3-Point Hitch Kubota L 2800 issues
/ Kubota L 2800 issues #21
Large pliers... Once it's broken free... it's easier.
ORC... push in the clutch at the same time you move the PTO lever...
i agree- then spray it with pb blaster and work it a little. Move it on occasion and it won't freeze up again-----"maybe"
Is there anything wrong with just slowly lowering the throttle and then shifting the pto lever without the clutch.
/ Kubota L 2800 issues #23
My speed lowering knob was frozen when delivered.. put some Kroil (penetrating oil) on the shaft.. wait for a couple of hours, put some more.. wait.. get the vice grips out.. keep wiggeling back and forth. dont break it off. just a little at a time. soon it will "break loose".. just keep working it. I lubed it with fluid film.. works real smooth now...
On the PTO engagement. If I Recall Correctly, the manual says to use the clutch both to engage and disengage.. I always throttle down to engage then push in the clutch, move the lever, let out clutch and run up throttle. And to disengage.. throttle down, push in the clutch, move lever let out clutch and go on.
James K0UA
/ Kubota L 2800 issues #24
I would use the clutch. There is a slight rake angle on the old PTO clutch. When it is loaded it tends to not want to disengage. By pressing the clutch in the implement is now driving and the clutch unloads. It is fine to slowly reduce power. I reduce mine to about 2000 and then clutch and disengage simultaneously.
I bought the tractor and have been doing some mower cutting and playing around with the front end loader. I am having a blast.
Am I correct in assuming that if you are hearing the over running clutch (such as when you press in the clutch while cutting with a rotary mower) that this is normal and is not damaging your tractor? My manual says to use the clutch so I will try to throttle down slowly and then clutch and disengage the PTO as quickly as possible so i don't have to hear that awfull racket.
/ Kubota L 2800 issues #27
...so i don't have to hear that awful racket.
I never want to hear that ratcheting sound... to me, that is going to wear down. So even at high rpm's, I'll press the clutch and move the pto lever... as fast as I can. I have a tiller and once in a while, I can hear the skipping of the cam (if it hits rocks) but only once in a while... need to work on the slip clutch on the tiller. :(
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63688)
2012 MACK Tender...
2019 Peterbilt 567 Quint Dump (A62613)
2019 Peterbilt 567...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
KUBOTA MI08S TRACTOR (A63276)
KUBOTA MI08S...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
