Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,744
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
My dilemma is that I really prefer using choker cables over chains, and it's tough to get them the right length as every load is different. You can't just hook the end of the cable to the tractor at any length like you could with a chain. Right now I'm using a 3/8" 12' Cat choker, but would like some sort of setup to 'grab' the choker at the tractor end giving me unlimited adjustability. Thoughts?
Good job :thumbsup:
I guess I would use choker chains. Don't know what you have against them. Get the ones with the steel rods on the ends to push under the log for easy starting. 5/16" would be plenty for what you discribe or 3/8" if you like. Weld grab hooks to your box blade or (preferably to me) use a cross draw bar with two or three tractor hooks and loaded tires. You can grab two chains in one tractor hook.
As a side note it seems amazing that a 10 year old blow down is burnable.
Hardwood that hits the ground up here rots pretty quick. You are lucky.
You got the work done and thats what counts the most. From the looks of the terain you have to work on you would find a winch and a couple snatch blocks invaluable.
