Poulan gas cap
/ Poulan gas cap #1
meb9796
VA
JD 3720
My saw is over 10 yes old, but runs great. About 1yr ago, I replaced the gas cap because it was getting harder and harder to remove/close it. Well, today I used the saw for the first time after 4 months and the same thing happened?? Anyone heard of this happening??? How about ideas on how to prevent this from happening????
Thanks in advance
/ Poulan gas cap #2
I've heard (and seen it mentioned in another thread here) that the ethonal in the gas causes this (and other) problem(s)
/ Poulan gas cap
Funny thing is that it just started happening in the last two years. Maybe that is when they started adding more of it into our every day gasoline. Wonder if they make a cap that won't be effected by this??
/ Poulan gas cap #4
And now the all-knowing morons in DC have just allowed it to be raised to 15%. Wait till you see the havoc that will be brought to engines.
regards,
Steve
/ Poulan gas cap #5
Have the same problem with mine. Anywhere I can find Poulan caps? I bought the saw at Rural King and all they sell are Mac caps. Pretty darn frustrating
/ Poulan gas cap #6
I had that problem with a newer yellow Poulan Pro 42cc. First I used a belt sander on the outside of the threads. Remove the o-ring if you do that. It helped but then the cap vent started leaking. I took the saw model # to Northern Tool's service desk and they ordered me a cap. It was about $4.00. Works great so far.
My older green Poulans have not had the cap problem.
/ Poulan gas cap #7
That's the saw I have Mr. Blazer. It runs great, cuts good, easy to start....until it runs out of fuel and I have to take that #$%^@# cap off. I have the Poulan (Yellow) 42cc, an older Poulan (green & metal) and a couple older Macs.
I have been told that my older Mac requires a 16:1 fuel mixture and the rest can run on, I think 40:1. Whatever the smallest bottle mixed with one gallon gives ya. I have also been reading about the effects of ethanol in the gas we are buying and the pros and cons of using aviation fuel.
Here are my questions:
1. how do I know if my saw has a catlytic converter?
2. Can I use the aviation fuel in all of these saws?
3. What are the thoughts of you more experienced fellas about the fuel stabilizer you can purchase at TSC in remedying the alcohol issue?
This has been my best find on the internet. I lovey TBN
/ Poulan gas cap #8
Yeah, I like that saw. It's a 4218avx. The tool-free blade adjustments and anti-vibe are nice. I got mine from a surplus place for $40 with a 16" Homelite bar - I guess it's normally an 18. The carb adjustments were messed up and the screw heads looked like male Torx. I cut some short pieces of 1/4" polyurethane air line and pushed them onto the screw heads so they stick out of the saw body just far enough to adjust by hand.
Here are my short answers to your questions.
1. Pretty sure it doesn't.
2. Yes. Higher octane won't hurt anything.
3. I usually use the Poulan brand oil which is not expensive and includes a stabilizer. I haven't heard of a stabilizer that negates the effects of ethanol. The concept doesn't sound plausible.
Many of the fuel stations around here still carry ethanol-free gas.
My older saws are a 2150 (16") and a 2750 (46cc Farmhand). They both still run good. The little saw is nice and light for limbing but the handles are mounted solid and it gives me the tingles if I run it for long.
/ Poulan gas cap #9
Have you considered replacing the gas cap with an alternate. Last year I left my gas cap at the gas station and needed an emergency replacement. I used a wiffle golf ball (plastic) wrapped in saran wrap. Luckily there was a crossbar in the neck so that the ball couldn't fall in.
Well you get the idea.
/ Poulan gas cap #10
You jinxed me I went to cut wood this weekend (poulan saw) and coulden't get my gas cap out.
The thread is binding I had to wind it all the way out of the tank with the bar wrench the cap appears to has swelled or the tank shrunk.
I had to crank it back in with channel locks the bar oil cap is fine.
tom
/ Poulan gas cap #11
Talked with a Stihl guy last night and he recommended an ounce of sea foam along with the oil in every gallon. says this seems to help protect from the ethanol. He also recommended running synthetic oil. Any thoughts???
/ Poulan gas cap
Just as an update, I used my bench grinder on the threads about two months ago and so far no problems. I use it almost every weekend and have put several tanks of gas through it with no problems!! Thanx for the advice!!
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
2022 John Deere 5055E (A60462)
2022 John Deere...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
Freightliner Cascadia (A63689)
Freightliner...
John Deere X500 Riding Lawn Mower (A66285)
John Deere X500...
