Warranty void by adding hooks on FEL?
   / Warranty void by adding hooks on FEL? #62
...If you are on a concrete surface, you are basically screwed until the bucket contacts something that will hold it stationary... /QUOTE]
I park my loader on smooth concrete (garage floor) all the time, never had it slide during removal or installation.
I am not referring to your loader, but a NH 7308 and the identical model that followed.
I figured that was obvious when I referred to a specific operator's manual.
   / Warranty void by adding hooks on FEL? #63
I knew you were refering to a NH loader, but why would a NH loader be any different as far as the parking surface? Does the manual state to not park it on concrete? Or, is there something in the design of the NH loader that limits it's ability to park on concrete?
Serious question...a loader that slides on concrete (during mounting or dismounting) seems like a design defect.
   / Warranty void by adding hooks on FEL? #64
Ever hear the principle of the inclined plane? Apparently the rocket scientist that designed the 7308 hadn't. The loader frame is required to slide UP the front mount bosses. If the bucket doesn't have sufficient friction with whatever it is resting on, the loader moves forward rather than up & on. Stupid engineering.
   / Warranty void by adding hooks on FEL? #65
Ever hear the principle of the inclined plane? Apparently the rocket scientist that designed the 7308 hadn't. The loader frame is required to slide UP the front mount bosses...
OK...makes sense now...
Yep, a degree never made anyone smart...darn shame that a lot of folks have that delusion.
   / Warranty void by adding hooks on FEL? #66
I can't reach out with the loader arms because they are on the loader.....which is parked ....separate from my tractor
or am I missing something?
I was not trying to hook up a quick attach bucket....as I have no QA anything
I had taken the whole loader assy off the tractor for welding
I thought you putting on your bucket. I missed it!!
   / Warranty void by adding hooks on FEL? #67
I got my weld on hooks from ebay. 3 grade 70 3/8" hooks for $18 plus $5 shipping
2023 G Bar K Goose Neck Flat Bed (A55218)
2023 G Bar K Goose...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
Case Compact Wheel Loader Skid Steer (A55851)
Case Compact Wheel...
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A55851)
2025 Kivel 42in...
2022 JOHN DEERE 330G SKID STEER (A52705)
2022 JOHN DEERE...
