DK551C and KL1595 update
/ DK551C and KL1595 update #1
Donegal_TDI
Donegal, Ireland
SAME100.4 Kioti551C XUV855D
Those of you that saw my other post....
http://www.tractorbynet.com/forums/...184397-urgent-has-kl1590-loader-problems.html
......are aware that I was interested in this tractor.
I drove a 400mile round trip to view,
and while it will suit many, not me.
Bit too rusty, stiff controls, overpriced and no warranty.
Pictures are very deceiving, best to see in the flesh.
End result, I am buying a new DK551C and KL1595 from the importer in Ireland,
will have a warranty and backup.
Very nice old guy,
be prepared for many pictures when I get it in a week or so.
Will be using it on a commercial farm to feed cattle over the winter.
/ DK551C and KL1595 update #2
Congratulations.
You need to recruit some countrymen to TBN but rest assured we've already got all the Blarney we can handle here.
Can anyone confirm what the lifting capacity of the KL1595 loader is, and break out force?
Some Kioti documents show it as 1213 to 1323 lbs at pivot points with breakout force similar. This seems low, I would expect lift capacity to be nearer a Ton.
Anyone got the figures on this specific loader model? Thanks.
/ DK551C and KL1595 update #4
Hard to get that data now that Kioti has removed it from their website. Maybe Wallace Tractor or Michigan Iron and Equipment have the old specs tucked away somewhere. Reach them via TBN. Kioti customer service in North Carolina should have it too.
/ DK551C and KL1595 update #6
I cant remember exactly, but it is between 2600lb and 2800lb lift cap on the KL1595
BTI
Well done!
That's more like it.
There definitely seems to be two distinct KL1595 loaders in Kioti world.
OK Guys & Gals.
For better or worse, I have paid a hefty deposit on a brand spanking new Kioti 551C and KL1595 loader and a few other bits.
Hope to get up next week to collect.
Will tow it down on a trailer myself using a BMW X5,
400 mile round trip.
Lots of pictures promised,
maybe a few from the epic trip.
Best wishes.
/ DK551C and KL1595 update #9
Donegal_TDI said:
OK Guys & Gals.
Best wishes.
No way the BMW is rated to tow a trailer loaded with about 6000lbs of tractor and loader. The trailer necessary would weigh another 1500lbs or so which totals around 7500lbs. The BMW X5 in the USA is rated for about 5000lbs as I recall.
I have a tendancy, be it a failing or a flaw, to push the sides of the envelope a little :)
The Germans have a reputation for building a major safety factor into their tolerences and I am using a very good triple axle trailer. The route is mostly flat with light gradients with one 4 mile section of a major gradient going over the Sperrin mountains.
I'll borrow John Wayne's testicles for the day :)
I have towed comparable things before. Wish me luck.
/ DK551C and KL1595 update #11
Good luck. Go slow.
I understand your point regarding conservative engineering. I had a ML320 but that was truly a small truck. The X5 as I recall is a unibody however. Here's an idea: put the Bimmer on the trailer and tow it home with the Kioti!
/ DK551C and KL1595 update #12
FWIW, the tow ratings of the same vehicle is often higher in Europe and elsewhere than it is in the US. I'd guess it's largely due to the sue-happy mentality that's prevalent in the US.
/ DK551C and KL1595 update #13
According to my brochure.
KL1595 Capacity to full height a pivot pins is 2,685lbs
Breakout at pivot pins is 4,500lbs
This sounds about right,
thanks for the info.
The only catalogue I could get on the net was one from Romania which I think referenced an older version of the loader.
I will keep you guys updated on developments.
A side issue I am working on is an effective detachable ballast for the rear.
My cattle go inside in about 2-3 weeks, and the Kioti will be going to work for real, after it gets a good polish and rust treatment,
a tacky transparant wax I spray on everything I get new.
It's a lot wetter in Ireland than you folk are used to in the land of the free:)
I will have about 2 weeks to get this work done.
You will get lots of pictures in due course.
/ DK551C and KL1595 update #15
I'm sure you've searched TBN for ideas. The one I like as simple, effective and cheap is to use a 55gallon drum and put rebar through the middle sticking out both sides to link to the 3PT arms. Use something for a toplink stabilizer then fill it with rocks and concrete above the rebar level to the desired weight.
I always have some attachment on the rear serving as ballast and therefore haven't pursued any other detachable ballast solution.
/ DK551C and KL1595 update #16
Donegal: Please tell me more about the :thumbsup:"tacky transparent wax I spray on everything I get new" I would like to treat my equipment with something like the wax you are using. Thanks
/ DK551C and KL1595 update #17
Google the name"Waxoyl"
Other companies make similar products.
It can be diluted with white spirits to put on an all but invisible protective layer.
Does'nt come off with power washing.
I have a 10 yo SAME 100 that looks essentially new because of this stuff.
/ DK551C and KL1595 update #18
I realize this post is quite a few years old but I have been making myself crazy trying to run down the specs on a KL1595 loader. I have found what I think is a good deal on 2004 DK55 (only 160 hrs!) with a KL1595 loader. My only concern is the capacity of the loader (and of course the well documented issue with the roll-back). I'd feel better about it if it indeed have at least the capacity reported by Wallace (2685 lbs) vs. the other European documentation I have been able to find (1365 lbs). I currently have a CK30 with a KL130 loader and looking for more capacity but it the KL1595 only has 1365lbs of capacity I'm not gaining much.
/ DK551C and KL1595 update #19
I don't know where that European number comes from (you sure it isn't kilos rather than pounds). I'm pretty sure the Kl1595 is about the same lift capacity as the KL401 so 2685lbs sounds right to me.
/ DK551C and KL1595 update #20
The specs on my 2014 KL401 on my DK45 are 2761 lbs of lift capacity at full height. I bet Island is right, that 1365 number is kilograms which would equate to 3009 lbs.
Excavator trenching bucket- one bucket per lot (A63118)
Excavator...
PALADIN GSS72-72" HYD BRUSH CUTTER (A62129)
PALADIN GSS72-72"...
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
2019 John Deere R-4038 (A63118)
2019 John Deere...
6 ROW RIPPER BEDDER W/ROW MARKERS, 3PT (A62130)
6 ROW RIPPER...
John Deere 1023E (A62177)
John Deere 1023E...
