd also suggest a set of standards. If I am not mistaken I think the hydraulic hoses are still SAE sizes. So if you ever need a replaceent you may need standards.
I'd start with a set of 3/8 and 1/2 drive standard AND meteric sockets.
And also a set of std and met. wrenches.
Most kits come with an assortment of extensions, u-joints, etc.
For sockets, dont mess with 12-point, get the 6 pointers unless you are doing engine rebuilds because about the only thing 12 point on anything automotive/tractors is flywheel bolts, rod cap bolts, and somethimes head bolts.
But for the wrenches I perfer 12 point. 6-point is a PITA especally in close quarters.
I can personally vouch for the quality of the HF pittsburgh brand deep impact sockets. I havent broke a one yet and I use them in an IR 2135TI Impact that has no trouble snapping new 1/2" gr8 bolts.
Aside from them basic sockets and wrenches, you will need a few screwdrivers for miscellaneous hose clamps and small prying jobs.
If you havent got one, get a big 15" crescent wrench. They are good for things like tightening the nut on a tow ball and such.
And a couple of specialty tools you may want to consider while you are there is a greese gun for sure and an oil filter wrench.
And vice grips and pliers are also handy to have with you on the tractor as well as a crescent for things like the turnbuckels on the 3PH.
PS, you can never have too many tools. I am also one who has $1000's invested. The basic stuff you need isn't going to break the bank. It when you get into all the specalty things like DVOM's, flaring tools, ball joint seperators, dial indicators, cam R&R tools, bearing drivers, pullers, enging rebuild tools, etc. etc. But you should be able to get the things I listed and come in well under the $400 mark at HF.
/ Kubota Tractor tool kit recommendations? #11
I am a carpenter by trade, but I also do alot of wrenching on the side. A buddy of mine has alot of northern tools, he likes them and hasn't had many break that I know of. I just suggested Craftsman since they are more plentiful than Northern stores. 20mm is just a hair bigger than 3/4".
As for getting a good torque wrench, look on Ebay. I have bought a few of mine off there, all are Snap-On and I never paid over $85 for any of them. I paid $85 including shipping for my 1/2" Snappy clicker with 200lbft capacity.
/ Kubota Tractor tool kit recommendations? #12
184081d1287960630t-kubota-tractor-tool-kit-recommendations-crescent-at10spud-2.jpg.png
That's it, but mine's bigger :laughing: 15" or so. It rides around in the pickup in a waterproof tool box. Handy in the field.
Thanks for the info,
Z.
/ Kubota Tractor tool kit recommendations? #13
You will need metric and standard wrenches and sockets for those machines. Everything that bolts directly to the tractor will be metric. The loaders except for the frame parts that bolt to the tractor will be standard.
In metric wrenches you shouldn't need anything larger than 24mm, in standard up to 1 inch should be fine and 1 1/4" or 1 5/16" combination wrenches or 1/2" drive sockets for the pins on the box scrapers or other implements if you have them. I also prefer 6-point sockets, in 3/8" drive up to 19mm and 3/4", and 1/2" drive from 14mm up and 9/16" up.
Unless you feel like you need to do engine work, a 1/2" drive click type torque wrench will fill most of your needs, primarily checking wheel torque and possibly loader bolts.
I think I might have more invested in tools than the cost of all of the vehicles I've owned combined.
Brian
/ Kubota Tractor tool kit recommendations? #16
Resist the temptation to use an SAE (inch measurements) wrench or socket on a metric fastener. Never use a crescent wrench or vice grips on a bolt or nut unless it's already loose--the risk of rounding the corners off is very real. A couple of cross-overs that are easy to remember: 3/4" is interchangeable with 19mm; 7/16" with 11mm, and 1 1/8 with 22mm. Except for those (and their multiples) using an SAE wrench on a metric fastener (or vice versa) is asking for more trouble than you can believe. all you need is one big fat bolt that's hard to get to, rounded off and stuck, and you'll want to tear your hair out. DAMHIKT.
I have a LOT of tools (both hand and power) but most of the time I'm using 12 point 3/8" deep sockets (Craftsman or Snap-on) and long combo wrenches. If I really have to hurk on something, I'll use a 1/2" socket with a long breaker bar. I have a small set of 3/4" drive SAE sockets for stuff like the spindle nut on my bush hog, but I use maybe once every 2 years.
The other two tools I use a lot is a large bench vise and a bench grinder with a wire wheel on one side. the wheel is great for cleaning the threads on bolts before I reassemble them.
Hope this helps.
/ Kubota Tractor tool kit recommendations? #17
Hope this helps.
There are more interchanges than that.
5/16-8mm are almost exact. 1/2 is just a hair smaller than 13mm, so if you are worried about rounding a 13mm, see if a 1/2 will fit, 90 % of the itme it will.
14 and 9/16 are very close, 5/8 and 16mm are almost exact.
In general it is not a good Idea to grab SAE wrenches for metric bolts and vice verse. BUT, I will always use the wrench that fits the best. Sometimes that is a 1/2 instead of a 13mm on a metric fastner. Etc.
/ Kubota Tractor tool kit recommendations? #18
I picked up something similar from TSC the other day - although it's probably 16" long overall. It stays in the toolbox behind the tractor's seat and gets a lot of use. Also in there are an assortment of lynch pins and top link pins for whenever one goes missing.
In the garage I have the same 3/8 SK socket set I bought in 1975 and a lot of other stuff that sort of found their way here in the mean time. I can't overstate the importance of having a good collection of quality screwdrivers of various configurations, drifts, punches, shim gages, torqx and allen drive sockets. Also 3/8 drive and a 3/4 drive torque wrenches (still looking for a good 1/4 drive for that fussy stuff). Enough hammers of assorted sizes and shapes to fill the trunk of a '71 Fury III. 3 anvils. A block and fall. 300' of 5/8 polyester double weave and 2 snatch blocks to fit. 60' of 1" nylon & snatch block to fit. It's a sickness. Run away before you catch it!
-Jim
/ Kubota Tractor tool kit recommendations? #19
I've recently been convinced to at least consider no longer bothering with Sears tools. Their sockets are very junky anymore, I suppose because the accountants determined that it was more cost effective to increase their replacement rate and decrease quality than it was to maintain the same quality they used to have. :mad:
/ Kubota Tractor tool kit recommendations? #20
I would be lying if I said I never used a 17mm on a 11/16" or 19mm on a 3/4". You almost always find a metric size that will work on an SAE fastener. It's not always true the other way around, like 10, 12, and 15 mm, gotta have the correct size wrench or socket.
It is best to use the correct size to avoid damage to the nut or bolt.
Another must have is a good quality (no china tools) flare nut wrench set. When dealing with hydraulic hoses and other lines they are the best tool to avoid damage to the fitting on the line.
CATERPILLAR D6K XL CRAWLER DOZER (A64279)
CATERPILLAR D6K XL...
2015 DODGE DURANGO RT SUV (A59912)
2015 DODGE DURANGO...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
2007 Volvo VNL Truck Tractor (A63689)
2007 Volvo VNL...
2001 Freightliner Allegro Bus Class A Motorhome (A61574)
2001 Freightliner...
