Installing a fuel guage on a MF1010?
   / Installing a fuel guage on a MF1010? #1
handirifle
Central Coast of CA
Massey Ferguson 1010
My MF1010 has an idiot light, instead of an actual guage, and of course within a month of owning it, I ran out of fuel. NOT something I want to repeat.
The cap is right behind the steering wheel but it's still a pain to stop, unscrew it and try to see how much is left in there.
Anyone ever put a real guage in an MF1010?
If so, how did you do it, and what did you use?
Thanks
   / Installing a fuel guage on a MF1010? #2
Hi Handi,
I've not done it but I imagine it can be done. I do know that changing the light bulbs in the warning light cluster is not so easy. Mostly due to the confined space. And on my tractor, the bulb in the gauge cluster was not the bulb MF sold me, so I ended up at NAPA. I changed every one of them while I was in there.
I recommend you do some searching on fuel gauges and see what you can find that's simple. But I think you'd probably have to replace the float assembly and install the gauge to work with it. Finding a float assembly that would fit your tank or modifying one to work might be the biggest challenge. I'd pull out the one I have and take it with me to the store.
Another good site to learn from is the Chinese Tractor Owner's Association on the web. I think most of their tractors have gauges, so it may not offer any learnings in this instance. But I've picked up a lot of tips from reading posts there.
If it were me, I'd just count on refueling the minute the idiot light came on. You could buy a fuel bottle at a camping store, keep it full of diesel and store it somewhere on the tractor as a reserve supply. I take one to the woods filled with premix for my chain saws. They hold about a quart and they are made for fuel, so I think it would work.
Did you ever get the correct owner's manual? I've never figured out a way to make my scanner scan all the pages into one file, or I'd send a copy to you!
Let us know if you do the mods!
Hi Handi,
Lambs
No I never have gotten the manual. Time has pulled me and my funds to other, more pressing projects. Those are nearing a point where I might be able to get back to the tractor.
I will look into the bulbs, and I do keep a fuel can handy, now!
I'll do the research and see what I can come up with. If I do anything, I will post on it.
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2014 John Deere 6125M Utility Tractor (A50657)
2014 John Deere...
2014 STEPHENS 200BBL TANKER TRAILER (A50854)
2014 STEPHENS...
2019 Caterpillar 815K Articulated Compactor (A49461)
2019 Caterpillar...
