New Toys
/ New Toys #1
Don87
Elite Member
SW Pa.
Massey Ferguson GC2400
My new toys.
/ New Toys #3
Nice stuff! :thumbsup: How about posting some pics if you can when you install that front quick hitch.
/ New Toys
Look nice:thumbsup:be shure to let us know who it works for you.
I just finished adjusting everything on the tiller, cut driveshaft, and tilled the garden.
It works great. It's made for the SCUT's, and it will raise about 16 inches off the ground for transport.
I had plowed the ground about a month ago, and used the cultivator on it.
But after 1 pass with the Bush Hog tiller, the ground was well worked.:thumbsup:
/ New Toys
Thanks, and I will post pics.
/ New Toys
Forgot to post the picture.
/ New Toys #7
Nice:thumbsup: Good to hear it works well. How does the GC do with the plow and cultivator?
/ New Toys
The plow I found is an old David Bradley, only 8 inch. Not really a fair test, but the 2400 pulled it just fine, even with turf tires.
The cultivator would stop the tractor, so I had to make several passes, going deeper each time.
My tires are loaded with Rimguard.
But all in all..........The GC2400 actually did better than I expected.:thumbsup:
/ New Toys
Here ya go: Pic number 1, under the fingers on my left hand......this slides over the top of the frame on the front of the tractor. Directly below that(the shiny piece), is the locking mechanism...........operated by the T-Handle in pic number 4 (quick hitch installed).
Picture number 5, the little thing sticking up in the middle of the hitch......that holds the blower on.
/ New Toys
The FEL can be used with the front quick hitch installed, BUT, the quick hitch, and driveshaft is sooooooooooooo close to the ground, that you would need to be extremely careful (I can't emphasize this point enough).
/ New Toys #11
By the looks Santa starting his run early this year. ;)
Nice looking setup. :)
/ New Toys #12
Thanks Don87, that's great. I always wanted to see how the Massey went on, as I've only seen the John Deere setup. I was worried that the front blower would be a pain if you needed to occasionally use the front loader, but it doesn't look bad at all.
I've had my eye on a scut or cut for a while now, the Gc was my favourite choice, but too many other things keep coming up. Got rid of my dump truck because I was frustrated with the low rates, then I got really stupid and bought a highway tractor, then a pickup.......hopefully the tractor is coming next:laughing:
Thanks for the pics.
/ New Toys #13
Hey, Paystar-- you're right, it's very easy to slip off the blower and mount the loader --I've done it myself-- but Don's absolutely right: that blower quick-hitch shoe sits very low. I found out when I --uh, contacted-- a low stone wall...:ashamed: Fortunately, no damage, other than some scrapes in my nice shiny black paint.:eek: But really, it only takes a few minutes to accomplish the swap, if you have wheeled dollies on which to set the FEL and blower.
/ New Toys #14
Very nice equipment Don. Looking forward to winter to try that blower out..... are we;).
/ New Toys
I purchased the blower, so that I can clear the path for Santa:thumbsup:
But yes, I'm anxious to try it out.
May not be long though...........Rochester NY. had snow last night. I was there, LOL
/ New Toys #16
Good luck with your 2360, I have found it to be an awesome snowthrower. It will throw light dry snow 50+ feet. I have thrown slush with visable standing water. With slush get into it hard and out of it fast. Light loading tends to clog. Personal opinion: for slush remove the wire gaurd in the chute as it tends to clog the chute.
/ New Toys
Thanks for the tips.
I was wondering about the 'wire guard' myself. Looked like a problem area to me.
/ New Toys #18
Ditto on the wire guard. I've threatened to yank it off several times, but it's still there.... :mur: Maybe this winter it'll bite the dust! :cool:
And ditto on the slush! Mine's throw gets reduced to around 25-30' with the wet stuff. (Oh yeah, I can live with that!:D)
/ New Toys #19
thanks for the pics, Very nice looking tractor, when I when green there was no red dealer in the area, but I have heard and can see many fine things about Red. Does your tractor have a rocker pedal like the orange or 2 seperate like green?
/ New Toys #20
The Massey's have seperate forward and reverse pedals like the Deere. And left side brake.
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
2006 INTERNATIONAL 7400 4X2 VACUUM EXCAVATION TRK (A63276)
2006 INTERNATIONAL...
2018 CATERPILLAR 303ECR EXCAVATOR (A65053)
2018 CATERPILLAR...
2019 Ford F-450 Liftmoore 1032 3,200lb. Crane Service Truck (A64556)
2019 Ford F-450...
HORST RSW HEADER CART (A64278)
HORST RSW HEADER...
Small Cow (A64557)
Small Cow (A64557)
