I am probably a bad person to suggest what you should have for tools. I have probably have over $900 worth of hand tool and $1200 of air tools in my house garage and well over $5000 in the shop garage in my shed. I also carry 200+piece Craftmans sets in both my work van and my personal truck, I also installed a onboard air system on my truck for min use of air tools but mainly for airing up tires.
I would suggest that you go to Sears and buy a 200 or so piece Craftsman set. It will have most of the things that you will need for repairs, plus its lifetime warrantied.
[a little OT]
I've got a really useful tool in the box. It's a big "crescent" wrench with a handle that tapers into a spike. Seems like there are always some holes to be aligned when wrestling with the tractor and accessories. I suppose adjustable wrenches are evil, but mighty handy.
Anybody know what that tool is called? I haven't found it or a pic on the web yet.
Z.
I am a carpenter by trade, but I also do alot of wrenching on the side. A buddy of mine has alot of northern tools, he likes them and hasn't had many break that I know of. I just suggested Craftsman since they are more plentiful than Northern stores. 20mm is just a hair bigger than 3/4".WOW!!!! where do you live?? :laughing: I will check out sears. I mentioned northern tool because they offer a Jumbo wrench set, I do not know what 20mm equates to.
I think this might be what you have, Crescent 10" Adjustable Construction Spud Wrench. Iron workers use wrenches with a similar end.
I have been using my adjustable wrench a lot on a B7800/--L3700 ? I would like to purchase a torque wrench and some large wrenches maybe a socket or two from northern tool. Do I need metric or standard also any specific sizes ? I have a grease gun.
Resist the temptation to use an SAE (inch measurements) wrench or socket on a metric fastener. Never use a crescent wrench or vice grips on a bolt or nut unless it's already loose--the risk of rounding the corners off is very real. A couple of cross-overs that are easy to remember: 3/4" is interchangeable with 19mm; 7/16" with 11mm, and 1 1/8 with 22mm. Except for those (and their multiples) using an SAE wrench on a metric fastener (or vice versa) is asking for more trouble than you can believe. all you need is one big fat bolt that's hard to get to, rounded off and stuck, and you'll want to tear your hair out. DAMHIKT.
I have a LOT of tools (both hand and power) but most of the time I'm using 12 point 3/8" deep sockets (Craftsman or Snap-on) and long combo wrenches. If I really have to hurk on something, I'll use a 1/2" socket with a long breaker bar. I have a small set of 3/4" drive SAE sockets for stuff like the spindle nut on my bush hog, but I use maybe once every 2 years.
The other two tools I use a lot is a large bench vise and a bench grinder with a wire wheel on one side. the wheel is great for cleaning the threads on bolts before I reassemble them.
Hope this helps.
I picked up something similar from TSC the other day - although it's probably 16" long overall. It stays in the toolbox behind the tractor's seat and gets a lot of use. Also in there are an assortment of lynch pins and top link pins for whenever one goes missing.I think this might be what you have, Crescent 10" Adjustable Construction Spud Wrench. Iron workers use wrenches with a similar end.
There are more interchanges than that.
5/16-8mm are almost exact. 1/2 is just a hair smaller than 13mm, so if you are worried about rounding a 13mm, see if a 1/2 will fit, 90 % of the itme it will.
14 and 9/16 are very close, 5/8 and 16mm are almost exact.
In general it is not a good Idea to grab SAE wrenches for metric bolts and vice verse. BUT, I will always use the wrench that fits the best. Sometimes that is a 1/2 instead of a 13mm on a metric fastner. Etc.
