Backhoe Routine Maintenance.
/ Backhoe Routine Maintenance. #1
kattywumpus
Gold Member
Southern Maine
Kioti DK40SE with Cab.
As I seem to be using my KB2485 more I wondering if there is any routine maintenance or things to watch out for besides just greasing I should be performing? Plus I知 wonder what people are using for grease? As mx5guy note in another thread, I also have the same challenge greasing the arm side-to-side pivot pins. About 10 days ago I was able grease the top and bottom pins with a couple pumps fine. Yesterday I could not get just one pump into the top pin
/ Backhoe Routine Maintenance. #2
lots of grease, I use moly grease from TSC. I would also keep an eye on bolt tightness, especially subframe to tractor bolts. A little lube on the control linkage might be good too.
/ Backhoe Routine Maintenance. #3
I hope you store your backhoe under a roof. Even if you are not able to keep your machine out of the weather or the backhoe sits a long time in between usage, keep all your hydraulic parts shiny and cleaned with a rust preventative.
rimshot
/ Backhoe Routine Maintenance. #4
Keep those stupid subframe bolts tight!
If you push the bucket to the ground and the backhoe moves more than a inch or 2 before it lifts the tractor up tighten up those 8 big bolts that are under yoyr feet.
/ Backhoe Routine Maintenance. #5
Those same bolts come lose on my KB2375 from time to time. I'm going to try locktight the next time they need tightened but that may not even work considering the forces the bh puts on them. Other than that, lots of grease to blow out any dirt or moisture. All of my zerks take grease but if one didn't, I definately be finding the problem. Members have mentioned fluid film for the hyd pistons when sitting. I just coat them with the same grease I use on the zerks. A little messy but it works.
Mmm, good rationale to purchase a larger socket set. Got to love those tools! :thumbsup:
rimshot
Yep, a new 12x28x11 barn style shelter. It's beside my electrical pole so it has power, plenty of lights and on an elevated gravel base. Add a concrete floor would make it perfect. My wife did the mistake of saying she likes the look of it and that I should get another one to hide all those implements. :) The problem is I realize with several implement in a long shelter I would need a chain hoist to move the implement to the front of the shelter to get at the implement with the tractor. And since I just placed an order for another attachment, a Gator Grapple I will need a long shelter to hide everything. I hope to recieve the grapple next week.
/ Backhoe Routine Maintenance. #8
Here is a picture of my new 28' square pole barn complete with 9' doors and concrete floor including drive approach. This land including road back for my CK20 and attachments was cleared from my heavily mature wooded land. 0f course that included removal of dozens of tree stumps and fill all done with the little ck and it's backhoe attachment.
Rather than a chain hoist to move my snow blower or backhoe around while unattached and stored, I just set them on top of those four wheel furniture dolly's. They are about $20 each at HD or Lowe's. That stuff wheels out of the way easily that way.
rimshot
rimshot
Nice. Long term I prefer a similar storage solution, but I can't build a permanent building in my current location. I need to clear more land.
Hey Wallace, did your trick to check the subframe bolts and notice something else. How much play is normal for the top side to side pivot pin?
/ Backhoe Routine Maintenance. #11
rimshot
I do the same thing, i.e., use those furiture dollies to sit my backhoe on for ease of moving around in my shed.
/ Backhoe Routine Maintenance. #12
I had one of the pins that hold the bucket on lose the bolt in the end and start to work its way out. Now I check over all pins and fasteners every couple of uses. It'd be really easy to bend something badly if a pin was part way out.
Really good point Jim.
PS: nice to get this thread back on track after I detour it with the shelter discussion. :)
2011 FORD F-350 FLATBED DUMP TRUCK (A64278)
2011 FORD F-350...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
2020 VOLVO EC140EL EXCAVATOR (A65053)
2020 VOLVO EC140EL...
WOODS TS1680 - 14' ROTARY MOWER, 3PT (A64278)
WOODS TS1680 - 14'...
HONDA generator (A64553)
HONDA generator...
