Oil & Fuel MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!!
/ MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #21
Here is more pump information from elsewhere on the internet. Another forum, I think, although I've forgotten exactly where I got it. It contains the instructions for actually rebuilding the pump. This goes far beyond what is necessary to just stop the leaks around the throttle or cutoff stems. I hope that is never necessary, as it seems to involve specialized tooling. You may find it interesting.
/ MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #24
I also have a leak, but I am pretty sure it is from a defective gasket. Can someone please send me the instructions for rebuilding the injection pump? I am hoping that I will not have to remove the pump from the tractor to replace the upper gasket, but any help or instructions would be appreciated. Also, any place that sells a gasket kit would be nice too. Please send any information to pottergang1995@aol.com
I tried to download the zipped link provided, but it would not open because it said it was corrupted.
Thanks.
/ MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #26
/ MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #28
I'd like to have that article too, same problem right after getting a new paint job. Thank you for your time.
texstar77@hotmail.com
/ MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #29
JJ. in B.C. said:
Yes it can be repaired without removing the pump but it must be done in the correct sequence, if you would like to drop me an email i will send you an article showing how to fix it.
JJ my email is tjohnny321@gmail.com thank you for the info.
/ MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #30
JJ,
I would like to have that article on MF fuel leak at inj. pump.
Thanks, redgarc
/ MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #31
could you email me instructions to this also, and maybe part numbers if available. thanks jeremy chapman
/ MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #32
Hi JJ
Would you be able to post me info on the above - I would be most greatfull.
Cheers
Roger - New Zealand.
my email - rogatkinson@paradise.net.nz
/ MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #33
Hi JJ
I am new to this site and sent you a message but am repeating it in case it did not work. Would you kindly send info on repairing fuel leak at end of throttle connection on top of injection pump. Most grateful.
Cheers
Roger
/ MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #34
Could you send me the fix for this broble as well, thank you.
/ MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #35
Here is my e-mail address. neseirf@hotmail.com
thank you
/ MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #36
Am emailing you separately.
Cheers
Roger
/ MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #37
I have a 165 and a 184-4 wheel drive. The fuel pumps look the same and I believe are the same as on the 135 The 184 has a leak around the throttle shaft. Could you provide me with the instructions on repairing the problem?
/ MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #39
I also have an old JD 420 crawler that I bought nearly 40 years ago. My son is wanting to restore it. The 420 needs a lot of parts. Many of the parts I can make but I still need a source for those that I can't. Where or who has a supply of 420 parts including an engine ?
/ MF 135 DIESEL LEAK AROUND THROTTLE SHAFT ON INJECTOR PUMP!!!! #40
I have the same problem with leaking around the throttle shaft. :confused2:
Please e-mail me the instructions too. Thanks, Tony
tmabes425@gmail.com
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
KENT HYDRAULIC HAMMER ATTACHMENT (A60736)
KENT HYDRAULIC...
JOHN DEERE 331G SKID STEER (A62129)
JOHN DEERE 331G...
500BBL WHEELED...
78''Skid steer bucket (A61567)
78''Skid steer...
